If you are looking for a simple, inexpensive, somewhat easy to make
light-flasher for your landing lights, check this out: geocities.com/eaa170/techc/AircraftLightFlasher.pdf . |
1. The URL given pops up "Page Not Found". Try this instead:
www.geocities.com/eaa170/techc/ and then click on the Aircraft Light Flasher pdf file. 2. The difficulty with this circuit is that we generally expect one side of both lamps to be grounded, one a taxi lamp and one a landing lamp. This design requires both sides of one lamp to be floating. 3. There is a different way of doing it, with both lamps grounded at one terminal, and using an inrush current limiter to achieve the same goals at http://www.rst-engr.com/kitplanes/KP0003/KP0003.htm . This design also uses FETs that are a little easier to come by than the ones suggested in the referenced article. Jim "ELIPPSE" wrote in message oups.com... If you are looking for a simple, inexpensive, somewhat easy to make light-flasher for your landing lights, check this out: geocities.com/eaa170/techc/AircraftLightFlasher.pdf . |
| Thread Tools | |
| Display Modes | |
| "bush flying" in the suburbs? | [email protected] | Home Built | 85 | December 29th 04 12:04 AM |
| Would a 3 million Candlepower spotlight make a good landing light? | Legrande Harris | Home Built | 6 | June 15th 04 07:32 AM |
| Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 05:35 PM |
| Effect of Light Sport on General Aviation | Gilan | Home Built | 17 | September 24th 03 07:11 AM |
| Landing Gear Lights-Need Wiring Help | BG | Home Built | 2 | August 17th 03 12:21 AM |
