TAS vs. flap reflex angle
Old January 13th 05, 12:46 AM
ELIPPSE
Default TAS vs. flap reflex angle
I recently did a flight test of my Lancair 235 testing TAS, true air
speed, vs. the reflex angle of the flaps, i.e. angle of the flaps above
the wing surface. The test was flown at 1535 lb, 11,000' density
altitude, full-throttle, leaned for max rpm.
+8 deg. - 196.2mph; +6 deg. - 199.7mph; +4 deg. - 196.2mph
+2 deg. - 189.3mph.
The test demonstrated that careful adjustment of the flap reflex angle
on Lancair or other aircraft so-equipped can result in higher TAS. The
reflex angle is sensitive to IAS and weight. As IAS decreases or weight
increases, L/D increases with less reflex, more camber and lower body
angle. An additional positive effect is that at the lower body angle,
vision over the nose is enhanced!
Old January 13th 05, 04:49 AM
Tim Ward
"ELIPPSE" wrote in message
+2 deg. - 189.3mph.
The nomenclature that sailplane pilots use for "reflex" is "negative flap".
You'll probably want to build a wing drag rake as shown at:
http://www.owp.us/Johnson/AtLast.asp
so that you can find minimum wing drag easily.
Do your ailerons reflex along with the flaps?
Tim Ward
Old January 13th 05, 06:14 AM
"Tim Ward" wrote in message
ink.net...
Tim Ward
Tim,
That sure looks like the page I created from Dick's article back in Feb,
2003!
http://www.soaridaho.com/Schreder/Te...ck_Johnson.htm
It even has the typo that I haven't corrected.
Old January 13th 05, 07:00 AM
Tim Ward
"Wayne Paul" wrote in message
ink.net...
Tim Ward
Tim,
2003!
I knew I'd seen it somewhere else. You realize, I'm not claiming it as my
work.
Tim Ward
Bending extruded angle Veeduber Home Built 8 August 29th 04 01:58 AM
7075 T6 Angle c hinds Home Built 7 May 17th 04 08:33 AM
Another angle... tongaloa Home Built 0 February 28th 04 12:13 AM
FS: Wing spar angle extrusions Bob Kuykendall Home Built 0 September 25th 03 09:23 PM
Flap design question Chris W Home Built 1 August 4th 03 03:50 PM
