Here in Salisbury, NC, the owners of portable hangars were just told they
had 30 days to remove their hangars. They leased land without the right to a long term lease. For the moment the County has relented but without that long-term lease, the County is just being nice. At McClellan-Palomar, California, the airport owner told some 100 hangar leasees that the hangars they leased were going to be torn down and they had to find some other airport to operate from. These people may not have built these hangars but the lesson is the same. Unless you have a long term lease to airport property, your lease can, and might be terminated. http://www.palomarairportassociation...master&PAGE_us er_op=view_page&PAGE_id=13&MMN_position=19:19 --Kent From: "abripl" Organization: http://groups.google.com Newsgroups: rec.aviation.homebuilt Date: 30 Mar 2005 17:54:37 -0800 Subject: 75 Year hangar lease BTW. I did ask for one real example of a problem with normal 5-10 year leases. Are we trying to fix a problem that does not exist? |
Vision 100 - Century of Aviation Reauthorization Act enacted last year,
requires (21) if the airport owner or operator and a person who owns an aircraft agree that a hangar is to be constructed at the airport for the aircraft at the aircraft owner's expense, the airport owner or operator will grant to the aircraft owner for the hangar a long-term lease that is subject to such terms and conditions on the hangar as the airport owner or operator may impose.'' http://frwebgate.access.gpo.gov/cgi-...cong_public_la ws&docid=f ![]() Problem is, the act doesn't say what a long-term lease is. Representative Pearce (R-NM) proposed a new law to say that a long-term lease is 75 years. I'm suggesting we should support that. --Kent From: Darrel Toepfer Are there any situations where normal 5-10 year leases have caused problems? With and airport receiving support funding from the FAA, the feds frown on leases over 25 years... |
Patrick, Patrick. It's a good deal--for the Airport. You build a hangar at
your expense, then you give it to the government after 20 years. If you could own it for 75 years, you would have an opportunity to sell it to somebody after you lost your medical. ;-) --Kent From: "W P Dixon" Organization: Internet News Service Newsgroups: rec.aviation.homebuilt Date: Wed, 30 Mar 2005 22:43:10 -0500 Subject: 75 Year hangar lease Hawkins County Airport, TN. was doing a thing that you built a hangar and you used it for 20 years, then it becomes property of the airport....which is county owned. Yep, they do get the hangar after 20 years ! I guess it's not to bad a deal. You get free land rent for 20 years, and the airport then gets a 15,000-20,000 dollar hangar. Patrick |
![]() "Kent Ashton" wrote in message ... Patrick, Patrick. It's a good deal--for the Airport. Oh I don't really think it is a good deal either, but it is the deal you get. Myself I do not have that kind of money just to give the local government,...they should build hangars from all the taxes they raise, and pilots should be able to use them for free; since our taxes paid for them in the first place. But that would be to much like a perfect world wouldn't it? ![]() Patrick |
Terms of a ground lease is a factor, but not the major problem. A
building merely housing airplanes is not the "highest and best use" of airport property, as they say in the business. The reason is that we don't like paying much in rents, even if we own a $400K airplane. C-172, forget it. Investors thus shy away. Sufficient length on the ground lease can attract commercial lenders, meaning much less put up by investors. Problem there is the need to assure the lender you'll be able to charge enough to make at least a little money. At our field, we worked with a commercial developer who donated his services to do various workups in full professional format. Rents, condo, combination, private money, banks. The cheapast one was still so costly a survey of all aircraft owners in a large area produced little interest. This even included an assumption of bays big enough for the corporate jet set, so as to subsidize the small bays. They later built three big hangars...for themselves. Two other groups of well-to-do people with planes worked up T-Hangar and community hangar proposals. Both abandoned the idea. Fred F. |
"TaxSrv" wrote in message
... Terms of a ground lease is a factor, but not the major problem. A building merely housing airplanes is not the "highest and best use" of airport property, as they say in the business. The reason is that we don't like paying much in rents, even if we own a $400K airplane. C-172, forget it. Investors thus shy away. Sufficient length on the ground lease can attract commercial lenders, meaning much less put up by investors. Problem there is the need to assure the lender you'll be able to charge enough to make at least a little money. At our field, we worked with a commercial developer who donated his services to do various workups in full professional format. Rents, condo, combination, private money, banks. The cheapast one was still so costly a survey of all aircraft owners in a large area produced little interest. This even included an assumption of bays big enough for the corporate jet set, so as to subsidize the small bays. They later built three big hangars...for themselves. Two other groups of well-to-do people with planes worked up T-Hangar and community hangar proposals. Both abandoned the idea. Fred F. I have no idea what you just said. Rich "That's why I'm poor, I guess" S. |
Maybe the problem is "minimum standards". The FAA permits an airport to
set "minumum standards", ostensibly to prevent plywood and tarpaper aircraft hangars, however the FAA lets airports set the minimum standards too high. At my local airport, the minimum aircraft hangar that can be built is a 60 X 80 foot hangar with full foam-water fire suppression, taxiway paving, car park paving, etc.; about a $300,000 project. A light aircraft owner seeking to build his own T-hangar is shut out. This airport will not even permit operators to share a hangar unless both own an equal interest in the hangar. --Kent From: "TaxSrv" Terms of a ground lease is a factor, but not the major problem. A building merely housing airplanes is not the "highest and best use" of airport property, as they say in the business. The reason is that we don't like paying much in rents, even if we own a $400K airplane. C-172, forget it. Investors thus shy away. Sufficient length on the ground lease can attract commercial lenders, meaning much less put up by investors. Problem there is the need to assure the lender you'll be able to charge enough to make at least a little money. At our field, we worked with a commercial developer who donated his services to do various workups in full professional format. Rents, condo, combination, private money, banks. The cheapast one was still so costly a survey of all aircraft owners in a large area produced little interest. This even included an assumption of bays big enough for the corporate jet set, so as to subsidize the small bays. They later built three big hangars...for themselves. Two other groups of well-to-do people with planes worked up T-Hangar and community hangar proposals. Both abandoned the idea. Fred F. |
("Darrel Toepfer" wrote)
With and airport receiving support funding from the FAA, the feds frown on leases over 25 years... Huh? The two are related how? Curious. Montblack Sitting on a 99 year land lease in our Townhose Association paperwork. Wonder what will happen in 60-75 years when all of these Townhome Association leases come due? |
Montblack wrote:
("Darrel Toepfer" wrote) With and airport receiving support funding from the FAA, the feds frown on leases over 25 years... Huh? The two are related how? Curious. Thats what we were told when we approached the airport board with our construction request. Previous constructors were given 50 or more year land leases. Nothing new has been built in over a decade though... 4R7 Since they are generous with the taxpayers dollars, the feds now want proof of performance from the locals airports before kicking in additional funding. ie. for new fueling systems and additional hanger construction, they wanna see budgets and operation information... Its been making me seriously consider something that easily folds, instead of having a fixed wing/location based plane... |
Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 02:39 AM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
Hangar Land Lease Rates? | Jim Kellett | Soaring | 1 | January 20th 04 06:42 PM |
APF: Naples, FL - Hangar over New Year | Nathan Young | Owning | 1 | December 24th 03 02:56 PM |
APF: Naples, FL - Hangar over New Year | Nathan Young | Piloting | 1 | December 24th 03 02:56 PM |
