Is there a drag rake guru out there?
Old March 31st 05, 11:18 AM
nimbusgb
Default Is there a drag rake guru out there?
Can anyone help with the design and installation details of a drag
rake?
I'm interested in:
Pitot tube sizing ( ID and length )
Span of the rake.
Positioning of the dynamic pressure port.
Plenum chamber/s dimensions.
Positioning of a rake on or behind the trailing edge.
Ian
Old March 31st 05, 01:49 PM
jphoenix
Ian,
Here's a link I was given last year, looks like a pretty good
description:
http://www.owp.us/Althaus/AlthausDragProbe.asp
rake?
I'm interested in:
Span of the rake.
Ian
Old March 31st 05, 02:31 PM
John Galloway
You could buy mine:-) Made by Replogle in the late
eighties to Dick Johnson's specifications - with meter
and tubing. Used once.
John Galloway
Scotland
At 13:00 31 March 2005, Jphoenix wrote:
Ian,
good
description:
of a drag
rake?
I'm interested in:
Span of the rake.
Ian
Old March 31st 05, 02:35 PM
Here is a link that may be helpful.
http://www.soaridaho.com/Schreder/Te...ck_Johnson.htm
"nimbusgb" wrote in message
ps.com...
rake?
I'm interested in:
Span of the rake.
Ian
Old March 31st 05, 05:18 PM
Ian Molesworth
Thanks Wayne,Jim
I am already aware of Johnson articles and Althaus's improved version.
Neither article actually discusses any of the maths behind the design
and positioning of a rake. I'm looking for a little more detail. I have
a prototype rake I built and I'll be testing its operation this weekend.
www.internationalsoaring.org/dragrake1.htm
Regards
Ian
Old March 31st 05, 06:00 PM
Brian
How much do you want for it?
Brian
Old March 31st 05, 06:01 PM
Brian
What are you using for meter?
Thanks
Brian
Old March 31st 05, 06:33 PM
nimbusgb
I have a differential pressure gauge built around a Honeywell DUXL01D.
Measuring 0 - 1" H20 which is the same range that I've seen used on the
old 80's repogle systems and in Dick Johnsons tests.
At the moment, during testing I'll be using an analog meter, my
amplifier outputs a signal between .6 and 4 volts. Ultimately it'll go
into an A/D converter on a digital system I have.
Ian
Old April 1st 05, 12:47 AM
jphoenix
Nice looking rake Ian.
It appears to be per the Althaus drawing?
Jmi
Ian Molesworth wrote:
Thanks Wayne,Jim
version.
have
weekend.
Regards
Ian
Old April 1st 05, 03:07 AM
Bob Salvo
An analog meter does a nice job of smoothing the information in mild
turbulence. Additional smoothing may be needed with a digital system. If a
pitot that is used to sample the airspeed at the other port of the pressure
gauge has the same hose size and length as the hose coming from the rake,
the pressure gauge output should be smoother. You might consider using a
Kiel tube for the pitot and mounting it on you drag probe. I hope to hear
more about your tests.
Bob
Ian
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Source of Induced Drag Ken Kochanski Soaring 2 January 10th 04 12:18 AM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
Did we decide if ballasted pullups are higher???????? Lars Peder Hansen Soaring 22 October 8th 03 12:45 AM
