Shear Pins for Propellors?
Old April 1st 05, 03:32 AM
Rich Lemert
Default Shear Pins for Propellors?
Back when I was growing up on the farm, we used several powered
implements that received their power from the tractor through a power
take-off assembly. Somewhere on the device's power train, between the
PTO take-off and the "business end" of the apparatus, there was always
either a belt-drive or a coupling fitted with a "shear" pin. Both of
these systems were intended to protect that tractor (and the implement)
by failing if the implement bit off more than it could handle.
This morning, while driving past the airport on my way to work, the
thought occured to me that a shear pin could be used to protect airplane
engines (at least partially) from prop strikes. My understanding is that
the props on light singles (at least) are connected directly to the
engine's drive shaft.
Recognizing that this issue is driven as much by regulation as by
anything, I'm wondering if there would be any benefit to using shear
pins in these systems. Would it reduce the need for a complete (or
partial) tear-down after a prop strike? Would there be any benefit for
more complex propeller arrangements?
Any thoughts?
Rich Lemert
Old April 1st 05, 03:45 AM
Peter Duniho
"Rich Lemert" wrote in message
link.net...
Frankly, having the prop keep moving is so much more important than
protecting the engine in the event of a prop strike, I can't imagine anyone
accepting the additional potential failure mode of a bad shear pin. We seem
to have a hard enough time making the crankshafts right.
Note that in a tractor, you are much more likely to suffer a sudden
stoppage, and the consequences for the premature breaking of a shear pin are
dramatically less. It seems to make much more sense for that application.
My understanding is that the props on light singles (at least) are
connected directly to the engine's drive shaft.
That's true of almost every propeller driven airplane. There are
exceptions, of course, mostly related to geared engine installations (found
on singles and twins).
Pete
Old April 1st 05, 04:12 AM
Morgans
link.net...
I have also had shear pins fail for no good reason. Aviation thinks that
designing in another point of failure is a bad thing.
Jim in NC
Old April 1st 05, 04:50 AM
nooneimportant
"Morgans" wrote in message
link.net...
Jim in NC
Don't some of the Rotax engines have a shear point to protect the engine? I
believe most vacum pumps have a Shear Wafer to protect the engine WHEN...
not IF the pump fails as well. But have ot agree that I'd rather have to
tear down an engine after a propstrike... than have the pin fail in
flight...
Old April 1st 05, 11:04 AM
Dale
In article .net,
Any thoughts?
I think the best protection for the engine would be to not land gearup,
taxi into super soft stuff, or do any of the other things that cause
prop strikes. G
Dale L. Falk
Old April 1st 05, 02:06 PM
John T Lowry
link.net...
implement)
airplane engines (at least partially) from prop strikes. My
Any thoughts?
Rich Lemert
Sounds to me like an idea worth pursuing. Could have two shear pins,
with visually checkable integrity during preflight inspection, to
counter the problem of one failing.
John Lowry
Flight Physics
Old April 1st 05, 02:28 PM
Dave Stadt
"John T Lowry" wrote in message
k.net...
link.net...
implement)
Any thoughts?
Rich Lemert
John Lowry
Flight Physics
Now you have added two additional points of failure.
Old April 1st 05, 03:38 PM
Jay Honeck
I'm sure Lycoming would be glad to pursue this, especially in light of their
recent failures in court.
Not.
Too bad, it's got merit.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old April 1st 05, 04:31 PM
Rolf Blom
Any thoughts?
Rich Lemert
Hmm...I think this would mean a weakening of the shaft.
And how would it be inspected at preflight, as was suggested?
Maybe there could be a market for a protective skid, something like the
Avro 504K, if prop strikes are a common occurrence?
/Rolf
Old April 1st 05, 05:01 PM
Rotax certified engines use a "slipper clutch" system to help protect the
crankshaft and gear box. It isn't a shear pin system, but rather a spring
loaded ramp-toothed afair that resets. Rotax has criteria for strikes that
still require teardown of the gearbox and/or the entire engine.
tom
Rich Lemert
Newbie question on trailering Setup joe Soaring 11 December 26th 04 11:10 PM
sound of wind shear Dan Jacobson General Aviation 2 May 11th 04 11:43 PM
IPAQ Wiring - which pins are used Michael Soaring 9 March 15th 04 08:48 PM
Amazing Wind Shear Today Jay Honeck Piloting 25 December 3rd 03 10:23 PM
taper pins Ernest Christley Home Built 4 September 12th 03 03:15 AM
