#11
Have you seen:
http://www.glidingmagazine.com/Featu...cle.asp?id=199 Bob "Bob Salvo" wrote in message ... An analog meter does a nice job of smoothing the information in mild turbulence. Additional smoothing may be needed with a digital system. If a pitot that is used to sample the airspeed at the other port of the pressure gauge has the same hose size and length as the hose coming from the rake, the pressure gauge output should be smoother. You might consider using a Kiel tube for the pitot and mounting it on you drag probe. I hope to hear more about your tests. Bob "nimbusgb" wrote in message ups.com... I have a differential pressure gauge built around a Honeywell DUXL01D. Measuring 0 - 1" H20 which is the same range that I've seen used on the old 80's repogle systems and in Dick Johnsons tests. At the moment, during testing I'll be using an analog meter, my amplifier outputs a signal between .6 and 4 volts. Ultimately it'll go into an A/D converter on a digital system I have. Ian |
Yup, been doing a LOT of reading lately!
Ian |
Pretty much.
2 * 10 pitots each over a 33mm span with a 'missing' tube a the midpoint. Gives the rake a 75mm span. The plenum chambers are seperate on each side of the wing and averaged by a tube running down the rear edge of the chamber. Ian |
Do you intend to use it to find the optimum flap position?
Bob "nimbusgb" wrote in message oups.com... Pretty much. 2 * 10 pitots each over a 33mm span with a 'missing' tube a the midpoint. Gives the rake a 75mm span. The plenum chambers are seperate on each side of the wing and averaged by a tube running down the rear edge of the chamber. Ian |
Yes, thats the general idea.
Ian |
max altitude and Mach 1 | Boomer | Military Aviation | 22 | June 1st 04 08:04 PM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
Source of Induced Drag | Ken Kochanski | Soaring | 2 | January 10th 04 12:18 AM |
Angle of climb at Vx and glide angle when "overweight": five questions | Koopas Ly | Piloting | 16 | November 29th 03 10:01 PM |
Did we decide if ballasted pullups are higher???????? | Lars Peder Hansen | Soaring | 22 | October 8th 03 12:45 AM |
