Shear Pins for Propellors?
Old April 2nd 05, 10:10 PM
David CL Francis
On Fri, 1 Apr 2005 at 02:32:55 in message
.net, Rich Lemert
This morning, while driving past the airport on my way to work, the
thought occured to me that a shear pin could be used to protect
airplane engines (at least partially) from prop strikes. My
understanding is that the props on light singles (at least) are
connected directly to the engine's drive shaft
It occurs to me that a shear pin could only work effectively against a
rotational stoppage. Since a normal prop either fits over a crankshaft
end or is bolted to a plate, a shear pin could do little or nothing.
What loading cases would you propose for the shear pin failure?
In a minor accident which way are the prop tips usual bent?
I somehow feel that the possibility of a prop detaching in flight should
not be encouraged. :-)
David CL Francis
David CL Francis
On Fri, 1 Apr 2005 at 13:06:26 in message
t, John T Lowry
Sounds to me like an idea worth pursuing. Could have two shear pins,
with visually checkable integrity during preflight inspection, to
counter the problem of one failing.
Good idea but when both were in place the shear failure load would be
twice as strong?
David CL Francis
  #24
Old April 3rd 05, 01:44 AM
This system would also allow the prop to windmill without attempting
to turn the
engine in cases of engine failure.
So what do we do for a flywheel?
Dan
  #26
Old April 3rd 05, 09:04 PM
That isn't a flywheel. It a ring gear mount for the starter
that also drives belt for the alternator (if it's a Lyc). It's aluminum
and weighs about four pounds. An engine such as the O-320, with its
four huge cylinders (compared to a Chev 350's eight much smaller ones,
for instance) would need a wheel of about 50 pounds in that small
diameter.
In all direct-drive aircraft engines the prop is the
flywheel. In most geared certified engines, the prop is the flywheel.
Geared ultralight engines like the Rotax have a separate flywheel, as
do many of the converted and geared or belted auto engines. They have
other problems with resonance between the prop and flywheel that can
lead to belt or gear failures if not properly designed and operated.
Dan
Newbie question on trailering Setup joe Soaring 11 December 26th 04 11:10 PM
sound of wind shear Dan Jacobson General Aviation 2 May 11th 04 11:43 PM
IPAQ Wiring - which pins are used Michael Soaring 9 March 15th 04 08:48 PM
Amazing Wind Shear Today Jay Honeck Piloting 25 December 3rd 03 10:23 PM
taper pins Ernest Christley Home Built 4 September 12th 03 03:15 AM
