#11
Dan Luke wrote:
Truck broke? Yep: starter busted. Interesting. The trucks with which I'm familiar use a PTO to run the pump. They never shut the engine off when fueling. George Patterson Whosoever bloweth not his own horn, the same shall remain unblown. |
![]() "George Patterson" wrote: Truck broke? Yep: starter busted. Interesting. The trucks with which I'm familiar use a PTO to run the pump. They never shut the engine off when fueling. Hmm...that's right. I dunno George, that's what the lady at the FBO said. -- Dan C172RG at BFM |
![]() "Andrew Gideon" wrote: That was my guess, that they probably would have at least left a note. But that's assuming good sense on the part of the late shift line guy, a very shaky assumption at best. Considering where he left the broken truck, he appears to be making your point for you. That's what bothered me: they have a tug big enough to pull a 737, so why just leave the truck sitting there unless there was another reason? -- Dan C172RG at BFM |
![]() Do you hear anything rattleing in the the fuel tank, like a mini maglite? - Steve "Dan Luke" wrote in message ... "Andrew Gideon" wrote: That was my guess, that they probably would have at least left a note. But that's assuming good sense on the part of the late shift line guy, a very shaky assumption at best. Considering where he left the broken truck, he appears to be making your point for you. That's what bothered me: they have a tug big enough to pull a 737, so why just leave the truck sitting there unless there was another reason? -- Dan C172RG at BFM |
Stephen McNaught wrote:
DoÂ*youÂ*hearÂ*anythingÂ*rattleingÂ*inÂ*theÂ*theÂ* fuelÂ*tank,Â*likeÂ*aÂ*mini maglite? - Steve No joke. One of our annuals found a flashlight in a wing. Not a fuel tank; the wing itself. It could only have been left by someone doing maintenance...or a prior annual. It makes me wish tools were id coded. But that would be Yet Another Price Increase for GA maintenance. - Andrew |
Dan Luke wrote:
[zap] It's time to go; you could push the plane away from the truck and taxi away, but now you're wondering: did they block it for a reason? Is the fuel contaminated? Did someone notice something dangerous about the plane that you don't see? Did you forget to pay your fuel bill? What??? In the event, I did an extra careful preflight, took large fuel samples, did an extended run-up and took off with no problems. Would you have? I would have done the same as you. My suggestion for the day: Always preflight as though you found the truck blocking your plane, and always fly like you have the DE sitting next to you. Hilton |
I'd complain to the FBO about the "hassles" and be glad that you could push
back and get away.. good thing it was not a 12,000# King Air. BT "Dan Luke" wrote in message ... "George Patterson" wrote: Truck broke? Yep: starter busted. Interesting. The trucks with which I'm familiar use a PTO to run the pump. They never shut the engine off when fueling. Hmm...that's right. I dunno George, that's what the lady at the FBO said. -- Dan C172RG at BFM |
I would not have even thought about it like that. I would have flown and
then, if it still bothered me, complained to the FBO when I got back. |
"Dan Luke" writes:
In the event, I did an extra careful preflight, took large fuel samples, did an extended run-up and took off with no problems. Would you have? Yes. Line-guys are not studying Rocket Science for a reason. |
"BTIZ" wrote in message news:1Z_3e.3181$ZV5.821@fed1read05...
I'd complain to the FBO about the "hassles" and be glad that you could push back and get away.. good thing it was not a 12,000# King Air. Throw a chain around the nose gear and tow it out of the way... I'm got a Hemi... |
