LOA's are still around. For the ex-mil's now they have a weird
pseudo-type-rating system that shows up on your license. But that applies only to ex-mil on that AC that's been recently updated. For my BD-5J, for example, I was told to apply for an LOA, and that's what the FSDO will issue me if aero-medical ever gets around to handling my special issuance renewal. "AINut" wrote in message ... The LOA is no longer called an LOA, but from what the FSDO told me about the requirements, it is still a rose by another name. Don Hammer wrote: Used to be ex military aircraft were in the Restricted category. I dealt with a Grumman Goose and a Lodestar years ago where that was the case. Is that no longer true or are fighters and trainers different? The way I remember it was the FAA came out with the hours and LOA requirement because there were too many doctors and lawyers that had more money than brains and got out of their Bonanza and into a P-51 and killed themselves. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
![]() "Ron Wanttaja" wrote in message ... There are two main airworthiness categories: Standard and Special. Standard airworthiness aircraft are proven to meet certain FAA standards, and The FAA waiver usually demands that these planes receive professional-type maintenance similar to that of standard airworthiness aircraft (e.g., the L-39 instructor won't be allowed the maintain the plane himself unless he has an A&P license). Ron "It's *albatross* bloody flavor" Wanttaja Nice write up Ron... Thanks! Dan D. |
![]() "Ron Wanttaja" wrote There are two main airworthiness categories: Standard and Special. "Blueskies" wrote Nice write up Ron... Thanks! Dan D. ************* Yea Ron! That was 'splained pretty good! You ought ot write a book, or sumpthin'! (wink) g -- Jim in NC |
![]() "Don Hammer" wrote in message ... Used to be ex military aircraft were in the Restricted category. I dealt with a Grumman Goose and a Lodestar years ago where that was the case. Is that no longer true or are fighters and trainers different? Flavors and trends do change over time. It did indeed, used to be the case that most warbirds that didn't have a civilian type certificate were certified in the "Restricted" category with the specific restrictions determined on a case by case basis. As I recall there were also some in the "Limited" category, with the specific limitations also determined on a case by case basis. At that time it was also true that the "certificate" given to an amateur built aircraft was only valid for one year. Every year you had to have the FAA come out and inspect the airplane to renew it. Then the FAA figured out that they were in the business of giving free annuals for homebuilts and instituted the present permanent "certificate" that must be inspected every year by a certified mechanic. Note that a "repairman certificate" holder is a "certified mechanic" whose "certification" extends only to one specific airplane. :-) Nowadays most of the warbirds are finding their certification easier in the "Exhibition" category. This category generally allows some radius of operation, of several hundred nautical miles, for "pilot proficiency maintenance" where you can fly pretty much as you please. Trips outside of that radius require that the FAA be "notified" prior to the trip. Generally you can fax the FAA office a "notification." You can also send them a list of the shows and flyins that you plan to attend once a year. Much of this change is because of the changing view of warbirds. At one time they were just big, expensive, impractical airplanes. Now they are antiques and collectors items and people pay money to see them up close and see them fly. I can remember when you could buy a surplus fighter for a couple of thousand bucks because nobody wanted the headaches. I just wish I had bought a few dozen of them an stored them in the back of my hangar! :-) I did meet one older gentleman down in Louisiana who had thirty Stearman trainers brand new in the crate stored in the back of his hangar. He said whenever he needs a little extra money he puts one together and sells it. Since that was back in the sixties, I doubt that any of them are left in the hangar. He was in his sixties then as well and may not need extra money anymore! Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
There is the old story about the DC-3. I recall it was designed before the
CAA adopted the new regulations in the thirties. The new regulations required that each airplane used in commercial service must have an emregency exit over the wing. However, that could not be done on the DC-3. It just happened that the DC-3 was already in service and the safest airplane in service. So, the newly created FAA gave a temporary type certificate to the DC-3 and it flew for a long time with a temporary type certificate. It had been awhile since I heard the story and sometimes facts get twisted, so I did a search and found in part 125 of the regulations the following: "This paragraph does not apply to the rear window emergency exit of DC-3 airplanes operated with less than 36 occupants, including crewmembers, and less than five exits authorized for passenger use." So, the FAA can make any rule it wants to make and then exempt airplanes from their own rules, just because it feels like it. I think wives have the same power. Colin N12HS |
("COLIN LAMB" wrote)
snip So, the FAA can make any rule it wants to make and then exempt airplanes from their own rules, just because it feels like it. I think wives have the same power. Yeah, but they don't write anything down for you to reference. You kind of have to keep up with the changes as you go... Montblack |
![]() "Ron Wanttaja" wrote in message ... There are two main airworthiness categories: Standard and Special. Standard airworthiness aircraft are proven to meet certain FAA standards, and The FAA waiver usually demands that these planes receive professional-type maintenance similar to that of standard airworthiness aircraft (e.g., the L-39 instructor won't be allowed the maintain the plane himself unless he has an A&P license). Ron "It's *albatross* bloody flavor" Wanttaja I'm curious what warbird experimentals come with a restriction that A&P's must maintain them. Far as I know, all experimentals are still exempt from FAA Part 43, and all of them carry the same annual condition inspection requirement in the operating limitations... 43.1.(b) This part does not apply to any aircraft for which the FAA has issued an experimental certificate, unless the FAA has previously issued a different kind of airworthiness certificate for that aircraft. ?? |
On Thu, 7 Apr 2005 16:36:28 -0500, "Highflyer" wrote:
I can remember when you could buy a surplus fighter for a couple of thousand bucks because nobody wanted the headaches. I just wish I had bought a few dozen of them an stored them in the back of my hangar! :-) Dunno, HF...I've *seen* your hangar. Sure there ain't a couple of P-40s stashed in back? :-) Ron Wanttaja |
![]() "Ron Wanttaja" wrote in message ... On Thu, 7 Apr 2005 16:36:28 -0500, "Highflyer" wrote: I can remember when you could buy a surplus fighter for a couple of thousand bucks because nobody wanted the headaches. I just wish I had bought a few dozen of them an stored them in the back of my hangar! :-) Dunno, HF...I've *seen* your hangar. Sure there ain't a couple of P-40s stashed in back? :-) Ron Wanttaja No P-40s Ron. However, there ARE a couple of Vultees. :-/ Back behind the Stinson and the Pietenpol and the Cavalier and the Apache. It is getting crowded in there. One of these days I will get ALL of them together and flying. Then I WILL have a parking problem! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
PA-32 on Experimental Certificate | Mike Granby | Owning | 3 | July 21st 04 03:04 AM |
Crashing Experimental on America's Funniest Home Videos | Jay | Home Built | 7 | March 10th 04 12:11 AM |
USA: Experimental Certificates | C.Fleming | Soaring | 4 | October 30th 03 10:48 PM |
A couple Questions-Ramp Checks and Experimental Operations | Badwater Bill | Home Built | 48 | October 8th 03 09:11 PM |
2 Place Experimental.... | [email protected] | Soaring | 8 | September 7th 03 03:03 AM |
