V8 fuel flow
Old January 23rd 05, 02:27 AM
Blueskies
"Big John" wrote in message news
Blueskies
Are you saying that if you lean the mixture until engine quits, then
the EGT goes down?
I'm still alive but lurking )
Big John
On Wed, 19 Jan 2005 23:09:06 GMT, "Blueskies"
"stol" wrote in message oups.com...
Lean mixture makes the exhaust hotter, not a rich mixture.
Up to a point, then it gets cooler...
Well, some folks argue for best economy they lean the mixture then go past peak to the lean side of peak which lowers
EGT...YMMV
  #32
Old January 23rd 05, 04:16 PM
Ben, I misunderstood the 310-to-240 derate... however, even with that
change, YOUR numbers still do not work. In your first post (the one I
was replying to...(you changed to 12.6 in this last post)) you stated
fuel flow of "...11.8-12.3 an hour...". If one uses 12.3, this
computes to (12.3 x 5.85)/240 = 0.3
If one uses the 11.8 number, this computes to (11.8 x 5.85)/240 = 0.29
BSFC.
Now, to say something nice..... I found the photos of your engine
installation to show nothing less than beautiful workmanship!!
Regardless of how the numbers shake-out, it is a conversion to be proud
to show.
73,
Sid
  #33
Old January 23rd 05, 04:26 PM
Blueskies
BSFC.
to show.
73,
Sid
What is the fuel used in that engine - autogas, 100LL?
  #34
Old January 24th 05, 03:41 AM
stol
I
0.29
BSFC.
proud
to show.
73,
Sid
Thank you sir. I am using a JPI 450 fuel flow gauge and it is still in
the calibrate test mode. It appears to read a bit on the low side,
maybe 8 to 10 % I am making repeated flights to verify the true flow
though it. Ya see I used the bigger transducer to be sure of proper
flow though it in case I needed to gravity feed to motor in case both
fuel pumps fail. That change probably confuses the 450 head unit. I am
sure the flows to the carb and engine are correct as all my plug cuts
show a good color and after years of being in the engine development
business I am pretty sure what a proper running engine should feel
like. To answer the other guys question, so far I have only used 100LL
just to make sure I don't get too far off baseline. I do admit I have a
new respect for test pilots,, thats for sure.. I will keep posting
results as they are produced. Ya have to keep in mind I realize this
thing might do me in on the next flight, but thats the price to pay for
pushing the envelope.
Ben Haas N801BH
  #35
stol
I
0.29
BSFC.
proud
to show.
73,
Sid
Ben Haas N801BH
fuel flow measurement khanindra jyoti deka Home Built 0 January 5th 05 04:34 AM
advanced fuel flow mesurement system using microcontroller khanindra jyoti deka Home Built 4 January 4th 05 01:18 AM
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
