Instrument PTS vs. GPS AFM -- who wins?
Old April 8th 05, 01:50 AM
Roy Smith
Default Instrument PTS vs. GPS AFM -- who wins?
I just noticed an interesting problem with the Instrument Rating PTS. It
says:
Aircraft and Equipment Required for the Practical Test
[...] GPS equipment must [...] contain the current database.
The problem is that not all GPS units require that the database be current.
The CNX-80 AFM Supplement says:
2.3 DATABASE
The CNX80 Database Card P/N 138-0329-010 Rev. -- (or later FAA approved
version) must be installed.
a) IFR enroute and terminal navigation is prohibited unless the pilot
verifies the currency of the database or verifies each selected waypoint
for accuracy by reference to current approved data.
b) Instrument approaches using the CNX80 are prohibited unlessCNX80
approach data is verified by the pilot or crew to be current. Instrument
approaches must be accomplished in accordance with approved instrument
approach procedures that are loaded from the CNX80 database.
So, it's perfectly legal for me to fly with an expired database, as long as
I verify that the data is correct (presumably by comparison to a current
chart).
Old April 8th 05, 02:55 AM
John R. Copeland
"Roy Smith" wrote in message =
I just noticed an interesting problem with the Instrument Rating PTS. =
It=20
says:
=20
=20
The problem is that not all GPS units require that the database be =
current. =20
=20
2.3 DATABASE
The CNX80 Database Card P/N 138-0329-010 Rev. -- (or later FAA =
approved=20
a) IFR enroute and terminal navigation is prohibited unless the pilot=20
verifies the currency of the database or verifies each selected =
waypoint=20
b) Instrument approaches using the CNX80 are prohibited unlessCNX80=20
approach data is verified by the pilot or crew to be current. =
Instrument=20
approaches must be accomplished in accordance with approved instrument =
=20
So, it's perfectly legal for me to fly with an expired database, as =
long as=20
I verify that the data is correct (presumably by comparison to a =
current=20
chart).
Roy, I've wrestled with that same idea.
I've concluded they are two separate items. That's to say:
(a) I may navigate IFR with an expired CNX80 database if I verify its =
data, but
(b) I may not use an expired database on a flight test.
I can live with that dichotomy.
Old April 8th 05, 05:01 AM
Ross Oliver
2.3 DATABASE
chart).
I'll play Satan's attorney for a moment, and argue that in this context,
the phrase "approach data" does not mean "data for a specific approach" but
instead means "ALL the data for ALL approaches," making manual verification
somewhat impratical ;-)
I could also argue that since the statement does not specify what is an
acceptable method of data verification, the only acceptable method is
verifying the revision date of the entire data set.
Sure, these arguments could be totally bogus, but do you really want to
take that chance?
Old April 8th 05, 05:24 AM
Stan Gosnell
"John R. Copeland" wrote in
data, but (b) I may not use an expired database on a flight test.
Any similarity between checkrides and the real world is merely an
illusion. For a checkride, do what you have to do to make the examiner
happy. In the real world, do what you have to do to remain safe and
legal. They aren't necessarily mutually exclusive, but they certainly
are not the same.
Regards,
Stan
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety." B. Franklin
Old April 8th 05, 11:50 AM
The way I read that says that you can use an expired database for
enroute or terminal navigation (paragraph a), however you must have a
current database in order to use it for approaches (paragraph b).
That makes a lot of sense to me, and since the PTS now calls for a GPS
approach if the aircraft is equipped with one, looks like you should
have a current GPS.
If, however, you can get the DE to do the approach in VFR conditions,
then you're still VFR and he may allow you to use the expired
database.
says:
2.3 DATABASE
chart).
Old April 8th 05, 01:16 PM
Ron Rosenfeld
says:
But apparently the I-PTS requires that the database be current "in order to
take the Practical Test". Just because something is required for purposes
of taking the test, does not necessarily mean that it is required to be
legal in other circumstances.
Old April 16th 05, 12:42 AM
andrew m. boardman
says:
There are all sorts of little requirements in various PTS's that call for
requirements beyond what you'd need for the actual sort of operation
you're testing for. (Complex aircraft, full dual controls, that sort of
thing.) This of this as just another one. (Or you can just think of it
as the FAA being randomly weird. They do that.)
Old April 17th 05, 03:11 AM
Sully
If I remember right though the PTS says for something to the effect
that if the aircraft is equipped with an IFR approved GPS that one of
the approaches needs to be a GPS approach. If you do not have the
current database then you can do another non-gps approach and it is a
dead issue.
says:
2.3 DATABASE
chart).
Instrument Checkride passed (Long) Paul Folbrecht Instrument Flight Rules 10 February 11th 05 02:41 AM
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
Tips on Getting Your Instrument Rating Sooner and at Lower Cost Fred Instrument Flight Rules 21 October 19th 04 07:31 AM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
