"BA-100" wrote in message ... "W P Dixon" : Luthiers commonly steam wood and form it over jigs, clamps hold it in place until it drys out. May be the same kind of construction used to build this sailplane. Just a thought and maybe something to check out. Yes, I've done this in fact. Have a guitar and a violin under my belt, but no compound curves. Most flattop guitars have a small radius which is compound, but nothing like what I'm talking about (a complete teardrop) This sort of technology realy died out when fibreglass hit the scene, though i'm sure there are some masters still around.Most likely source of info are boatbuilders, of course, but their curves wouldn't even appraoch the radius I'm talking about..... The key to bending wood with steam is how hot it is. Superheated steam is best, which takes a re-heater after the water is boiled. Make sure the plywood is made with water proof glue, which is anything of A grade or better, or marked withEXT after the grade. It might be B grade, but I don't remember, right off. For testing, that type of plywood is fine, but for building a plane, use at least marine grade, and best is aircraft grade. -- Jim in NC |
"Alan Baker" wrote Is everyone forgetting the deHavilland Mosquito? Constructed almost entirely of cold-moulded plywood. Isn't cold molding done using layers of wood, with glue applied as the wood is bent in the mold, with the glue setting up in the new shape? -- Jim in NC |
BA-100 wrote: My question is, would it be possible to laminate your own shell using vacuum bagging? ------------------------------------------------------ Yes. But with a bit of fore-thought. My first effort at vacuum bagging leading-edge skins ended up crushing my mold :-) --------------------------------------------------- Seems to me even the wettest veneers would split if you tried to force them into or around a male or female mold. -------------------------------------------------------- Forming a compound curve, the plywood is usually HOT as well as wet, and is remarkably plastic. A standard technique in the repair of such structures offers a bit of insight into fabricating such a hull from scratch. The general procedure is as follows: A mold is taken from the opposite side of the structure. (The assumption here is for a symmetrical form). The mold is usually made of plaster, stiffened with burlap or jute fiber and is a few inches larger than the section to be replaced. The plaster mold is used create a pair of re-enforced concrete molds, much thicker than the plaster mold and usually in a frame of welded steel angle-iron that has been previously drilled for bolts. The concrete is wet-cured for about a week then air-dried in a warm hangar for about ten days. The plywood or veneer is boiled or steamed then laid into the mold, which has been pre-heated to about 170*. If veneer, the usually adhesive is a urea-formaldehyde type such as Weldwood 'Plastic Resin' or resorcinol (the concrete mold must be protected). The upper part of the mold is put in place and drawn down with bolts. The closed mold is then returned to the oven or hot box and allowed to cure for 24 hours. The resulting part is then scarfed to match the area to be repaired. --------------------------- The point often overlooked is that this method may also be used for scratch-building the entire pod. This is because the pod is symmetrical. Other than the nose, which is usually carved from balsa, you need only five or six molds to duplicate a longitudinal SLICE from the pod. The builder simply makes eight copies of each panel then scarfs them onto a frame. It should also be apparent that this method works even better using composite materials and vacuum-bagging, since you need only a few pounds per square inch to cause the fiber & resin to conform to the shape of the female mold (the male part is not required). Prior to WWII there was considerable effort devoted to composite structures including a few that actually flew (circa 1940) but they tended to be heavier than their aluminum counterparts. I know the glider people, but here (ie, Sandy Eggo) and Santa Monica had considerable success using linen fabric, balsa cores and urea-formaldehyde 'resins.' ------------------------------------- Although the Loughead brothers are often cited as the first to use the laminated ply fuselage, there were some earlier airframes that pioneered the process. I can't recall the details but 'LMB' comes to mind; some outfit on the east coast, shortly after WWI. (I'm old. I forget things and fart a lot.) This eventually lead to the patented Duramold process which Howard used on the HK-1. -R.S.Hoover |
"Morgans" wrote: "Alan Baker" wrote Is everyone forgetting the deHavilland Mosquito? Constructed almost entirely of cold-moulded plywood. Isn't cold molding done using layers of wood, with glue applied as the wood is bent in the mold, with the glue setting up in the new shape? Yup. And the original post was talking about just that, ISTM. "Seems to me even the wettest veneers would split if you tried to force them into or around a male or female mold. to date," -- Alan Baker Vancouver, British Columbia "If you raise the ceiling 4 feet, move the fireplace from that wall to that wall, you'll still only get the full stereophonic effect if you sit in the bottom of that cupboard." |
("Morgans" wrote)
For testing, that type of plywood is fine, but for building a plane, use at least marine grade, and best is aircraft grade. "...and best is aircraft grade" I know about marine grade plywood, but aircraft grade? Speaking of marine grade plywood (I paid $77 w/tax for a sheet of 3/4" last year) is there such a thing as marine grade + green treated that they sell? That's what I wanted, couldn't find any. Something about varnish + green preservative doesn't do well together I was told. (???) It was for a carpeted-over floor in a 16 ft boat. We ended up spar varnishing our sheet a number of times. Montblack |
"Nafod40"
egroups.com: BA-100 wrote: My question is, would it be possible to laminate your own shell using vacuum bagging? I would do some googling on "cold molding" and boatbuilding. Very common method for building hulls. It's also how the SPruce Goose and Mosquito bombers were built. You'd find... Yeah, knew that, though I'm not so sure it's suitable for this particular airplane. Unfortunately, I've never seen one of the molded ones, only the one in the NASM and that was built using scarfed rings. If I'm not mistaken, the molded ones were made of single sheets of veneer made into a ply in the mold, but I may be wrong about that. http://www.nwmarinedesign.com/coldmold.htm You can build up a structure as strong as fiberglass but lighter with this technology. Mmm, that's the idea! Plus it just looks beautiful. I don't think they were made in quite the same way as the cold molded boats are though. |
"Montblack" wrote in message Speaking of marine grade plywood (I paid $77 w/tax for a sheet of 3/4" last year) is there such a thing as marine grade + green treated that they sell? That's what I wanted, couldn't find any. Something about varnish + green preservative doesn't do well together I was told. (???) It was for a carpeted-over floor in a 16 ft boat. We ended up spar varnishing our sheet a number of times. Montblack Yea, I know what you mean. A friend wanted to do the same thing. We found a place that treats wood, and got him to throw in some sheets of marine grade into his treating thingy, the next time he was running a load. We then (after waiting for it to dry out some) put it down and put a layer of fiberglass cloth and epoxy over it all, before laying the carpet. It looks like new, about 5 years later. -- Jim in NC |
vacuum bagging? Seems to me even the wettest veneers would split if you tried to force them into or around a male or female mold. to date, the only sort of manipulation I've done with ply is to wrap 1/16 leading edge pieces over a hot pipe. I just don't see how Hawley Bowlus got the compound curves.. They used a boatbuilding and canoemaking technique that used bands of thin veneer laminated over a male mould. The process is called "Cold Moulding" and there are a couple of books about it in the "boatbuilding" section of the library. Essentially you build up a male plug with plywood formers covered with fairly closely spaced strips of lath. The veneer thickness is selected to give you an odd number of laminations, 3, 5, 7, etc. The bottom layer goes on about forty five degrees to the lathing. Staple it down here and there to hold it in place. It is wise to use heavy cardboard tags under the staples because you are going to pull them out when you put the next layer in place. Brush the first layer with glue and cross it with the second layer at something approximating 90 degrees. Aerolite glue works well. Brush the cream component onto the first layer and then brush the hardener onto the bottom of the second layer. Pull the staples as you go and restaple through both layers. The third layer goes on like the second, but aligned with the airflow so the finished grain will be pretty! :-) Pull staples and staple it down as you go. After all the layers are down pull you vinyl over the whole banana and turn on the vacuum pump to pull it all tight and hold it down. If you want more than three layers of veneer repeat layers 1 and 2, finishing with the top layer aligned with the airflow. After the glue is hardened, remove the bag and sand the whole thing with a random orbital sander to contour. Standard industrial veneer for veneering furniture, etc. is 1/28 inches thick. That is just under a millimeter for you continental folks. A three layer veneer would be close to 3mm thick or a stout 1/8 inch. Be gentle sanding because it is really easy to sand completely through a veneer layer and get real embarassed! Any stringers or frames are glued inside after the skin is finished. This CAN be done without expensive or bulky tooling. The Dutch made fighters using this technology in WWI. Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
"Morgans" wrote in message ... "Alan Baker" wrote Is everyone forgetting the deHavilland Mosquito? Constructed almost entirely of cold-moulded plywood. Isn't cold molding done using layers of wood, with glue applied as the wood is bent in the mold, with the glue setting up in the new shape? -- Jim in NC Exactly. Plywood is nothing but thin veneers of wood glued together face to face with the grain running at different angles, generally ninety degrees, but sometimes other angles for special applications. Plywood is normally laminated on a flat plate making a flat sheet of wood that is very hard to bend into anything other than a conical curve because the laminated layers are glued together so they can't slide. Cold Moulding is merely a low temperature process using ordinary waterproof glues, for makeing you own plywood from thin veneers that is formed over something other than a flat plate, so that it comes out with the shape of the mould it was laminated in or on, as the case may be. No reason in the world you can't make compound curved plywood by laminating it up over a male plug and useing a vacuum bagging process to apply the requisite clamping pressure. Ideally pick a good waterproof glue that gives you a rather long working time and bonds well with a fairly low clamping pressure. Say 5 to 10 pounds per square inch clamping pressure that you can easily obtain with simple vacuum equipment. Working time of fifteen or twenty minutes should allow time to build up thin laminations and get clamping pressure onto them. This can be stretched a lot by using staples with a pull pad under them to apply temporary clamping pressure as you build up the lamination. I have only done this using older glues like resorcinol and aerolite and urea resin. I would think it would work very well with some of the more modern epoxy based wood glues like T-88, etc. If it works for canoes, it oughtta work for a Bowlus. :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
| Nut/thread securing compound | nauga | Home Built | 7 | April 22nd 04 08:56 AM |
| Randolph Wing Walk Compound | Larryskydives | Owning | 7 | March 7th 04 10:44 PM |
| Plywood | Kathi Jo | Home Built | 3 | January 12th 04 11:48 PM |
| Somebody Terrified of Compound Curves ---- Or Just Lazy | Larry Smith | Home Built | 8 | October 31st 03 03:40 PM |
| Substitute for Mahogany plywood | Kelvin & Janice Rempel | Home Built | 1 | September 5th 03 09:02 PM |
