Reading back altimeter settings?
Old April 8th 05, 12:41 PM
Denny
The controller is off any hook if he issued the altimeter, a readback
or
lack of one changes nothing.
In it's infinite wisdom the gov't has decided that even if you read
back the wrong information and the controller does not correct it you,
the PIC, are responsible if subsequently violate airspace, or crash,
etc.
Do your homework, it's a mean world out there...
denny
Old April 8th 05, 01:20 PM
Ron Tock
Steve Foley wrote:
I always read back any numbers given by ATC. Altimeter, runway, heading,
altitude.
"Paul Tomblin" wrote in message
Does anybody have a good handle on when ATC wants you to read back
altimeter settings? On a single IFR flight on Tuesday, I encountered
several controllers who I'd check in with, and they'd give me an altimeter
setting, and that would be it, and 2 (both in Canada, BTW) whom when I
didn't read back the altimeter setting gave it to me again.
Paul Tomblin http://xcski.com/blogs/pt/
What boots up must come down.
Rodger that. I read back all numbers. It's cheap insurance.
Old April 8th 05, 06:06 PM
Paul Tomblin
In a previous article, John Harper said:
"identing" - "they can see it on the screen, you don't need to tell them"
I've had controllers request it again after I just pushed the ident button
without telling them that I was doing so. You'd think that only one VFR
target would be identing when they asked, but evidently not.
If you're not part of the solution, you're part of the precipitate.
Old April 8th 05, 08:32 PM
Steven P. McNicoll
"Denny" wrote in message
etc.
Actually, it hasn't. What the government decided was that if you read back
a clearance meant for another aircraft and the controller doesn't hear your
readback because your transmission was blocked by the transmission from the
proper aircraft then you, the PIC, are responsible for any loss of
separation, airspace bust, crash, etc., due to your error.
Old April 8th 05, 09:08 PM
Larry Dighera
On Fri, 08 Apr 2005 19:32:34 GMT, "Steven P. McNicoll"
wrote in
et::
roups.com...
etc.
Here's some background information on the subject:
The Federal Register cite is he
http://www.aopa.org/whatsnew/regulat...retiverule.pdf
http://www.aopa.org/whatsnew/regulat...erpretive.html
Regulatory Brief
FAA interpretive rule places the responsibility for compliance with
ATC clearances and instructions squarely on the pilot
The issue:
On April 1, 1999, the Federal Aviation Administration published what
they called an "interpretive rule" in the Federal Register. The stated
purpose of this interpretive rule was to "correct" the National
Transportation Safety Board legal interpretation of the FAA
regulations regarding communications between the pilot and air traffic
control personnel. In essence the interpretive rule overturns a line
of reasoning developed through a series of enforcement case appeals
heard before the NTSB Administrative Law Judges. This line of
decisions absolved the pilot of responsibility in certain instances
where incorrect information was read back by the pilot and not caught
by ATC personnel. FAA’s new interpretive rule squarely places the
primary responsibility on the pilot to listen attentively, to hear
accurately, and to construe reasonably all ATC instructions and
clearances. In effect, the simple act of giving a readback does not
shift the primary responsibility to air traffic control and does not
insulate the pilot from enforcement action in the event of error.
The importance to our members:
The FAA’s issuance of this interpretive rule raises several concerns.
First, it shifts all responsibility for proper communication and
understanding to the pilot, raising the specter of increased
enforcement actions against airmen for communications deviations.
Further it tampers with the notion that aviation safety requires air
traffic control to function as a cooperative system, in which all
participants must share the responsibility for accurate communication.
The interpretive rule places the pilot and controller in an
adversarial position, each trying to protect themselves from penalty
or enforcement. Perhaps the greatest consequence of this interpretive
rule is the precedent that it sets for the NTSB appeal process. In
effect, the FAA is demonstrating a willingness to overturn any line of
reasoning or decisions developed through the NTSB enforcement appeal
process that do not fit the FAA’s desired interpretation. Further,
they feel they can do this by publishing a simple statement in the
Federal Register describing their desired interpretation. This
approach sets a dangerous precedent and could be applied in the future
to overturn other NTSB appellate lines of reasoning deemed to be
undesirable by the FAA.
Significant provisions:
FAA’s general operating and flight rules require pilots to comply with
the clearances and instructions of air traffic control, unless they
are amended, except in an emergency or in response to a traffic alert
and collision avoidance system resolution advisory.
It has traditionally been the FAA’s view that it is the duty of pilots
and controllers alike to adhere to a high standard of clear
communication, attentive listening, and reasonable understanding.
Given these shared responsibilities, the FAA deems responsible the
participant who is the initiating or principal cause of a
miscommunication or misunderstanding.
NTSB case law reasoned that a pilot was absolved of responsibility if
an erroneous full read back of clearances or instructions were given
by the pilot and the error was not detected or corrected by the
controller.
FAA does not agree with the NTSB’s interpretation and believes this
requires correction.
FAA states that the simple act of giving a readback does not shift
full responsibility to air traffic control and cannot insulate pilots
from their primary responsibility under §91.123.
AOPA position:
AOPA is strongly opposed to the issuance of this interpretive rule and
believes that it undermines the free flow of information between
pilots and controllers and thus hinders aviation safety. Further, we
are deeply concerned with the legal precedent this sets in having the
FAA overturn NTSB lines of decisions with the simple stroke of the
pen. In our view, this nullifies the airman’s only right of appeal in
the enforcement process.
Status:
AOPA is conducting a careful and thorough legal review of both the
substance of the FAA’s interpretation of the rules as well as the use
of an interpretive rule to overturn case law. On April 15, 1999 AOPA
sent a letter to FAA Administrator Garvey outlining our concerns and
urging the FAA to withdraw the interpretive rule. AOPA is awaiting a
formal response to our letter from the FAA and will continue to
evaluate the legal ramifications of the FAA’s abuse of its discretion
in overturning NTSB case law using the interpretive rule.
Related documents:
FAA 14 CFR Part 91 — Pilot Responsibility for Compliance with Air
Traffic Control Clearances and Instructions (requires Adobe Acrobat
Reader)
AOPA Letter to FAA Administrator Jane Garvey, April 15, 1999
AOPA Press Release 99-2-007, April 16, 1999
991604R1
http://www.aopa.org/whatsnew/newsite.../99-2-007.html
AOPA implores FAA Administrator Garvey to put safety first by
withdrawing readback errors interpretive rule
Apr. 16, 1999 — The Aircraft Owners and Pilots Association is
imploring FAA Administrator Jane Garvey to put safety first and
withdraw an “interpretive rule” that places blame solely on the pilot
for any errors in air traffic control clearance readbacks.
“Fix the problem, not the blame,” said AOPA President Phil Boyer.
“Just as with the ticket program, FAA is sending the message that
enforcement is more important than safety.”
In April, FAA issued an interpretive rule on Federal Aviation
Regulation 91.123 concerning a pilot’s responsibility to understand
and comply with air traffic control clearances and instructions.
The rule, in effect, absolves air traffic personnel from any legal
responsibility to correct misunderstandings between pilot and
controller. Simply put, if a pilot reads back an ATC instruction
incorrectly, the controller has no legal obligation to correct the
error. FAA could then take enforcement action against the pilot for
not complying with ATC instructions.
“This seems contrary to the Administration’s “Safer Skies Initiative”
and joint FAA-industry efforts to improve aviation safety,” Boyer told
Garvey.
Boyer said that pilots and controllers share responsibility for the
safety and integrity of the air traffic control system. There is no
evidence of pilots deliberately mishearing ATC instructions. Clearance
readbacks are part of a checks and balances system that guards against
miscommunication. That system depends on mutual trust between
controllers and pilots.
“But this interpretive rule is a classic Catch-22,” Boyer said. “The
pilot honestly believes he’s doing everything right, but FAA can still
hit him with an enforcement action. This rule will hinder
pilot-controller communication, and that will affect safety.”
Interpretive rule serves FAA legal self-interests, not safety
AOPA said the interpretive rule serves only the self-interests of
FAA’s legal and air traffic divisions.
“FAA’s Flight Standards Division has the expertise to determine how
pilots should comply with regulations and it is the only FAA division
that could even remotely be considered as having pilots’ interests at
heart,” Boyer said. “AOPA can’t find evidence in the rule that Flight
Standards had any significant input.”
FAA trying to overrule NTSB
FAA issued the ruling following several enforcement cases in which the
National Transportation Safety Board (NTSB) ruled against FAA and in
favor of the pilot. AOPA said that FAA was trying to thwart
congressional intent that NTSB have authority to independently review
FAA enforcement actions.
“FAA didn’t like NTSB’s rulings, so FAA changed the rules,” Boyer
said. “That flies in the face of fair and just principles of the law.”
Boyer told Garvey the interpretive rule was an abuse of FAA’s
discretionary authority and “ill conceived on many fronts.”
“Most onerous, it will rupture the cooperative relationship between
pilots and controllers to the detriment of aviation safety. We implore
you to withdraw this interpretive rule.”
A copy of AOPA President Phil Boyer’s letter to FAA Administrator Jane
Garvey is available on AOPA Online at
http://www.aopa.org/whatsnew/regulat...iveletter.html. [See also
AOPA's regulatory brief.]
The 345,000-member Aircraft Owners and Pilots Association is the
world’s largest civil aviation organization. More than one-half of the
nation’s pilots are AOPA members.
99-2-007
Old April 8th 05, 09:38 PM
Steven P. McNicoll
"Larry Dighera" wrote in message
Regulatory Brief
The issue:
by ATC personnel. FAA's new interpretive rule squarely places the
The FAA's issuance of this interpretive rule raises several concerns.
process that do not fit the FAA's desired interpretation. Further,
FAA's general operating and flight rules require pilots to comply with
It has traditionally been the FAA's view that it is the duty of pilots
controller.
FAA does not agree with the NTSB's interpretation and believes this
AOPA position:
pen. In our view, this nullifies the airman's only right of appeal in
Status:
substance of the FAA's interpretation of the rules as well as the use
evaluate the legal ramifications of the FAA's abuse of its discretion
Related documents:
FAA 14 CFR Part 91 - Pilot Responsibility for Compliance with Air
Reader)
991604R1
Apr. 16, 1999 - The Aircraft Owners and Pilots Association is
withdraw an "interpretive rule" that places blame solely on the pilot
"Fix the problem, not the blame," said AOPA President Phil Boyer.
"Just as with the ticket program, FAA is sending the message that
enforcement is more important than safety."
Regulation 91.123 concerning a pilot's responsibility to understand
"This seems contrary to the Administration's "Safer Skies Initiative"
and joint FAA-industry efforts to improve aviation safety," Boyer told
Garvey.
"But this interpretive rule is a classic Catch-22," Boyer said. "The
pilot honestly believes he's doing everything right, but FAA can still
pilot-controller communication, and that will affect safety."
FAA's legal and air traffic divisions.
"FAA's Flight Standards Division has the expertise to determine how
that could even remotely be considered as having pilots' interests at
heart," Boyer said. "AOPA can't find evidence in the rule that Flight
Standards had any significant input."
"FAA didn't like NTSB's rulings, so FAA changed the rules," Boyer
said. "That flies in the face of fair and just principles of the law."
Boyer told Garvey the interpretive rule was an abuse of FAA's
discretionary authority and "ill conceived on many fronts."
"Most onerous, it will rupture the cooperative relationship between
you to withdraw this interpretive rule."
A copy of AOPA President Phil Boyer's letter to FAA Administrator Jane
world's largest civil aviation organization. More than one-half of the
nation's pilots are AOPA members.
99-2-007
I don't think you have a lot to fear (enforcement wise) if you give a full,
but incorrect, readback of an air traffic control transmission when the air
traffic controller, under the circumstances, reasonably should have
corrected your error but did not. Controllers are still required to ensure
that read backs are correct, that has not changed and no change in that
requirement was ever proposed.
From FAA Order 7110.65, "Air Traffic Control"; Chapter 2. GENERAL CONTROL;
Section 4. RADIO AND INTERPHONE COMMUNICATIONS:
2-4-3. PILOT ACKNOWLEDGMENT/READ BACK
a. When issuing clearances or instructions ensure acknowledgment by the
pilot.
NOTE-
Pilots may acknowledge clearances, instructions, or other information by
using "Wilco," "Roger," "Affirmative," or other words or remarks.
REFERENCE-
AIM, Contact Procedures, Para 4-2-3.
b. If altitude, heading, or other items are read back by the pilot, ensure
the read back is correct. If incorrect or incomplete, make corrections as
appropriate.
When this was announced pilots formed opinions on it based solely on what
had been written about the interpretive rule, not on what is actually in the
document.
All the FAA really did was to declare that the act of giving a readback does
not shift full responsibility for readback/hearback errors to Air Traffic
Control and does not insulate pilots from their responsibility under FAR
91.123 and related regulations to listen attentively and to hear accurately
in the first place. That's paraphrased from the Federal Register, the
complete document can be seen at http://www.avweb.com/other/faa9914.pdf
Basically, the FAA felt the NTSB had been inconsistent. The NTSB had
concluded that an air traffic controller's failure to identify and to
correct a
pilot's erroneous readback warranted a mitigation of a regulatory violation.
That is not what the FAA was objecting to. The NTSB had also excused
pilots even when the pilot was the initiating or principal cause of the
miscommunication. Pilots had given partial readbacks of clearances where
the error was in the portion not read back.
The NTSB excused a miscommunication for which the pilot was the initiating
and principal cause. The pilot took a clearance meant for another aircraft
and a loss of separation between two air carrier flights resulted. The NTSB
agreed that the pilot's error caused the miscommunication and that there was
no prior or subsequent air traffic control contribution to the
miscommunication.
But the NTSB excused the pilot's error based on his readback, even though
pilot's readback was blocked by another radio transmission and could not
have
been received, acknowledged, or corrected by ATC.
How can ATC correct a readback that they don't receive? The pilot should
not have complied with the clearance until he received a "readback correct"
(or words to that effect) from ATC. Had the pilot done that in this case
there would have been no loss of separation. There was nothing the
controller could have done differently.
Old April 8th 05, 10:48 PM
HankC
In 2003, I had an interesting experience at a small airport...
I was inbound, 15 miles out, above pattern altitude and descending.
I called the field to get runway in use and wind. He also gave me
altimeter, which I started to dial in, and in and in...
I slowly realized this was not right by a long shot.
I vaguely remembered the previous setting, set it back and put her
down.
Turns out that *someone* had set the field altimeter to field elevation
(600 feet) but had dialed it in BACKWARDS past zero to basically -400
feet! The reading was an historic 'hurricane low' pressure, perhaps
only seen before in Death Valley.
Since then, when changing the altimeter, I announce 'off of 2992 for
HankC
John Harper wrote:
So maybe there really is a geographic aspect to this. It's
true that my instructor taught me to minimize chit chat, and
I do. But really, honestly, in Northern CA where I do most of
my flying I rarely hear them read back, and never do it myself,
and it never seems to cause a problem. Or maybe I just filter
it out when other people do it, I don't know.
(Things that used to drive my instructor mad:
them"
"taxiing into position" - "how else are you going to do it"
etc.....)
John
I automatically read back the altimeter setting when ever given,
whether IFR or VFR. Any time I've forgotten to include it in the
read
back they have given it to me again.
www.rogerhalstead.com
  #28
Old April 9th 05, 12:29 AM
Icebound
"John Harper" wrote in
message news:1112895851.557572@sj-nntpcache-3...
In the UK it is mandatory and they will prompt you if you don't read
it back. I guess Canada operates to the same procedures as the UK.
I realize that I have not completed training yet... but in Canada, under
VFR, my understanding is that pretty much NOTHING needs to be read back
EXCEPT:
....instructions to hold-short (or cross) runways during taxi (must be
specifically itemized in the taxi instructions, and must be read back)
....LAHSO clearances.
....anything else only whenever read-back requested by ATC.
Maybe my training will uncover more, as it progresses, but to date (and from
what I have read), those are the only MANDATORY requirements.
Where I fly (busy satellite within major class C area), you pretty much
never hear an altimeter (or even a landing clearance) read back. Always
acknowledged..., but rarely read back.
  #29
Old April 10th 05, 01:53 PM
Joe Johnson
"Dan Luke" wrote in message
"Michael 182" wrote:
In the US I've never read back an altimeter, I've rarely heard anyone
else do it, and I've never heard anyone questioned for it.
Really - I hear about 9 of 10 altimeters read back every time I fly.
Ditto.
Dan
C172RG at BFM
Me three...
  #30
Old April 12th 05, 04:56 AM
aaronw
On Thu, 07 Apr 2005 15:06:30 -0700, John Harper
etc.....)
I waffle on saying 'identing' when asked to ident. I think nowadays
I've settled on just reading back my tail number when asked for an
ident (with, of course, pushing the button).
aw
how much money have you lost on the lottery? NOW GET THAT MONEY BACK! shane Home Built 0 February 5th 05 07:54 AM
high copper reading in oil analysis [email protected] Owning 1 March 26th 04 03:32 PM
Why not use the F-22 to replace the F/A-18 and F-14? Tony Naval Aviation 290 March 7th 04 07:58 PM
