#111
Jay Honeck wrote:
I was referring specifically to the pages and pages (ad nauseum) of study questions that show you a VOR instrument, totally out of context with anything else, and ask you to determine where you are in relation to the transmitter. So what? Is that difficult for you? Consider that an "easy" question that counts against the finite number they can ask. It could be replaced with a bunch of PITA airspace questions. -- Mortimer Schnerd, RN VE |
#112
![]() "George Patterson" wrote: Consider slow flight. Why do we teach it? According to several of my instructors, we teach it because if you get trapped by deteriorating weather, it's a lot safer to be looking for a good place to land at slow speed than at cruise. Wow, that's a scary pictu a newbie PP stuck in bad weather, flying around with the stall horn blowing. -- Dan "How can an idiot be a policeman? Answer me that!" - Chief Inspector Dreyfus |
#113
Dan Luke wrote:
Wow, that's a scary pictu a newbie PP stuck in bad weather, flying around with the stall horn blowing. Way back in the 30s, some pilots would spin through an overcast and then recover underneath in the clear. Unless the ceiling was 200', that is. Can you imagine? Open cockpit, rain spraying you and there you go into an intentional spin into the merk. Must have had huge balls and tiny brains.... -- Mortimer Schnerd, RN VE |
#114
Jay Honeck wrote:
After I got tired of that and removed the hood, I asked "so, where are we". He laughed and told me that I was supposed to figure it out. So I did. This seems rather useful to me. Why eliminate it? You figured out your position using VORs? What decade was this? ;-) A few years (3? 4?) ago. Did I just use the two VORs or did I use a VOR and DME? I don't recall which, to be honest. The airplace I used for the checkride was, I recall, /A. Who in the world uses VORs for daily flight anymore? Out of the "neighborhood", I do. I know, a lot of you guys do. Despite the fact that you've probably got a Garmin/Lowrance/AvMap on your yoke that is 500 - 1000 times more accurate and intuitive than your old 1953 Narco 12, you feel compelled to "follow the needle" cuz that's what you're used to doing. Actually, GPS was a part of my IR training. It was just annoyingly bad luck that I took the checkride in a /A instead of /G. Fortunately, I'd a good CFII. The /A had an ADF; the /G didn't. Naturally, though, the DE required an NDB approach of me. No problem. If I'd two GPSs, perhaps it would be different. But since I've but one, I track my location with VORs too. I'd like to think I'd do that even with two GPSs. I've the tools in the airplane; it's silly to waste them. It's more to do, but this also means I've some "slack" if I ever grow overloaded (and I'm "exercising" to help avoid that). [...] Which isn't to say that tracking a VOR isn't kind of fun, and (for those of us at the bottom of the aviation food chain) still necessary for IFR flight. But for regular, VFR navigation, VORs have pretty much outlived their usefulness. The planes that are often rented to VFR-only pilots are often as historic as radio ranges, no laugh? [...] In five more years everything will be GPS based, and interpreting a VOR will be like knowing how to gauge your position by listening to two tones in your headset. That's a separate issue. I'm not entirely comfortable with GPS-only, given the ease with which it can be jammed or otherwise impacted. Why not have the new "GPS" units dual capable, perhaps LORAN and GPS? From a user perspective, we'd never see a difference, but it would offer greater resilience. These new units could even use VORs. It's not the navaid so much as the UI, I think, that makes it a big deal. - Andrew |
#115
Jay Honeck wrote:
[...] I was referring specifically to the pages and pages (ad nauseum) of study questions that show you a VOR instrument, totally out of context with anything else, and ask you to determine where you are in relation to the transmitter. I've always thought of that as akin to unusual attitude work. It's practice for something having already gone wrong. First of all, if I'm flying along and the "black box" goes dead, I've been following my position on my sectional -- so I have a pretty good idea where I am from the get-go. Except that the GPS signal has been warped by some weird error in either the signal or your box. You're not where you think you are. Except you weren't flying. You were sleeping in the right seat. The pilot was so shocked that the GPS screen went blank that he fainted, but not before waking you up. Except you're not sure whether you're approaching or past that nearby VOR. - Andrew |
#116
Hilton wrote:
Jay, so what percentage of people fail their knowledge tests?Â*Â*ThenÂ*what percentage of those people failed because of questions you believe shouldn't be there.Â*Â*IÂ*thinkÂ*we'dÂ*beÂ*approachingÂ*0-1%Â*-Â*atÂ*theÂ*most. In defense of this thread, I think you're asking the wrong question (or at least you're missing one of the two questions). While your question is reasonable, the other is "what is the cost of including these questions?" It's not just an increased failure rate. It may also serve to keep people from taking the test in the first place, either because it is "too hard" or because it adds to the time required for the PPL and this passes beyond certain individuals' personal thresholds' for the time they're willing to spend. While VORs are still the main electronic nav in many planes (including rentals), I think that they need to stay on the test. But I would like to see the test simplified *if* it would translate to more pilots. - Andrew |
#117
for daily flight anymore? Those of us who refuse to pay $400/yr "Garmin tax" for data collected and produced at taxpayer expense. Garmin charges $400 per year to keep their databases current? Glad I own an AvMap. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#118
Jay, so what percentage of people fail their knowledge tests? Then what
percentage of those people failed because of questions you believe shouldn't be there. I think we'd be approaching 0-1% - at the most. Irrelevant. The "failed pilots" we should be concerned about are the ones who fail because they are so intimidated by the process that they never even take the test. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#119
recover underneath in the clear. Unless the ceiling was 200', that is. Can you imagine? Open cockpit, rain spraying you and there you go into an intentional spin into the merk. Must have had huge balls and tiny brains.... And appalling short life-spans. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#120
On Fri, 15 Apr 2005 04:37:47 GMT, "Jay Honeck"
wrote in vyH7e.15254$xL4.5745@attbi_s72:: ... to put those kind of questions on the Private written exam is just another way to weed out potential pilots. That's true. The potential pilots it weeds out are those who are incapable of understanding VOR operations. Would you prefer to share the skies with them? Dumbing down the airman training curricula in blind fear of future dwindling numbers in our ranks is a policy about as astute as squandering tens of billions of dollars of tax payers' money waging your daddy's war during a time when our nation's future citizens are being so poorly educated that it's embarrassing if not freighting. Fortunately, it is you, not me, who will have to live in that future America. |
