More wireless in airplanes stuff
Old April 11th 05, 02:45 AM
Nafod40
Default More wireless in airplanes stuff
While reading about Boeing's new 787 Dreamliner in AvLeak, I saw that
they will be piping the entertainment to the seatback displays via
wi-fi (or some other wireless technology) instead of wires. I was
surprised to see that...implies they've wrestled with the EMI issues
pretty thoroughly.
Old April 11th 05, 07:04 PM
Will probably save thousands of pounds of wire. EMI is not a big
problem to tackle if nature of emissions are known.
Gene Seibel
Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html
Because I fly, I envy no one.
Old April 21st 05, 05:13 AM
Don Hammer
I agree with your dad, but if you look at how much circuitry it takes
for a wireless connection to replace a simple length of wire, I don't
think you can say that wireless is less complex.
Matt
Matt,
Trust me, by the time you run a bunch of wires to each seat along with
net hubs etc in a larger aircraft, one wireless router saves a bunch
of weight and cost.
Old April 21st 05, 11:18 AM
Matt Whiting
Matt
Matt,
of weight and cost.
Weight and cost, yes, complexity, no.
Matt
Old April 21st 05, 12:09 PM
Bob
Yes, complexity is higher, but the complexity is at the chip level.
This stuff is getting cheap and it's down to the hobbist level now.
check out http://www.sparkfun.com
As an Aerospace engr I always marveled at the no cell phone use or
other banned electronic devices on aircraft. The amount of testing we
go through to cert a piece of avionics is mind boggling and quite $$$$.
Some of these levels (EMI) would fry you.
Old April 21st 05, 07:42 PM
Don Hammer
Matt
Maybe I don't understand what you are getting at. I put wireless in a
Gulfstream G-550. System was a short wire from the onboard server
(Part of the hight-speed data system) to the wireless hub and and
power to the hub. My other option was wires and jacks to each seat
and the cockpit from a hub. Why is wireless more complex?
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Hidden costs of owning a Glider Doug Snyder Soaring 17 March 16th 05 08:46 PM
SMALLL airplanes.. BllFs6 Home Built 12 May 8th 04 12:48 PM
FS: 1990 Cracker Jack "War Time Airplanes" Minis 6-Card (CJR-3) Set J.R. Sinclair Aviation Marketplace 0 April 12th 04 05:57 AM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 02:54 AM
