Colibri to SeeYou
Old April 19th 05, 09:32 PM
Default Colibri to SeeYou
I'm having a problem trying to download flights from my
Colibri to SeeYou
when I plug my colibri into the laptop the mouse is demobilelized on
the top of the screen. when I get in to seeyou connection wizard it
always freezes with a white screen.
has anyone had this problem? how do you fix it?
Thanks
Devin
Old April 19th 05, 10:32 PM
Knacklappen
Have you tried this solution:
http://www.seeyou.ws/forum/messages/...tml?1084464804
....which incidentally is posted in the "Connection to GPS" section of
the SeeYou forum on the SeeYou homepage. Nudge nudge, wink wink, know
what I mean?
/Reno
Old April 19th 05, 11:29 PM
I just tried that now but it still does not work, however, when I press
the center button on the colibri and the "waiting connect" display
comes up on the lcd, it allows my mouse (touch pad) to be operational
any other hints
Devin
Old April 20th 05, 03:37 AM
Philip Eldridge
If you are using Activesync on your laptop, try disabling that. I had a
similar problem once and that fixed it. If you aren't using Activesync, I've
got no idea!
Phil
any other hints
Devin
Old April 20th 05, 04:39 AM
nimbusgb
Are you using a USB convertor? What version of windows? Quite often
windows sees the data stream from a serial port as a mouse, your
Colibri has control of your PC! Ah! The joys of 'Plug and Pray'.
The way around this involves dropping into control panel and disabling
the 'phantom' mouse in the device list and differs per versions of
windows.
Ian
Old April 20th 05, 10:33 AM
I am not using a converter. should I be? I'm running windows xp pro on
a dell 600m
devin
Old April 20th 05, 12:29 PM
Bert Willing
I'm also running xp from a dell d600, with SeeYou 2.x (last version before
3.0).
On an earlier 2.y version I had the Colibri sometimes connecting flawlessly,
sometimes not at all and SeeYou hanging up.
Now it seems to connect more often than it does not, but it takes a very
long time to do so.
So far, I could retrieve every single flight I wanted to for the last two
years, but I never knew why...
Bert Willing
ASW20 "TW"
a écrit dans le message de news:
a dell 600m
devin
Old April 20th 05, 09:42 PM
The colibri only beeps at power up. how do I check the IRQ and serial
port setting? lxe would not download thats why I'm using CU
devin
devin
Colibri failures? [email protected] Soaring 3 April 15th 05 12:30 AM
Colibri Ipaq problem! [email protected] Soaring 11 March 2nd 05 04:06 PM
SeeYou MOBILE v2.0! Roy McMaster Soaring 10 July 12th 04 12:25 AM
SeeYou - "Calculate minimum distance to next observation zone" Tom Soaring 2 May 18th 04 02:01 PM
Virtual exploration with SeeYou John Galloway Soaring 3 February 19th 04 10:49 AM
