MOGAS availability database
Old April 27th 05, 04:50 PM
Default MOGAS availability database
Being a Rotax 912s driver, and being as how the Rotax prefers premium
automobile fuel, I have been searching for places that serve automobile gas
that are accessable to airplanes. I'm not having much luck.
So, does anyone know of a database that tracks availability of MOGAS for
aviation use?
thanks,
tom pettit
Old April 27th 05, 05:34 PM
Darrel Toepfer
for aviation use?
You did not specify your region, so I might as well give a shot...
MOGAS maps for German and Austrian airfields can be found at
http://eddh.de/equipment/kniebrett.html
http://airnav.com/fuel/local.html
Just select the fuel of choice:
Jet A, 100LL Avgas, 80/87 Avgas, Mogas (auto)
Old April 27th 05, 08:30 PM
Dave S
Be VERY careful depending on that feature of Airnav. Most of the places
that list "mogas" don't list a price, have irregular or spotty hours of
attendance, or very well may be mom n pop airparks.
If you plan on using these listed fields, CALL AHEAD and confirm. You
very well may just do better refilling with blue stuff when away from home.
I'm going to be running a Mazda Rotary engine in a Velocity, and the
fuel issue is one that I've looked at several times. I plan on using
100LL when fueling out.
Dave
Darrel Toepfer wrote:
for aviation use?
Old April 27th 05, 08:48 PM
Rich S.
"Dave S" wrote in message
k.net...
If you plan on using these listed fields, CALL AHEAD and confirm. You very
I'm going to be running a Mazda Rotary engine in a Velocity, and the fuel
issue is one that I've looked at several times. I plan on using 100LL when
fueling out.
Make that last idea a *must*, Dave. You don't know what you are getting out
of a strange mogas tank. It may be 100° out and that mogas could've been
sitting in the tank since winter. My commandments read:
1. Never use mogas from an unfamiliar source.
2. Always test for alcohol.
3. Never use mogas above 5,000' density altitude.
4. Always check for water.
5. Never use mogas above 80° F.
Remember - 100 LL can foul a spark plug. Mogas can boil, give you vapor
lock, and stop your engine RFN. Which would you prefer? Would you like fries
with that?
Rich S.
Old April 27th 05, 09:40 PM
Hi Tom
I read your post on RAH but cannot post a newsgroup from work so
I'm e-mailing a reply. You might want to post this for others.
http://www.airnav.com
go to this site select "Aviation Fuel"
select" Check local fuel prices"
enter 3 letter airport identifier
select "mogas"(auto)
then click on get local fuel prices
It will give you all airports within 200 miles that have mogas and
price. plus a link to the airport database.
Hope this helps
John Price
for aviation use?
Old April 27th 05, 09:48 PM
Dave S
getting out
with that?
Rich S.
Dude... I'm using mogas because I'm using a MO-engine. I've driven cars
at over 5000 ft (Lake Tahoe.. 9000 ft) MSL.. and in temps over 100* F...
and alcohol wont hurt MY engine because the seals in it and the fuel
system are DESIGNED to use motor gas in all of its domestic
forumulations. I think some of those "absolutes" you are listing are
overkill.
I will be using fuel injected engine with an automotive fuel rail
regulated at 40 PSI over upper deck pressure..through a recirculating
fuel circut with firesleeved hoses. I don't think vapor lock is gonna be
the issue here. I'm just planning on using 100LL because I dont want to
land on a 2000 ft sod strip 40 miles from the nearest town of over
50,000 people. I'm into flying to travel to where the people are
Old April 27th 05, 09:50 PM
Dave S
I listed a cross country flight on airnav, and selected the widest
possible swath.. (like from San Fran to Charleston SC and however
hundred miles wide)
Hi Tom
Hope this helps
John Price
for aviation use?
Old April 27th 05, 10:38 PM
Rich S.
k.net...
Dude... I'm using mogas because I'm using a MO-engine. I've driven cars at
over 5000 ft (Lake Tahoe.. 9000 ft) MSL.. and in temps over 100* F... and
alcohol wont hurt MY engine because the seals in it and the fuel system
are DESIGNED to use motor gas in all of its domestic forumulations. I
think some of those "absolutes" you are listing are overkill.
regulated at 40 PSI over upper deck pressure..through a recirculating fuel
circut with firesleeved hoses. I don't think vapor lock is gonna be the
issue here. I'm just planning on using 100LL because I dont want to land
on a 2000 ft sod strip 40 miles from the nearest town of over 50,000
So? You've a different set of commandments. I just related *mine*. :^)
Rich S.
Old April 27th 05, 10:49 PM
Rich S.
k.net...
out
sitting in the tank since winter. Rich S.
are DESIGNED to use motor gas in all of its domestic formulations. I
Oh - as for the rest of it? Lousy gas can stop that Wankel in it's tracks.
Gas that is not blended for altitude and or season (temperature) can make
the fan stop turning. In your car, you likely bought gas that was intended
for use at Lake Tahoe and/or in temps over 100° F. In your airplane you
might buy mogas at sea level which is designed for sea level. Then you haul
your butt to 10,000' msl and your sea level mogas is merrily bubbling away.
Firesleeves and recirculation only *delay* vapor lock - they don't prevent
it.
You may be safe - for a while. Then maybe. . .not. You have a point - stay
close to roads and civilization.
Rich "Never say 'all'" S.
George Graham ----Garmin 95XL database Bill Zaleski General Aviation 2 April 28th 11 10:14 PM
Problem with Lowrance Database Update? Stuart Grant Piloting 5 December 24th 04 04:16 AM
Simulation Resources Database Tom Allensworth Simulators 2 September 27th 04 02:02 AM
Database update for Foster LRN-500 loran? Ray Andraka Owning 4 September 3rd 03 07:08 PM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 10:32 PM
