Can anybody tell me the numbers to enter in the Cambridge
302 for the Discus A, or where to find these numbers? Thanks. |
You can review the poplars that are available from WinPilot at
http://winpilot.com/Gliders.htm. Go to the bottom of the page and select "Polars". This list was created by Carl Herold. I hope that helps. Charlie |
This isn't everything you need, but there is a WinPilot polar file you
can get for the Discus A at http://www.winpilot.com/polar.asp. Unfortunately, different manufacturers like to ask for polars in different ways. My LX5000 wants the polar's (a,b,c) coefficients and min and max wing loadings. Cambridge wants (1) best L/D, (2) wing area in sq meter, (3) best L/D speed in kph, (4) dry weight in kg, (5) speed at 2 m/s sink in kph, and (6) ballast capacity in liters. You can get some of that from your glider's manual. What's the difference between the Discus and the Discus A? SeeYou (my 3.1 version anyway) has polars for "Discus" and "Discus 2". I derived the C-302 polar numbers by plugging the SeeYou polar numbers for H304CZ into LXe's Polar tool to get a graph of the polar. From that I read off the numbers for best L/D speed and speed at 2 m/s sink. I can do that for you, if "Discus" and "Discus A" have the same polar. -ted/2NO |
Something I forgot to add: the Cambridge 302 utility has a "From File"
button that looks for files of type "Polar Files (*.plr)". Do not confuse those with WinPilot .plr files, they have completely different formats. |
That's my problem. I can get all these different numbers
but they are not the ones that I need for the Cambridge. I can get SeeYou polars too. The Discus or Discus 2 come with 2 different fuselages: A and B. |
Serge Serfaty wrote:
That's my problem. I can get all these different numbers but they are not the ones that I need for the Cambridge. I can get SeeYou polars too. The Discus or Discus 2 come with 2 different fuselages: A and B. You may wish to give some consider that any polar coefficient numbers you obtain are, at best, simply an approximate curve fit to numbers measured off of one particular clean glider on one particular day, that flight computers use these approximate numbers to calculate a further approximation for speed to fly, and that the real world difference in performance between an A and B model Discus is quite likely smaller than errors inherent in these approximations. Use some middle of the road B polar numbers, the result will be close enough to reality of the day to day performance of your ship... Marc |
Marc
I am totaly aware of that but I don't have these numbers. Do you know them? |
The CAI numbers for the Discus A as per R. Johnson.
Wing loading 32kg/m^2 42.5 @ 98km/h V 2 163km You will have to make adjustment for your wing loading I hope this will help. Udo "Serge Serfaty" wrote in message ... That's my problem. I can get all these different numbers but they are not the ones that I need for the Cambridge. I can get SeeYou polars too. The Discus or Discus 2 come with 2 different fuselages: A and B. |
At 15:00 27 April 2005, Udo Rumpf wrote:
The CAI numbers for the Discus A as per R. Johnson. Wing loading 32kg/m^2 42.5 @ 98km/h V 2 163km You will have to make adjustment for your wing loading I hope this will help. Udo Thanks Udo, The Cambridge requires the wing area. Do you know that number by any chance? |
Commercial polar routes? | General Aviation | 6 | January 28th 05 08:03 PM | |
Stemme S10-VT Polar | Catherine Conway | Soaring | 2 | December 21st 04 05:17 PM |
For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 05:18 AM |
1930s Navy side numbers. | JDupre5762 | Naval Aviation | 3 | September 24th 03 07:51 PM |
Is anyone still interested in CuSoft "Polar Explorer" program for PC? | Branko Stojkovic | Soaring | 1 | July 26th 03 01:06 AM |
