MOGAS availability database
Old April 29th 05, 04:39 AM
Dave Stadt
"Trent Moorehead" wrote in message
"Rich S." wrote in message
Gas that is not blended for altitude and or season (temperature) can
make
the fan stop turning. In your car, you likely bought gas that was
intended
for use at Lake Tahoe and/or in temps over 100° F.
That's silly. We have driven a Suburban, with its 42 gallon tank, all
over
the US, including Lake Tahoe. We bought the fuel we rode into Tahoe on
at
least 500 miles away, not far above sea level, in the desert. Many
times,
fuel purchased in one locale took us right into a place with completely
different characteristics (altitude, temperature, whatever).
Formulations aside, my big concern with buying mogas from a podunk airport
tank is that the gas could be old and contaminated. This would be due to
small number of planes that are actually set up to burn mogas. With 100LL,
you can feel a bit more assured that the fuel has a had a decent
"turnover"
rate and the fuel is fresher and cleaner.
-Trent
PP-ASEL
More engines are mogas capable than those that need 100LL. If 100LL were to
disappear the vast majority of the fleet would get along just fine on mogas.
In fact the majority of the fleet is much better off burning mogas.
  #32
Old April 29th 05, 04:41 AM
Jay Honeck
The ONLY time I've EVER had engine trouble has been while operating with
100
LL -- which has far more lead in it than my engine was designed to run
on.
Just how much do you think "too much" is?
80 octane avgas -- which my engine was designed to use -- had roughly 25%
(?) of the lead 100 "low lead" (ha!) has in it today.
Which explains why I have to mercilessly lean my engine when running 100LL
avgas to prevent spark plug fouling.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #33
Old April 29th 05, 04:42 AM
Dave Stadt
"Morgans" wrote in message
news
"Blueskies" wrote
Ok, fuel is 6 lbs/gallon, and the quote says there is 6 lbs of lead in a
gallon...what????
Ahh, grasshopper, read it very carefully, again. There is great truth in
the details, and relationships of the part, and the whole. g
Jim (wise teacher) in NC
Extremely poorly worded sentence. It has multiple meanings.
  #34
Matt Barrow
"Blueskies" wrote in message
"Matt Barrow" wrote in message
April 27, 2002
Pelican's Perch #55:
Lead in the Hogwash
When 100/130 was the standard, the mix
limit was four grams of lead per gallon, but in reality the actual
blends
were around 2.7, for the same reasons. (There are about 6.0 pounds, or
about
2,721 grams in a gallon of 100LL, so the lead is less than 0.0735%, by
weight.)"
http://www.avweb.com/news/columns/182149-1.html
gallon...what????
100/130 is four grams of lead per gallon (actually 2.7) and there are 2721
grams in a gallon.
Read it again and this time pause at the "(". :~)
  #35
Old April 29th 05, 04:45 AM
Matt Barrow
news
a
gallon...what????
in
Ok, I suppose it can be read that way also...
"When 100/130 was the standard, the mix limit was four grams of lead per
gallon, but in reality the actual blends were
around 2.7, for the same reasons. (There are about 6.0 pounds, or about
less than 0.0735%, by weight.)"
I don't think I have never heard of weight being 'in' something, a better
read would be something like a gallon weighs 6
lbs, or about 2,721 grams, so...
(Sigh)
Dan (with 185 pounds in him) D.
Would an English Lit teacher be able to break down the lead content ratios?
  #36
Old April 29th 05, 05:17 AM
Matt Barrow
"Dave Stadt" wrote in message
to
mogas.
You probably already know, but that 25% that needs 100LL is the bunch that
flies 75% (or so) of the hours each year.
  #37
Old April 29th 05, 05:18 AM
Matt Barrow
news
a
gallon...what????
in
Only when taken out of context of the previous sentence
  #38
Old April 29th 05, 05:47 AM
Dave Stadt
were
to
mogas.
I would need to see something to support that. The 100LLers are the high
performance engines which in my experience sit in the hangar. Given, on
those few occasions when they do venture out they burn a lot of gas.
  #39
Old April 29th 05, 12:14 PM
Morgans
No doubt, it could have been written more clearly.
Jim in NC
  #40
Old April 29th 05, 01:02 PM
Jay Honeck
Agreed -- although offsetting that are the air charters that fly many hours
on end. I believe they are skewing the numbers dramatically.
At my field, private twins and truly high performance birds rarely leave
their hangars. What we see flying all day long, day in and day out, are the
C-150s and Cherokee 140s -- both of which could be (and possibly already
are) running on mogas.
Jay Honeck
Iowa City, IA
Pathfinder N56993
MOGAS availability database [email protected] Home Built 54 May 9th 05 12:02 AM
Problem with Lowrance Database Update? Stuart Grant Piloting 5 December 24th 04 03:16 AM
Simulation Resources Database Tom Allensworth Simulators 2 September 27th 04 01:02 AM
Database update for Foster LRN-500 loran? Ray Andraka Owning 4 September 3rd 03 06:08 PM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
