"Richard Kaplan" wrote in message ... If my plane had nothing but GPS-based avionics, what would my options be? Vectors. |
In a previous article, "Richard Kaplan" said:
exists due to military testing or some atmospheric irregularity or whatever, but the point is that the NOTAM really is out there and will be effective in a few days. If my plane had nothing but GPS-based avionics, what would my options be? GPS 07/015 ZDC GPS UNRELIABLE WITHIN A 100 NM RADIUS OF PATUXENT VORTAC (PXT) AT 10,000 MSL THROUGH FL400, AND DECREASING IN AREA WITH DECREASE IN ALTITUDE TO 80 NM RADIUS AT 4000 FT AGL 1200-2000 DLY WEF 0307211200-0307252000 Stay away from Patuxent? -- Paul Tomblin , not speaking for anybody UNIX was half a billion (500000000) seconds old on Tue Nov 5 00:53:20 1985 GMT (measuring since the time(2) epoch). -- Andy Tannenbaum |
Is this the groundhog day location? Maybe GPS don't like groundhogs rooting
around? GPS 07/015 ZDC GPS UNRELIABLE WITHIN A 100 NM RADIUS OF PATUXENT VORTAC (PXT) AT 10,000 MSL THROUGH FL400, AND DECREASING IN AREA WITH DECREASE IN ALTITUDE TO 80 NM RADIUS AT 4000 FT AGL 1200-2000 DLY WEF 0307211200-0307252000 -- Richard Kaplan, CFII www.flyimc.com |
Doesn't leave you any out should comm go down. I've had that
happen due to P-static, ice on the antenna, and problems with the radio in a rental. Robert Henry wrote: "Richard Kaplan" wrote in message ... If my plane had nothing but GPS-based avionics, what would my options be? Vectors. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Richard Kaplan wrote: The recent thread regarding GPS as the sole navaid sometime in the future has focused on terrorism as the "what if" scenario. I am not focusing specifically on terrorism in my concern the need for GPS redundancy; I am simply observing that there is no system or device I am aware of anywhere in aviation which works 100% of the time, so certainly it is always worh having a backup. Even if GPS has 12 satellites, it seems clear by common sense that the best backup system would use a technology different from GPS. With that as background, look at the following NOTAM, which is currently available on DUAT. We can theorize all we want about whether this NOTAM exists due to military testing or some atmospheric irregularity or whatever, but the point is that the NOTAM really is out there and will be effective in a few days. If my plane had nothing but GPS-based avionics, what would my options be? GPS 07/015 ZDC GPS UNRELIABLE WITHIN A 100 NM RADIUS OF PATUXENT VORTAC (PXT) AT 10,000 MSL THROUGH FL400, AND DECREASING IN AREA WITH DECREASE IN ALTITUDE TO 80 NM RADIUS AT 4000 FT AGL 1200-2000 DLY WEF 0307211200-0307252000 Again, there are toy airplanes then there are real airplanes. All high-end jets have triple IRUs feeding position to the FMS and LNAV. So, if the primary nav sensor shoots craps around Podunk, Merrykanasa, you just coast along using triple-mized inertial position until the GPS kicks back in. |
options be? Vectors. Ray Andraka wrote: Doesn't leave you any out should comm go down. I've had that happen due to P-static, ice on the antenna, and problems with the radio in a rental. Now you're theorizing about a simultaneous double system failure -- GPS and communications. It's impossible, just extremely unlikely. You can keep adding redundency to get the probability of incapacitation as low as you want, but eventually an event will happen which will take out all of your backups at the same time. What's the odds of a DC-10 having all three hydraulic system fail at the same time? They said it was impossible, yet it happened (Souix City, uncontained failure of a turbine disk). By far the most likely cause of simultaneous GPS and COMM failure is loss of ship's electrical power. It would take out your VOR, ILS, Loran, too. The way to protect against that is multiple electrical busses (like in twins), or battery backup and/or handheld devices. |
I wrote:
It's impossible, just extremely unlikely. Obviously, that's a typo. It should read "It's NOT impossible". |
"Ray Andraka" wrote in message ... Doesn't leave you any out should comm go down. I've had that happen due to P-static, ice on the antenna, and problems with the radio in a rental. Dial in last good frequency or 121.5 on the handheld. |
"Roy Smith" wrote in message ... You can keep adding redundency to get the probability of incapacitation as low as you want, but eventually an event will happen which will take Even assuming ATC has the manpower and frequency bandwidth to simultaneously give vectors to all airplanes in an area of GPS outage, do we land nowhere but runways with ASR approaches when it is IMC in that region until the GPS service is resolved? And if we want to take off with a void clearance, do we just consider airports without radar coverage down to the surface to be unusable during IMC since there would be no navigation system available on takeoff? Or maybe we just go by dead reckoning on takeoff? What happens if there is a need for an emergency medical aircraft in a region where GPS is out of service and no radar coverage is available? Central Pensylvania east of Johnstown is just one excellent example --- there is a pretty significantly sized area where there is no radar coverage available for apporches, so I suppose if sole-nav GPS went out of service in the region all the airports would just become VFR-only. Clearly this situation is absurd, and for that reason we cannot and never will switch to GPS-only navigation. Maybe there will be fewer but strategically placed VORs and ILS systems but clearly there always must and will remain some backup system besides just GPS. -- Richard Kaplan, CFII www.flyimc.com |
| Thread Tools | |
| Display Modes | |
