Ham radio integrated into the comm configuration
Old May 2nd 05, 02:09 AM
Default Ham radio integrated into the comm configuration
Want to combine my hobbies as I acquire a C-172 - has anyone mounted a
ham radio in their bird and wired it through the comm panel?
Problems?
Successes?
Don
Old May 2nd 05, 03:35 AM
Mike W.
Would that be legal, with the FCC? That's an awfully tall antenna mast!
Hello, my name is Mike, and I am an airplane addict....
Problems?
Successes?
Don
Old May 2nd 05, 04:07 AM
The FCC doesn't care, it is the FAA hoops that are a pain in the ass.
Jim Pennino
Remove .spam.sux to reply.
Old May 2nd 05, 04:09 AM
George Patterson
Aircraft that used these frequencies usually streamed a wire antenna behind the
plane.
George Patterson
There's plenty of room for all of God's creatures. Right next to the
mashed potatoes.
Old May 2nd 05, 04:23 AM
plane.
George Patterson
mashed potatoes.
The ham bands go to 250 GHz; how long would that wire be?
Jim Pennino
Old May 2nd 05, 04:24 AM
Javier Henderson
" writes:
Yes, installed it myself, signed off by my A&P, who is a frequent
contributor to this group. I wired it as COM3 on my audio panel (a
King KMA28), works great. I installed an Icom IC207H, which covers
both 2m and 70cm, and I use a Comant commercial VHF antenna for 2m (it
covers 136 MHz to 174 MHz), and an aviation radiotelephone antenna for
70cm (it covers 450 MHz to 500 MHz, as I recall). Both are available
from the usual suspects (I got mine at Chief Aircraft, I think).
Problems?
None.
Successes?
Many. From 8500', the range with 50W is amazing.
-jav, w6vms
Old May 2nd 05, 04:47 AM
You can do this easily with the little plug in antenna adapter that
King makes.
(It's just a 3 circuit phone jack, actually)
Even tho a com antenna is a pretty bad mismatch on 2m, you can kerchunk
at least a hundred repeaters at a whack from 10K feet over Indiana.
Bill Hale K0QA
Old May 2nd 05, 05:13 AM
You might check with John Price -- he has one of the old L planes and is trying
to get the radio gear working. He says he can use it as a ham operator. IIRC
from "Fate is the Hunter", the antennae used there were about 250' long. John's
site is
http://home.att.net/~jm.price .
That's a 1/2 wave at the lowest ham band which starts at 1.8 MHz.
The majority of airborn ham HF operations run between 14 MHz to 30 MHz,
i.e. the 20 to 10 meter bands, where the antennas are a bit more reasonable.
A slightly loaded ADF antenna works just fine at those frequencies.
In the olden days, there were motorized reels to deploy long wire
antennas during cruise and reel them back in before landing.
Actually, not so olden, as I remember seeing them on 727s that were
HF equiped in the early 80s.
Jim Pennino
Old May 2nd 05, 02:37 PM
Newps
About an inch.
(sorta OT) Free Ham Radio Course RST Engineering Piloting 43 January 24th 05 08:05 PM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 10:57 PM
Comm 1 Radio Sim Software Sim Man Simulators 1 November 24th 03 08:04 PM
Comm 1 Radio Simulator Software Sim Man Simulators 0 November 16th 03 11:03 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
