Aluminized fiberglass
Old May 2nd 05, 10:42 AM
Dan, U.S. Air Force, retired
Default Aluminized fiberglass
I have come across a small amount of aluminized fiberglass. Any idea
what it would be used for?
I'm just going to be using it for some nonstructural widgits and it was
free.
Old May 2nd 05, 07:23 PM
Richard Riley wrote:
On Mon, 02 May 2005 04:42:04 -0500, "Dan, U.S. Air Force, retired"
:I have come across a small amount of aluminized fiberglass. Any idea
:what it would be used for?
:I'm just going to be using it for some nonstructural widgits and it was
:free.
1) Making a structure that will survive lightning strikes. Assuming
you also have conductive paint, are ready to electrically bond each
piece to it's neighbor, and don't care if the resin adheres very well
to the aluminum.
2) Make a composite Faraday cage. Same issues.
Is it treated as the non aluminized stuff in terms of using it?
Old May 3rd 05, 08:35 AM
On Mon, 02 May 2005 13:23:46 -0500, "Dan, U.S. Air Force, retired"
:Is it treated as the non aluminized stuff in terms of using it?
Yes. You end up with the resin encapsulating the fibers instead of
actually bonding to them. So anything you build out of it will be
very weak, compared to the same structure without the aluminum on the
glass.
But if it's a non-structural doodad, just wet it out and let it set.
Terrific, thanks.
Fiberglass / Mold release advice requested Mark Zivley Home Built 10 April 2nd 04 11:15 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
Fiberglass Tip Tanks Question Jay Honeck Owning 7 September 26th 03 04:23 AM
