Need a 2nd nav with GNS 430?
Old May 4th 05, 03:05 AM
Paul Folbrecht
Default Need a 2nd nav with GNS 430?
I am doing some preliminary planning of the panel for my RV-9A and
wondering if a 2nd nav is really a necessity with a GNS 430 in the
panel. Seems to me that flying IFR GPS, with mostly GPS approaches in
the near future, I should not have much need for a 2nd VOR receiver to
identify intersections - obviously the GPS does that itself and the 430
does have one nav radio built-in.
Only problematic area I can think of are the cases where 2 VOR receivers
are pretty much necessary - to identify FAFs on ILS, LOC, and VOR (no
GPS overlay) approaches. I release that ILS's almost always have an OM
anyway and VOR IAPs w/no GPS overlay become scarcer by the month. With
WAAS.. much less of a problem all around (WAAS precision approaches).
If I decide I can do without another nav I save $2000 going with a SL-40
(com only) vs a SL-30 (nav/com).
Interesting in hearing from people with 430s (and up) how they are
flying the things.
(As for navigating with the 430 tango uniform - there's ATC vectors &
the backup handheld GPS.)
Old May 4th 05, 03:47 AM
Roy Smith
In theory, you can fly all day with just the single GPS/NAV/COM. Just keep
going waypoint to waypoint to waypoint, with maybe an ILS approach at the
end, and some vectors thrown in.
But, there are still a couple of reasons you want a second NAV receiver.
1) If #1 goes TU, you're not SOL (ok, you covered that below).
2) Sometimes it's just plain easier to use the #2 NAV. You're in the
middle of programming an approach on the GPS when the guy says, "Fly direct
FOO VOR and hold". You could go direct FOO on the GPS, but it's often more
convenient to use the #2 NAV for something like that so you don't have to
interrupt what you're doing on the GPS.
flying the things.
Most of my club's planes are equipped with a CNX-80/GNS-480 and an SL-30.
If not an SL-30, then some other kind of NAV/COM. I find I do most of my
flying with the #1 radio, but I still wouldn't want to be without the #2.
I set them both up on an ILS. I'll use the #2 NAV to quickly get going in
the right direction, when the GPS is tied up programming something
complicated that I don't want to interrupt.
How about a clearance like this... "Depart Carmel on the 270 radial to
intercept the Sparta 030 radial, then direct Sparta". That's a real
clearance that you sometimes get out of HPN (I'm guessing on the exact
radials). That's a tough one to execute with just the single GPS. It's
probably not impossible, but having the 2nd nav sure makes it simplier.
The bottom line is you can probably get away without the #2 NAV. I
wouldn't want to, but it's not my $2k we're talking about spending :-)
Old May 4th 05, 04:15 AM
Mike Rapoport
You might want to consider a 530 instead of a 430. On the 530 you can opt
to show the distance and radial from whatever VOR is tuned. This basically
lets you show two waypoints (one VOR and one GPS) at a time. You can even
have the VOR output to an indicator if the indicator will take composite
input (while in GPS mode). I think that the 430 will also output a
composite signal (VOR (or LOC). The advantage of the 530 is that it gives
you distance and doesn't require another indicator.
Mike
MU-2
"Paul Folbrecht" wrote in message
wondering if a 2nd nav is really a necessity with a GNS 430 in the panel.
Seems to me that flying IFR GPS, with mostly GPS approaches in the near
future, I should not have much need for a 2nd VOR receiver to identify
intersections - obviously the GPS does that itself and the 430 does have
are pretty much necessary - to identify FAFs on ILS, LOC, and VOR (no GPS
overlay) approaches. I release that ILS's almost always have an OM anyway
and VOR IAPs w/no GPS overlay become scarcer by the month. With WAAS..
Interesting in hearing from people with 430s (and up) how they are flying
the things.
(As for navigating with the 430 tango uniform - there's ATC vectors & the
Old May 4th 05, 04:30 AM
Paul Folbrecht
Points taken. Thanks for the feedback. I'm now learning how to use a
430 (in a 172 RG I'm using for my complex endorsement) but not all this
stuff is clear yet.
I know it's only $2K, but my panel is over $20K as it is, equipment only
(building the panel is the only part of my aircraft, other than painting
it, that I don't plan to do myself). I am looking to save a bit here
and there. I had wanted to keep it to $25K ready to install.
On a related note, here's a great reason to fly a kitplane:
http://www.grtavionics.com/efis_horizond_series_1.htm
flying the things.
Old May 4th 05, 04:32 AM
Paul Folbrecht
530 is out of my price range.
The 430 does output a composite signal. An indicator is not needed with
the GRT EFIS - it talks to the 430 very nicely.
Mike
MU-2
Old May 4th 05, 04:35 AM
G. Sylvester
The standard route from SQL to STS is 'RV SAU SAU R-330 STS R-141 COATI
Direct" To do that on a G430 + 2nd nav is not difficult. The easier
way is to know that SAU R-330 STS R-141 is also known as BURDE. I don't
know they don't use that intersection by name. Anyway, knowing it is
BURDE makes the GPS use a snap. I guess my point is, check out the DP
and IAP and maybe that clearance becomes easy with a single GPS.
Gerald
Old May 4th 05, 11:47 AM
Brad Salai
How do your members like the 480? Our club is going to upgrade three of our
airplanes with IFR gps's. Our maintenance officer is a big fan of the 430,
but some members want bigger units and are looking at the 530. The rational
for staying away from the 480 varies, but includes:
Harder to use,
Garmin may discontinue it,
Don't like soft keys ,
430/530 installed base is much bigger, therefore, guarenteed to be around,
Cheaper initially, and don't need waas now, so why pay for it.
I'd be interested in your opinion, having flown with the 480.
Brad
"Roy Smith" wrote in message
keep
direct
more
flying the things.
Old May 4th 05, 12:52 PM
Roy Smith
Harder to use,
We're happy with the 480 (otherwise we wouldn't have bought 6 of them). I
don't have that much time with the 430, but from what I can see, it's a
nice unit too.
There is no doubt that there's a learning curve to the 480, but once you've
learned it, it's great. As far as screen size goes, bigger is better.
As for discontinuing it, nobody really knows what Garmin's plans are. I've
heard rumors that they're going to discontinue the 480, and I've also heard
rumors that they're going to discontinue the 430. At this point, it's all
just rumors. If you can pin a Garmin rep down to making a definitive
statement one way or the other, please let me know!
Old May 4th 05, 01:15 PM
Jose
Don't put all your eggs in one box.
1: the display fails, you're toast. HYBT
2: RAIM error in IMC is also inconvenient. BTDT
3: if you can't update the database (such as you're in the middle of a
trip during the window) you can't do IMC anymore. BTDT - at Sun'n'Fun,
no less.
4: you're in some bumpy clouds, reach over to switch off the strobes or
switch on the pitot heat or something, and a bump causes you to hit the
master. Oops - flip it back on. VORs come right back. NAV comes right
back. ADF comes right back. DME comes right back. GPS begins to
acquire satellites, do its self test, and waits for you to push the
lawyer button before continuing. Meanwhile, you're doing 150 knots in
the soup and just got an amended clearance. BTDT
5: New clearances are often easier to dial into a VOR to start with, so
while you push the GPS buttons you're at least flying the clearance. BTDT
6: If you have an electrical failure in IMC, you may need to decide
what units to leave on the battery and what units to shut off. I don't
know the 430's current draw; you may be better off with just a single
VOR in some cases (though I wouldn't be surprised if the old VOR
receivers draw more than the new GPSs). BTDT, though without the 430.
That's just a start.
Jose
(r.a.h retained, though I don't follow that group)
Get high on gasoline: fly an airplane.
Old May 4th 05, 02:39 PM
paul kgyy
Put in a used KX125 as backup. I use it for atis/awos and monthly VOR
integrity checks.
Another option: purchase a portable GPS and portable comm to use as
backup. Only catch here is the difficulty of doing approaches.
