Welding...
Old May 6th 05, 04:15 AM
Akron
Default Welding...
When welding, say, a strap across a variety of thicknesses, for example a
tube, then a weld then a cluster wiht a lot of welds, I find it neccesary
to stop the weld and change tips.
is this acceptable practice?
Old May 6th 05, 02:05 PM
Corky Scott
Yes, it's what you are supposed to do. Different thicknesses of metal
require different amounts of heat concentration. Thick metal requires
a LOT more heat than thin metal.
When I welded the wing mounting brackets to my Christavia, the bracket
was made of eigth inch steel. I also had to weld inside corners,
which takes a LOT more heat than welding outside corners. I ended up
using the cutting tip to get enough heat to make the puddle work
properly. The cutting tip without pushing the oxygen lever of course.
Hint from EAA's welding video: "if you adjust your flame properly and
hold it the correct distance from the material and cannot create a
puddle within 10 seconds, you don't have enough heat."
Corky Scott
Rivets vs Welding David Findlay Home Built 15 January 3rd 05 12:55 PM
AC 43.13, welding and a hip-check Michael Horowitz Owning 2 June 27th 04 08:09 PM
TIG welding video? Russell Duffy Home Built 3 October 6th 03 06:55 AM
Welding techniques for 4130? Building The Perfect Beast Home Built 29 September 4th 03 09:52 PM
welding rod Del Rawlins Home Built 0 July 15th 03 12:21 PM
