When to acknowledge ATC
Old May 6th 05, 07:59 PM
Frank
Andrew wrote:
ATC says "radar contact, 20 miles south of XYZ, proceed on course". Do
you acknowledge this transmission? How about when ATC says "altimeter
setting 2992" on your first contact after a handoff? Does this require
acknowledgement?
In the past, I've acknowledged such things if the controller was not
busy. But I've heard all kinds. Some people read back the altimeter
setting. I've even heard people reading back the "radar contact"
message. I feel that this is a waste of bandwidth. However, I don't
know what ATC prefers. Do they want read back for everything, or should
we shut up as much as possible?
I don't read back "ident" instructions, I just press the button. I
acknowledge everything else. Things like altimeter and such I just use the
(shortened) tail number. Anything that's an instruction I read back.
Frank....H
  #42
Old May 6th 05, 08:12 PM
Steven P. McNicoll
"A Guy Called Tyketto" wrote in message
m...
If ATC tells you to remain outside a certain class airspace,
you must read that back and remain outside that airspace until he
clears you into it.
If ATC tells you to remain outside you have to remain outside, whay
requires you to read it back?
RADAR CONTACT is not required. Altimeter setting is not required.
Readback is not required. You know he hears you because he responded
to your radio call with your call sign. I'm having a hard time
following your argument.
Actually, for Class B, it does. AIM 3-2-3.d.2 and 3-2-3.e back that:
3-2-3.e: ATC Clearances and Separation. An ATC clearance is
required to enter and operate within Class B airspace. VFR
pilots are provided sequencing and separation from other
aircraft while operating within Class B airspace.
For Class C, AIM 3-2-4.3 states that 2-way comms must be
established, and that is the clearance into/through Class C. But, if
ATC tells you to remain outside of it, you *MUST* remain outside of it
until told otherwise. Plus, a readback of that would be required.
Where's the requirement for radar contact? Where's the requirement for a
readback?
  #43
Old May 6th 05, 08:28 PM
but ATC's actual notification of 'remain
outside Class x airspace' (where x is B, or C) overrides your clearance
into that airspace. You will need to remain outside that airspace until
told otherwise.
Wouldn't it also apply to Class D airspace?
Mike Flyin'8
PP-ASEL
Temecula, CA
http://flying.4alexanders.com
  #44
Old May 6th 05, 08:39 PM
John Galban
Happy Dog wrote:
snip
Where do you fly where ATC doesn't give you the
setting on initial contact?
Almost every class B, C or D airport that I fly into. If on my
initial call, I give them the proper ATIS code (and the setting hasn't
changed). They have no reason to tell me (and everyone else) the
altimeter setting on initial contact. That's why ATIS was invented.
It reduces frequency congestion.
  #45
Old May 6th 05, 10:00 PM
Icebound
"R.L." wrote:
[snip] I'd just say ROGER, thanks.
My first instructor, when teaching me the radios, said: "DO *NOT* say
'Roger!'" Maybe it was just her pet peeve, but she insisted that it was
more professional to acknowledge with your tail number vs. saying
"Roger" ... i.e., "95B, thanks".
"Roger" is definitely more professional than "Thanks". Now THAT is truly a
waste of bandwidth. Any "aviation-communication" text that I have ever
read, discourages the use of "thanks" or "thank you" etc... as being totally
redundant and useless...
If you do not intend to say "roger", then just say "niner fife bravo" and
nothing more.
  #46
Old May 6th 05, 10:23 PM
Icebound
"A Lieberman" wrote in message
What I wonder is, is it better to say your tail number first or after your
acknowledgement or read back of instructions. I tend to flip flop.
Technically, you are shortcutting:
"xyz tower, this is whatever-type ... four three lima. Roger, here is my
readback of your instructions"
you throw out the "xyx tower, this is whatever-type ...", but your tail
number is still left in, so it is now first, as in: "four three lima....
roger, two niner, niner two."
Unfortunately, if we do not include the "roger", then "four three lima....
two niner niner two" seems clumsy and that's when we flip-flop to "two niner
niner two.... four three lima" as being somehow more natural.
But I still prefer...: "four three lima.... roger, two niner niner two" as
the most natural of all.
Of course, VFR, I would never read back anything except
runway-hold-short-or-cross instructions, unless specifically requested to do
so.... so it would only be the acknowledgement: "four three lima".
  #47
Old May 6th 05, 11:07 PM
Happy Dog
"John Galban" wrote in
So you're speaking almost exclusively about towers? That I can see. If the
ATIS is good, no need for the altimeter setting. Other than towers, you
should almost always be getting a setting on initial contact.
moo
  #48
Old May 6th 05, 11:36 PM
Ron Natalie
A Guy Called Tyketto wrote:
No clearance is required.
For Class C airspace, 2-way communication is the clearance into
that airspace. No, ATC doesn't ahve to 'clear' you into it, but the
communication is the clearance as is.
No clearance is required. Do you know what CLEARANCE means?
I don't have to read back anything.
clears you into it
You will not EVER get a VFR clearance into class C or D airspace.
What on earth does that passage have to do with anything? Radar
contact is NOT required, Altimeter settings are not required, Readbacks
are not required. A clearance is required.
It says nothing about clearances. You're making things up again.
  #49
Old May 6th 05, 11:37 PM
Ron Natalie
told otherwise.
Wouldn't it also apply to any airspace. If ATC tells me to stay clear
of the town of Pinkneyville, I'm inclined to oblige (though I may ask
them later when I'm on the ground).
  #50
Old May 6th 05, 11:46 PM
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
m...
clears you into it.
Because if you don't read it back, they have no way to know
that you have acknowledged their call to you. Would you want ATC to
keep repeating the same call to you, adding more radio congestion to a
frequency they are already busy on? If they're trying to provide
separation that your jaunt through their airspace could jeopardize,
they're bloody well are goign to look for hearing a readback from you
on it, and make sure that you are still outside their airspace.
readback?
For class C, they will always tell you 'radar contact
location, say altitude'. Class B, they'll tell you 'radar contact
location, cleared through/into xxx Class B airspace' along with an
altimeter setting for the major airport in their area. That is a
requirement for ATC to give you when entering Class B or C airspace.
See the 7110.65, sections 5-3-1 through 5-3-6. There's the requirement.
If they tell you to remain outside a given airspace, you had best
readback that you are remaining outside that airspace. 7-9-2 gives
leeway for the readback.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.sbcglobal.net/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (GNU/Linux)
iD8DBQFCe/PGyBkZmuMZ8L8RAgXEAKDRqFO8uFqW9JnKp9islutOlzKfIACg n7i8
9Yt/ya39wYpK1n3Jypc1j0E=
=PIJy
-----END PGP SIGNATURE-----
What F-102 units were called up for Viet Nam Tarver Engineering Military Aviation 101 March 5th 06 03:13 AM
