ILS or LOC approach?
Old May 8th 05, 10:43 AM
YKM (Yakama, Washington) RWY 27
BFI (Boeing Field, Seattle) RWY 13R
ACV (Arcata, California) RWY 32
J Haggerty wrote:
Here's an ILS with ILS and Circling minima, but LOC is NA.
This one has the note on the procedure that states "Circling requires
descent on GS to MDA".
http://www.naco.faa.gov/d-tpp/0504/00388ID32.PDF
For May 12th effective date, the link is;
http://www.naco.faa.gov/d-tpp/0505/00388ID32.PDF
Sheridan, WY (KSHR) ILS/DME Rwy 32
JPH
Can you give us some examples?
Stan
On Tue, 03 May 2005 20:04:24 -0500, J Haggerty
There are actually a few ILS procedures that do not have LOC minima.
That would normally be caused by very high obstacles that would keep
the LOC MDA too high, but are not high enough to penetrate the
precision obstacle clearance slope.
Old May 8th 05, 10:26 PM
J Haggerty
The original poster thought that all ILS procedures had LOC minima
available. There are no LOC minima available on that procedure. The
LOC-2 you mentioned is a separate procedure, and not part of the ILS
procedure.
This other example I mentioned is what you were thinking about, an ILS
procedure with no other LOC procedure at the airport.
Sheridan, Wyoming.
Is this an example of what we were talking about?
There is a separate LOC-2 approach for this airport.
That's a separate, stand-alone procedure, not part of the ILS procedure.
Clearance for the ILS approach in that situation could not be construed
as having a clearance for the LOC-2 procedure if the GS failed.
I thought we were discussing situations with an ILS and NO LOC
approach.
Depends on your outlook. For that procedure (ILS) the LOC minimums are
NA. For the other example, there is not even a separate LOC procedure
available.
On Sat, 07 May 2005 22:31:48 -0500, J Haggerty
Found one.
ILS Rwy 16R, Reno, NV (KRNO)
LOC and circling minimums NA.
This isn't the one I was thinking of. The one I was thinking of had ILS
and circling minima, but LOC minima was NA. I'll post that one if I run
across it.
Plate can be viewed at this site;
http://www.naco.faa.gov/d-tpp/0504/00346I16R.PDF
Stan
JPH
Old May 9th 05, 10:11 AM
Peter
So on the SHR ILS/DME 32, the missed approach point for the circling
approach is 1.5 DME from I-SHR. Do you always assume that the last fix
on the profile view is the MAP for the non-precision approach on the
ILS plate? Usually non-precision MAPs coincide with the beginning of
the runway, but not always.
Anyhow, just wondering if that can become ambiguous in some corner
cases.
Old May 9th 05, 09:59 PM
Yep. And, the timing table gives another check except when DME is
required, then it's blank.
The MAP is usually the threshold for an IAP with straight-in minimums, but
it could be prior to the threshold with dashed lines afterwards, or it
could be after the threshold for an on-airport VOR or NDB.
cases.
Old May 9th 05, 11:20 PM
Peter
Yeah, but in the ILS at SHR mentioned previously, the dashed line shows
the missed approach beginning at the decision height (not the MDA for
the circling approach) and there is DME, so the timing table is blank,
and in the little airport diagram there is no "FAF to MAP XX NM" blurb.
In other words, on that particular plate, there is nothing identifying
the missed approach point for the circling approach. There just
happens to be this fix at the threshold.
If there also happened to be an inner marker, that would show up on the
plate, but it has nothing to do with the circling approach. So how can
you be sure which fix is the MAP for the ILS-circle-to-land or LOC
approach that is co-charted with an ILS?
Old May 10th 05, 12:41 AM
The Jeppesen chart shows an "M" at the 1.5 I-SHR DME, which means
non-precision MAP.
GPS approach question Matt Whiting Instrument Flight Rules 30 August 29th 08 04:54 AM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 12:13 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 10:03 PM
