#101
"Larry Dighera"
On Sun, 08 May 2005 02:32:08 GMT, George Patterson wrote in ISefe.3205$EC6.1616@trndny06: I have a personal dislike of flight following, so I don't take advantage of this service. The thought of ATC's intrusion into the reverie of our aerial operations is displeasing. But anyone who fails to avail themselves of Radar Traffic Advisory Service in the Los Angeles basin just doesn't appreciate the magnitude of aerial congestion in the vicinity. The first time you see an in-cockpit traffic display, it's pretty sobering. It's not as lonely out there as it appears! moo |
#102
On Sun, 08 May 2005 05:46:16 GMT, A Guy Called Tyketto wrote:
Class C, on the other hand, requires 2-way comunication. When that is established, unless told otherwise, you have clearance through Class C airspace. If ATC tells you to not enter it, for whatever reason, you don't enter it. In short, once again, if the 2-way communication is established between pilot and ATC, the clearance into/through Class C airspace is implied, and pilots may fly through. Brad, There is no such thing as "implied clearance" through class C as you state above. Please see http://www.faa.gov/atpubs/ATC/Chp7/atc0708.html. Note 7-8-4. Clearances MUST be read back. When you contact ATC in Charlie airspace, you do not have to read back your "permission to enter" Charlie airspace. Typical transmission would be: ME Jackson Approach (JAN) Sundowner 1234L out of Madison, climbing through 500, headed to Covington LA. (Note the three W's). JAN Sundowner 1234L, squawk 0103, altimeter 29.89. ME 34L squawk 0103, altimeter 29.89. Note, at this point, I have been given PERMISSION to enter Charlie airspace. I did not have to read back the "permission" where as Class Bravo, I must not only hear the magic words cleared into Bravo, I MUST read back that clearance. You will NEVER hear the words, cleared into Charlie. Hope this clears it up for you. Allen |
#103
On Sun, 8 May 2005 11:27:10 -0400, "Happy Dog"
wrote in :: It's not as lonely out there as it appears! Right. The Big Sky Theory belongs right up there with the Tooth Fairy, Easter Bunny, and other childish notions. Just because you can't see 'em, doesn't mean they're not there. |
#104
![]() A Lieberman wrote: Clearances MUST be read back. No, they do not have to be. |
#105
![]() "Cub Driver" wrote in message ... I often listen to the tower at Pease tradeport (and National Guard base) across the bay. Professional pilots regularly thank the tower, and routinely say "G'day" upon departing the Delta airspace. If I am flying through the airspace low and slow for a tour of Great Bay, I call upon leaving the Class D to give my position and altitude and to say "Thank you Pease!" Perhaps things are more formal in Charlie airspace; I don't know. They're not. |
#106
A Lieberman wrote:
On Sun, 08 May 2005 05:46:16 GMT, A Guy Called Tyketto wrote Clearances MUST be read back. Nonsense. The only requirement for a readback is runway hold-short and crossing instructions (technically even then it's not on the pilot to give the readback, but ATC in soliciting one). When you contact ATC in Charlie airspace, you do not have to read back your "permission to enter" Charlie airspace. You Typical transmission would be: ME Jackson Approach (JAN) Sundowner 1234L out of Madison, climbing through 500, headed to Covington LA. (Note the three W's). JAN Sundowner 1234L, squawk 0103, altimeter 29.89. ME 34L squawk 0103, altimeter 29.89. Note, at this point, I have been given PERMISSION to enter Charlie airspace. Nope, you had permission after the first exchange (where called you back with your identifier).. I did not have to read back the "permission" where as Class Bravo, I must not only hear the magic words cleared into Bravo, I MUST read back that clearance. You're not required to readback in either case. You will NEVER hear the words, cleared into Charlie. True. |
#107
![]() "A Lieberman" wrote in message ... You absolutely must hear the words Cleared into Bravo. You have to have a clearance to enter Class B airspace, but it doesn't have to take the form "Cleared into Bravo". An IFR clearance will suffice as well as a clearance for a practice approach while VFR. It's required that ATC clears you AND you are required to read back this clearance. Please cite the FAR that requires that clearance to be read back. |
#108
![]() "A Guy Called Tyketto" wrote in message m... Thank you. This is EXACTLY what I've been trying to get at all along in this thread. You *MUST* hear 'Cleared into Class Bravo Airspace' to be allowed to enter Bravo airspace. That is your clearance into it. Even the FARs state it: Sec. 91.131 - Operations in Class B airspace. (a) Operating rules. No person may operate an aircraft within a Class B airspace area except in compliance with ?91.129 and the following rules: (1) The operator must receive an ATC clearance from the ATC facility having jurisdiction for that area before operating an aircraft in that area. Some people just fail to understand that. The regulation says the operator must receive an ATC clearance, it does not state he *MUST* hear 'Cleared into Class Bravo Airspace' to be allowed to enter Bravo airspace. Even more than that, if they tell you to remain outside of Bravo airspace, or any airspace, and give you a reason, pilots are requested to read that back. Previously you said it MUST be read back, now you say it's a REQUEST. What caused you to change your mind? Where does ATC make this request known to pilots? ATC is going to expect a readback. What makes you think that? If not, they will repeat it. What makes you think that? If no readback is given, they aren't going to *ASSUME* anything. If there's no response they're going to assume the message was not received and repeat it. If the message is acknowledged but not read back they're going to conclude the message was received and understood by the pilot and that particular little matter is then closed. If the message is read back they're going to conclude the message was received and understood by the pilot and that particular little matter is then closed. They aren't going to think 'oh, he heard it, let me worry about separating my aircraft flying into JFK, LAS', or any major field, they are going to get that readback from you, or send up the F18s to escort you down/shoot you down, depending on how grave the situation is. What makes you think you know what ATC thinks? Class C, on the other hand, requires 2-way comunication. When that is established, unless told otherwise, you have clearance through Class C airspace. If ATC tells you to not enter it, for whatever reason, you don't enter it. In short, once again, if the 2-way communication is established between pilot and ATC, the clearance into/through Class C airspace is implied, and pilots may fly through. So it no longer requires radar contact prior to entry? |
#109
![]() "Larry Dighera" wrote in message ... Mr. Dog does make his location reasonably known. If you look at the 'From' header of his articles: From: "Happy Dog" You'll note the domain of his e-mail address is: sympatico.ca You're probably aware that '.ca' domain names indicate their location to be Canada. His location does not necessarily mean he's speaking about Canadian procedures. Many Canadian pilots operate in the US regularly. He entered a discussion where US procedures were being discussed and spoke of Canadian procedures without identifying his comments as such. Bad form. |
#110
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 A Lieberman wrote: On Sun, 08 May 2005 05:46:16 GMT, A Guy Called Tyketto wrote: Class C, on the other hand, requires 2-way comunication. When that is established, unless told otherwise, you have clearance through Class C airspace. If ATC tells you to not enter it, for whatever reason, you don't enter it. In short, once again, if the 2-way communication is established between pilot and ATC, the clearance into/through Class C airspace is implied, and pilots may fly through. Brad, There is no such thing as "implied clearance" through class C as you state above. Please see http://www.faa.gov/atpubs/ATC/Chp7/atc0708.html. Note 7-8-4. Clearances MUST be read back. When you contact ATC in Charlie airspace, you do not have to read back your "permission to enter" Charlie airspace. Typical transmission would be: ME Jackson Approach (JAN) Sundowner 1234L out of Madison, climbing through 500, headed to Covington LA. (Note the three W's). JAN Sundowner 1234L, squawk 0103, altimeter 29.89. ME 34L squawk 0103, altimeter 29.89. Note, at this point, I have been given PERMISSION to enter Charlie airspace. Exactly what I've been saying. I never said you had to readback a clearance INTO Class C, but that if a controller tells you for whatever reason to remain OUTSIDE of Class C, that should be read back. I did not have to read back the "permission" where as Class Bravo, I must not only hear the magic words cleared into Bravo, I MUST read back that clearance. You will NEVER hear the words, cleared into Charlie. Hope this clears it up for you. I agree, but I never said you'd hear 'cleared into class C'. Just that if they tell you to remain outside of it, that should be read back, and sometime along the way, ATC should be able to either a) tell you when you will be able to transition it, or b) work you around their airspace, either via different suggested routing (note, not giving vectors), different altitudes (possibly dropping you into class D, should that area exist near/around there), or handing off to another controller who can get you back on your course. BL. - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.1 (GNU/Linux) iD8DBQFCfne0yBkZmuMZ8L8RAroKAKCVMpk9XGdMTMtyopuN1u yEQAFWbgCfXIzU PuwKA1FQsC7v7TL0o74/ZSY= =39PT -----END PGP SIGNATURE----- |
What F-102 units were called up for Viet Nam | Tarver Engineering | Military Aviation | 101 | March 5th 06 03:13 AM |
