Proposal for a future (helicopter) engine...
2-stroke diesel 2500cc two cylinder 45 degree V (120-150hp) air cooled (cowlings) common rail direct injection (high pressure) supercharged (Whipple fixed displacement max. 25 psi twin-screw) piston ported (or with LIM-type intake valve) Links... www.limtechnology.com www.zoche.de Has anybody ever tought of opening the intake valve (one ceneterd valve) with (the high) diesel injection pressure? Perhaps the valve and injector could be integrated. As the pressure is released (at the exact right time) to the valve, it opens and lets the supercharged compressed air rush in. As the piston rises past the exhaust ports, the diesel fuel is injected and as the pressure quickly drops (and simultaneously the cylinder pressure rises) the valve closes tightly. Could this be feasible? Unfortunately, I am no engineer. Just a tought. In a two-cycle engine the integrated pump nozzles and intake valves could be operated directly from crankshaft with push rods and rocker arms. This would still eliminate the camshaft and the high pressure injection pump. This type of engine could prove to reliable and economical... - diesel fuel acts as a lubricant as well (reliability) - low parts count (reliability, low and easy maintenance, light) - sturdy diesel parts (reliability, low maintenance) - economical on fuel(low consumption, the use of bio-fuels, possibly a bi-fuel) Is this the future engine for aviation (rotor aeroplanes and helicopters), automotive, machines, marine etc? Cars (trains and boats as well) should be full two-mode hybrids with a mecanical planetary drivetrain or just the combination of a diesel generator, batteries and electric engines (to make things simple and economical). You could (and should) recharge the batteries from AC mains during the night, so they are at full charge when you go off to work. They are charged with the diesel generator and as you apply the brakes. |
Detroit Diesel has been producing 2-stroke diesels of this sort for 50
years. They recently changed to conventional 4 stroke engines. Guess why? "Max Kallio" wrote in message om... Proposal for a future (helicopter) engine... 2-stroke diesel 2500cc two cylinder 45 degree V (120-150hp) air cooled (cowlings) common rail direct injection (high pressure) supercharged (Whipple fixed displacement max. 25 psi twin-screw) piston ported (or with LIM-type intake valve) Links... www.limtechnology.com www.zoche.de Has anybody ever tought of opening the intake valve (one ceneterd valve) with (the high) diesel injection pressure? Perhaps the valve and injector could be integrated. As the pressure is released (at the exact right time) to the valve, it opens and lets the supercharged compressed air rush in. As the piston rises past the exhaust ports, the diesel fuel is injected and as the pressure quickly drops (and simultaneously the cylinder pressure rises) the valve closes tightly. Could this be feasible? Unfortunately, I am no engineer. Just a tought. In a two-cycle engine the integrated pump nozzles and intake valves could be operated directly from crankshaft with push rods and rocker arms. This would still eliminate the camshaft and the high pressure injection pump. This type of engine could prove to reliable and economical... - diesel fuel acts as a lubricant as well (reliability) - low parts count (reliability, low and easy maintenance, light) - sturdy diesel parts (reliability, low maintenance) - economical on fuel(low consumption, the use of bio-fuels, possibly a bi-fuel) Is this the future engine for aviation (rotor aeroplanes and helicopters), automotive, machines, marine etc? Cars (trains and boats as well) should be full two-mode hybrids with a mecanical planetary drivetrain or just the combination of a diesel generator, batteries and electric engines (to make things simple and economical). You could (and should) recharge the batteries from AC mains during the night, so they are at full charge when you go off to work. They are charged with the diesel generator and as you apply the brakes. |
Considering that the famous mfg. of 2-stroke Diesel locomotives has now
gone to 4-stroke because of better economy and lower emissions, this seems to me like a step backward. Max Kallio wrote: Proposal for a future (helicopter) engine... 2-stroke diesel 2500cc two cylinder 45 degree V (120-150hp) air cooled (cowlings) common rail direct injection (high pressure) supercharged (Whipple fixed displacement max. 25 psi twin-screw) piston ported (or with LIM-type intake valve) Links... www.limtechnology.com www.zoche.de Has anybody ever tought of opening the intake valve (one ceneterd valve) with (the high) diesel injection pressure? Perhaps the valve and injector could be integrated. As the pressure is released (at the exact right time) to the valve, it opens and lets the supercharged compressed air rush in. As the piston rises past the exhaust ports, the diesel fuel is injected and as the pressure quickly drops (and simultaneously the cylinder pressure rises) the valve closes tightly. Could this be feasible? Unfortunately, I am no engineer. Just a tought. In a two-cycle engine the integrated pump nozzles and intake valves could be operated directly from crankshaft with push rods and rocker arms. This would still eliminate the camshaft and the high pressure injection pump. This type of engine could prove to reliable and economical... - diesel fuel acts as a lubricant as well (reliability) - low parts count (reliability, low and easy maintenance, light) - sturdy diesel parts (reliability, low maintenance) - economical on fuel(low consumption, the use of bio-fuels, possibly a bi-fuel) Is this the future engine for aviation (rotor aeroplanes and helicopters), automotive, machines, marine etc? Cars (trains and boats as well) should be full two-mode hybrids with a mecanical planetary drivetrain or just the combination of a diesel generator, batteries and electric engines (to make things simple and economical). You could (and should) recharge the batteries from AC mains during the night, so they are at full charge when you go off to work. They are charged with the diesel generator and as you apply the brakes. |
Diesel aircraft engines for certified and experiimental aircraft are here
now. http://www.centurion-engines.com/c17/c17_start.htm There are others also. |
That's not a new design.
Dan wrote:
Diesel aircraft engines for certified and experiimental aircraft are here now. http://www.centurion-engines.com/c17/c17_start.htm There are others also. To prevent going to much OT in rec.auto.tech, if you wish to discuss engines other than car engines, there is a Yahoo group called heat engines, for discussion of any heat engine, IC, steam, or other. http://groups.yahoo.com/group/heatengines/ You can access it as a web discussion group, or you can receive and post via email. We'd be happy to see more folks join, and liven up the discussions. |
Wandering aimlessly about the Web, I heard Max Kallio say:
Proposal for a future (helicopter) engine... 2-stroke diesel 2500cc two cylinder 45 degree V (120-150hp) air cooled (cowlings) common rail direct injection (high pressure) supercharged (Whipple fixed displacement max. 25 psi twin-screw) piston ported (or with LIM-type intake valve) Links... www.limtechnology.com www.zoche.de -- SNIP -- I've been watching Zoche for 6-7 years, and as far as I know, they still haven't released anything to the market that you can buy. The material on their web site hasn't been updated in three or four years. Their aerodiesel designs look good -- excellent power/weight, fuel economy significantly better than gasoline, use of more widely available jet fuel or kerosene, projected high reliability and life due to much lower component count than 4-stroke engines, compressed air starter eliminates need for large, heavy cranking battery, etc., etc. Unfortunately, Michael Zoche got wrapped around an axle in typical German mindset by trying to get JAR-E and FAR-33 certification before marketing the engines. That's kept them entangled in bureaucratic red tape for years, particularly in Germany. (The bureaucracy in Germany is phenomenal. It's little wonder Germans have been relatively non-innovative in the world market, compared to Japan and the U.S.) It would have been better to get some of their smaller, lighter engines into the hands of homebuilders and experimenters on a non-certified, use-at-your-own-risk basis to gain operational experience, while they continued to work on JAR and FAA certification. After all, look at the junk ultralight builders have been strapping to their machines for years. A Zoche pre-production engine would probably be as good or better. -- Andrew P. [Post replies to this message on forum only] |
You have most of it right. Some things you have wrong,
1. Desiel injection timing is differant than on an Otto engine. The fuel is injected during the intake cycle on the Otto engine and the fuel is injected during the ignition cycle on the Desiel. On the Desiel the fuel injection cycle starts just before TDC and ends well after TDC. The fuel ignites as soon as it hits the hot air. 2. The parts count is not less on a two stroke Desiel, It is higher because of the need for a supercharger and a way to port the exhaust. I don't think you would want a four stroke Desiel in an aircraft because of the increased weight and low power. Desiel engines don't really produce more torque as a gas engine, its just that the fuel burns slower and thus the engine cannot rev as fast, but it can produce the same or slightly more torque at lower speeds, and at much lower fuel flow rates. Because of this they should be ideal for an aircraft engine that doesn't need to turn at a higher speed. You do lose one advantage of the Desiel engine on an aircraft. Because of the lack of a throttle and the fact that they can burn extreamly lean at idle, Desiel engines are extremely efficient in stop and go traffic. But we don't idle aircraft engines that much. |
Wandering aimlessly about the Web, I heard Sport Pilot say:
You have most of it right. Some things you have wrong, 1. Desiel injection timing is differant than on an Otto engine. The fuel is injected during the intake cycle on the Otto engine and the fuel is injected during the ignition cycle on the Desiel. On the Desiel the fuel injection cycle starts just before TDC and ends well after TDC. The fuel ignites as soon as it hits the hot air. etc., etc. --- SNIP --- It's Diesel, not "Desiel". -- Andrew P. [Post replies to this message on forum only] |
Guess why?
*Duh* Pollution laws, and no need for the power to weight requirements of Aviation! Duh... whats that got to do with this topic? Other than to show that 2 stroke Compression ignition engines are a proven concept? |
| 2-stroke diesel is the (near) future? | Max Kallio | Home Built | 134 | July 18th 05 01:39 AM |
| BSFC vs gas mileage, 2 stroke vs 4 stroke | Jay | Home Built | 10 | August 24th 04 03:26 PM |
| Diesel Jodel information..........and .........diesel plane groups | Roland M | Home Built | 1 | January 4th 04 05:04 AM |
| Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Home Built | 3 | September 13th 03 01:44 AM |
| Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Rotorcraft | 2 | September 13th 03 01:44 AM |
