MoGas Long Term Test: 5000 gallons and counting...
Old May 9th 05, 02:34 AM
Jay Honeck
Default MoGas Long Term Test: 5000 gallons and counting...
Yesterday I noticed that we had pumped more than 5000 gallons of mogas
through the Mighty Grape. This represents something like 60 complete fills
(our plane has four gas tanks, totaling 84 gallons), and around 350 hours of
flight time over the last 2.5 years.
(See: http://alexisparkinn.com/fuel_truck.htm for details on our Jim
Weir-inspired fuel truck, the "Mighty Grape"...)
At an average saving of over $1 per gallon (at the moment, it's more like
$1.25), we have paid for the truck (which we use extensively at the hotel),
the tank & pump installation (which has worked flawlessly from "Day One") --
and put aside over $2500 toward our next overhaul.
Best of all, Atlas (our Lycoming O-540-powered Cherokee Pathfinder) simply
runs best on regular, 87-octane unleaded car gasoline. In fact, the ONLY
time we've had trouble with our new engine has been when we were forced to
buy 100LL avgas, which causes lead-fouling of our spark plugs at the drop of
a hat.
All the worries that people stated, both personally and here in this forum,
have turned out to be entirely baseless. After flying with mogas for the
last 2.5 years, I can unequivocally state the following:
1. Mogas works better in my plane than avgas. Our engine runs noticeably
better on mogas.
2. I have had no problems with contamination of any kind (my pump/tank
installation has a very good filtration system)
3. If we've run across any ethanol, the engine has never burped because of
it.
4. We've run mogas from sea level to 13,500 feet, in temperatures from -15
to +97 degrees Fahrenheit, without problem.
Because of this, I state further that:
1. I would burn mogas in my plane even if it cost MORE than avgas -- it runs
that much better.
2. I will never buy a plane that doesn't have the auto gas STC.
The autogas STC is undoubtedly the best thing that has ever happened to
aircraft owners. If you've got the STC, but aren't using it, you are
literally flushing thousands of dollars down the toilet.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 9th 05, 03:41 AM
Jim Carriere
Awww, anecdotal evidence. Statistically speaking, you need a larger
sample size
But seriously, a good post, well documented.
'Couple questions-
Do you use the same spark plugs (and same heat range) as before going
to mogas?
Do you lean, and how lean? What kind of numbers do you usually see
in different regimes of flight (EGT, CHT)? Obviously detonation
hasn't been a problem for you, I'm curious how hot you can get away
with on that engine with regular auto fuel.
Thanks.
OK, 3 questions, if you save a buck a gallon on 5000 gallons, and but
$2500 to the next overhaul, the other $2500 must buy a lot of good
beer, right?
Old May 9th 05, 03:51 AM
Jay Honeck
Do you use the same spark plugs (and same heat range) as before going to
mogas?
Yep. Although because they foul too easily with 100LL (which we must buy on
long-cross-country flights), I'm probably going to go with a hotter plug
when these die.
Do you lean, and how lean? What kind of numbers do you usually see in
different regimes of flight (EGT, CHT)? Obviously detonation hasn't been
a problem for you, I'm curious how hot you can get away with on that
Sure do. At take off power, full rich, we're burning 25 gph. At cruise we
tend to run 23 squared, leaned back to 15 gph. At this setting we'll see
EGTs in the 1350 - 1450 degree range, and CHTs in the 300 - 325 degree
range.
We can, of course, throttle back to 20 squared, and burn 10 gph or less.
Danged engine is so quiet at that power setting, it's almost spooky.
$2500 to the next overhaul, the other $2500 must buy a lot of good beer,
right?
Nah, beer is extra! :-)
The Grape itself cost $1800, and the tank/pump installation (and a couple of
other things) make up the other $700 or so.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old May 9th 05, 04:37 AM
Dave Stadt
"Jay Honeck" wrote in message
news:y6zfe.67777$WI3.10767@attbi_s71...
fills
of
hotel),
One") --
of
a hat.
forum,
better on mogas.
it.
runs
that much better.
Jay Honeck
Iowa City, IA
Pathfinder N56993
The only down side to mogas I have noticed is the smell.
Old May 9th 05, 04:43 AM
ORVAL FAIRBAIRN
of
sample size
'Couple questions-
to mogas?
I do, too -- plugs last longer without the lead in the fuel.
Detonation is NEVER a problem when the octane is correct. If the engine
is designed for 80 octane, it will happily drink 80 octane mogas or
anything else that meets the minimum spec. The absence of lead in the
fuel simply means that there is less junk to scavenge out of the
combustion products.
BTW, how many out there are aware that 80 octane unleaded avgas used to
be available, back in the 40s and 50s?
Remove _'s from email address to talk to me.
Old May 9th 05, 05:07 AM
BTIZ
Actually I think it was available up into the mid to late 70s...
80/88, and it was colored Red...
BT
Old May 9th 05, 07:01 AM
Ben Jackson
Unfortunately the engine isn't the only consideration. For some reason
the Comanche is subject to vapor lock with mogas so there is no STC
available.
What's really sad is that last year this time I was paying less for avgas
than I am *now* for mogas.
Ben Jackson
http://www.ben.com/
Old May 9th 05, 08:06 AM
Scott Skylane
Jay Honeck wrote:
/snip/
range.
/snip/
Jay,
Huh??? On my 230 hp O-470, I cruise at 23-squared, without any fancy
engine monitors. Using the "pull-until-it-feels-about-right" method of
leaning, I get 12 gph. Religeously. You can set your watch by that
figure. I wonder if using mogas is somehow requiring you to run 25%
richer than avgas? If so, what are your corrected savings per hour?
On a side note, as I asked you earlier, what part # spark plugs are you
running? I am curious due to your undue propensity to fouling while
running avgas.
Happy Flying!
Scott Skylane
N92054
Old May 9th 05, 12:21 PM
kontiki
range.
My Comanche has an O-540 and at 22/23 I'm burning about 13 Gph with 100LL.
If there was an MOGAS STC for the Comanche I'd give it a try but that will
never happen.
Old May 9th 05, 12:45 PM
Denny
Fat Albert the Apache dines on a diet of the cheapest, stinkiest,
crapola, 83 octane, gas I can find... He only gets toxic, lead spewing,
plug fouling, valve sticking, 100LL, on trips where I can't get to the
gas station....
My mechanic is mumbling because the plugs have gone 4 years and way
over 400 hours and are going strong... This annual he said he HAD to
change the plugs because of the hours, he felt he JUST couldn't sign
them off for another year... I said, "Fine, JUST as long as you are
paying for them!"... He changed the subject...
I lean by the EGT at 70% or higher... On local flights I am normally at
60 - 65% power, lean em until they go rough, and smile...
ymmv, sar, bni
denny
