Airbrakes Pop Out at 115 kts
Old May 9th 05, 08:45 PM
For Example John Smith
Is there a 3rd possible outcome or is something always wrong with these
things? ;-)
John,
Have you done the "dime" test?
+ Lift the spoiler cap and slip in 4 or 5 dimes.
+ Close and lock spoilers. If the cap didn't close flush, then the rod
length after the over-center mechanism needs adjustment.
+ If the spoilers did close flush, then you need stronger springs. The
springs on the ends should be about twice as strong as the others.
JJ
Old May 9th 05, 10:21 PM
John Sinclair
I was responding to a post that stated the spoilers
were popping open at 115 knots, but the dime test should
be done every now and then even though no problem is
noted. If the spoiler caps go flush (with dimes in)
then go fly and put her into a 2-G turn (60 degree
bank) and while holding it in the turn, peek out at
both spoilers. If the caps are lifting, increase spring
tension.
JJ
wrong with these
things? ;-)
John,
Have you done the 'dime' test?
flush, then the rod
springs. The
as the others.
JJ
Old May 9th 05, 11:46 PM
Eric Greenwell
tension.
I'm assuming you aren't referring to just the DG 101, so...
Do the dimes go between the spoiler cap and the top of the spoiler blade?
Is there any chance the dimes will fall out and work their way to a
place we don't want them?
What's the best way to increase spring tension? On my ASH 26 E, I put a
couple washers on the posts that didn't seem to be pulling hard enough
to increase the pre-tension there, which has worked so far, but maybe
there is a better/easier way.
Eric Greenwell
Washington State
USA
Old May 10th 05, 02:50 PM
John Sinclair
should
is
tension.
so...
Yeah, works on all spoilers.
Yes
their way to a
You don't leave them in, Eric. Just slip them in,
do the test (close and lock) and then remove them.
If one does slip out, it will be in the bottom of the
spoiler box, fish it out.
pulling hard enough
so far, but maybe
It has been my observation that adding washers doesn't
increase the spring tension and therefore doesn't solve
the problem. A quick & dirty way to do the job is to
fill all the nooks & crannies of the spring with silicone
calking, let it dry with spoilers unlocked. Worked
on the ASW-20's end springs. Nowadays, the ships come
with stronger end springs. A good hardware store may
have an nice assortment of springs. Take in the old
one to judge by.
JJ
Change 'netto' to 'net' to email me directly
Eric Greenwell
Washington State
USA
ASW19b best descent rate on approach (full airbrakes) Robert Sharpe Soaring 1 April 30th 05 12:41 PM
Slip to landing on PPG practical test Roger Worden Soaring 56 November 11th 04 10:38 PM
Devices for avoiding VNE? John Galloway Soaring 100 April 12th 04 09:53 PM
Thermal right, land left John Soaring 195 April 2nd 04 12:43 AM
Spoiler placement and design. B2431 Home Built 9 November 11th 03 05:02 PM
