Lubrication Advise
Old May 10th 05, 07:13 PM
Dan, U.S. Air Force, retired
Default Lubrication Advise
I'm playing with a mechanism that involves a piece of nylon rod rotating
inside an aluminum tube. Is lubrication required and if so what kind?
Old May 10th 05, 09:28 PM
Morgans
"Dan, U.S. Air Force, retired" wrote in message
news:5R6ge.6000$aB.4725@lakeread03...
At what RPM. and what kind of loads will be on it?
Jim in NC
Old May 11th 05, 01:43 AM
Actually it will be cycling over an arc of 15º - 20º lateral loads won't
exceed 20 pounds total over a 4 inch length. Longitudinal load is
essentially zero. Cyclic rate won't exceed 5 cycles per second.
Old May 11th 05, 01:53 AM
LCT Paintball
Make sure the Aluminum is very smooth. I wouldn't lubricate it at all. I
think you'll find the nylon lives longer than the aluminum that it rides on.
Old May 15th 05, 04:32 PM
Stealth Pilot
On Wed, 11 May 2005 00:53:04 GMT, "LCT Paintball"
grease?
Stealth Pilot
Old May 15th 05, 05:23 PM
LCT Paintball
grease?
Stealth Pilot
Nylon is self lubricating. It might actually perform worse with grease.
Mooney Engine Problem in Flight - Advise Paul Smedshammer Owning 17 December 21st 04 06:39 AM
CAI 302 repair advise needed Jamey Jacobs Soaring 5 October 19th 04 03:06 AM
Need advise on ASA's IPT charley Products 0 December 14th 03 05:40 PM
