Service Volumes of VOR's make no sense
Old May 12th 05, 06:10 AM
Antoņio
Default Service Volumes of VOR's make no sense
I was at a CFI safety meeting today and the subject of VOR service
volumes came up. The AIM describes the Standard High Service Volume as
providing positive course guidance at varying distances depending on
your altitude--40nm at 1000ft., 100nm at 14,500ft, 130nm at 45,000ft, etc.
If the VOR is a "line of sight" signal device. How can there be varying
distances of service at varying altitudes? I mean, shouldn't I be able
to pick up a VOR radial from the moon as long as no obstructions intervene?
Antonio
Old May 12th 05, 07:01 AM
Grumman-581
"Antoņio" wrote in message ...
intervene?
NEWSFLASH -- THE EARTH IS NO LONGER BELIEVED TO BE FLAT !!!
(at least my *most* of us)
Old May 12th 05, 07:51 AM
Larry Dighera
On Wed, 11 May 2005 21:10:13 -0700, Antoņio
wrote in
shouldn't I be able
Perhaps, but the energy of the received signal is reduced by the
square of the receiver's distance from the station.
Old May 12th 05, 09:21 AM
Antoņio
intervene?
I'm not sure of what that remark means.
Have you seen the "wedding cake" drawings of the service volumes?
Antonio
Old May 12th 05, 11:40 AM
Hilton
intervene?
Yes, if we all had extremely efficient receivers, but we don't. The FAA and
some radio guys got together and decided on applicable distances. Once they
figured that out, they had a bunch of semi-spheres. While it would have
been 'correct' to define the service volumes are a semi-sphere, it wouldn't
have been all that useful to us (pilots). So the FAA made them (mostly)
cylinders (and ensured that the cylinder lay within the semi-sphere) to make
it easy for pilots to figure out whether or not they were in the service
volume. i.e. it is a combination of radio effectiveness and pilot
usefulness that describes the service volume.
I just made that up, but it sure sounds convincing, logical, and almost as
good as if I had stayed at a Holiday Inn last night... instead of working
on software.
Hilton
Old May 12th 05, 12:45 PM
Peter Clark
The way it was explained to me was that once you get above a certain
altitude you can start getting interference from other VORs with the
same frequency, so the 'valid' radius starts getting shorter again.
Old May 12th 05, 01:30 PM
Denny
Damn, and just when I was getting good at plane trigonometry...
OK, smart a** remarks aside, not only is the world round, it is very
round - in the sense that the horizon falls away so quickly that for
those who are not boaters/sailers it will be a surprise... We used to
keep our Pearson on Lake Huron, up at Tawas Bay... Every summer they
held the Laser fleet races on the bay... (These are small sail boats
with a gunnel about a foot high) It was common for me to sit on the
beach on a calm Sunday morning and look across the bay and see these
guys sailing in light air, with the sailer visible from the waist up -
the entire hull of the laser and his lower body were below the horizon
- I don't mean hidden by waves, the bay was a sheet of glass......
denny
Old May 12th 05, 04:29 PM
Grumman-581
The earth is round... Radio travels line of sight, which means a straight
line...Draw a large circle with a protractor... Choose a point on the
circumference at the top of the circle... Draw a line tangent to the circle
through this point... The line is horizontal... If an object is above this
line, it will be able to 'see' the original point, if it is below the line,
but above the circumference, it will not be able to 'see' the original point
since the body of the circle (i.e. the earth) is getting in the way of the
signal... The greater the distance the object is above the circumference of
the circle, the more of the circle it is able to 'see'...
Now, extend this concept into three dimensions...
Old May 12th 05, 10:26 PM
Steven P. McNicoll
I was at a CFI safety meeting today and the subject of VOR service volumes
came up. The AIM describes the Standard High Service Volume as providing
positive course guidance at varying distances depending on your
distances of service at varying altitudes? I mean, shouldn't I be able to
Yes, and every other VOR on that frequency as well. The altitude/distance
limits ensure you won't receive an unwanted VOR signal. Note that the
service volume decreases from 130 miles to 100 miles above FL 450.
Old May 13th 05, 02:27 AM
Andrew Sarangan
Isn't that the reason certain airways have a MAA - Maximum Authorized
Altitude?
"Steven P. McNicoll" wrote in
nk.net:
"Antoņio" wrote in
message ...
as providing positive course guidance at varying distances depending
on your altitude--40nm at 1000ft., 100nm at 14,500ft, 130nm at
45,000ft, etc.
varying distances of service at varying altitudes? I mean, shouldn't
I be able to pick up a VOR radial from the moon as long as no
altitude/distance limits ensure you won't receive an unwanted VOR
signal. Note that the service volume decreases from 130 miles to 100
miles above FL 450.
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 6th 04 12:14 AM
Copyright Š2004-2025 AviationBanter.
