Aircraft Winch
Old May 11th 05, 08:27 PM
Jens Krueger
"Montblack" wrote:
http://cgi.ebay.com/ebaymotors/ws/eB...rd=1,1&item=45
48358271&sspagename=STRK%3AMESE%3AIT
This long link happens to work for me tonight - most do not.
If you format a link in brackets it tends to survive a couple of
quoting levels. It's not a guarantee but then you always have the
original post.
Please consider using:
www.tinyURL.com or www.makeashorterlink.com
The biggest problem I have with those services is that they don't
archive well. Usenet is very well archived, you can still find posts
from over ten years ago; including references to websites. Try that with
a "tinyurl". How long do they keep those "tiny" references?
Cheers,
Jens
I don't accept any emails right now. Usenet replys only.
Old May 11th 05, 09:02 PM
xyzzy
original post.
So give both the long and the tiny url. Tinyurl automatically puts its
result into your clipboard so it's easy to do.
Old May 12th 05, 01:20 AM
Jens Krueger
So what's the point of having tinyurl then? Because a broken newsreader
cant handle ""-formatted urls forces everybody else to quote a url now
twice? If your newsreader doesn't open a web browser with Google after
clicking on this http://www.google.com, then you need another
newsreader, not tinyurl or whatever... ;-)
Cheers,
Jens
Old May 12th 05, 03:15 AM
Grumman-581
"Jens Krueger" wrote in message
Either that or learn how to cut-n-paste...
Old May 12th 05, 04:59 AM
Peter Duniho
quoting levels.
Even a broken URL isn't hard to reconstruct. Regardless...
archive well.
Define "archive well".
As far as I know, forever. makeashorterlink.com specifically says in their
FAQ that, as long as they are around, their links will work. tinyurl.com
doesn't have an FAQ, or any real documentation beyond "here's how to use our
service" as near as I can tell. But I would be surprised if it's different.
What makes you believe that the shortened URLs age at all, never mind in an
unreasonably short period of time. I think it's more likely that the
original URL itself will go out of date before the shorter reference URL
does. The web is filled with dead links.
Pete
Old May 12th 05, 06:01 AM
Grumman-581
"Peter Duniho" wrote in message ...
I guess the term for that is "HTTP roadkill"...
Old May 12th 05, 04:21 PM
Jens Krueger
archive well.
As long as source (news post) and target (webpage) exist.
Well...
....that could be significantly shorter than "forever". ;-)
Anyways, my point was that introducing link-hosts should not be the cure
for broken newsreader, like the response to the OP suggested.
Cheers,
Jens
Old May 12th 05, 07:16 PM
Peter Duniho
It could well match the lifetime of the Internet, for all we know. My point
is that there's no reason to believe that the shortcut web sites will have a
shorter lifetime than the Usenet archives or other related resources.
Perhaps not. But even the person saying that we shouldn't work around
broken newsreaders (you) apparently has a broken newsreader (your
formatted URL come through with a line break).
makeashortlink.com shows you the target URL before redirecting you. It
doesn't make links as short as tinyurl.com, but they are short enough and
IMHO do address the line-break issue, and make the post more readable anyway
(to a human being, often the only part of the URL really useful is the
domain...one could just put that seperately -- "From foo.com:" -- and use
the shorter link service).
I just don't see what you have against the services. Your original
complaint was that the redirects go out of date, but they don't. Now your
complaint seems to be that we ought to all just be using newsreaders that
aren't "broken", but your own newsreader appears to be as well.
Pete
Old May 13th 05, 08:30 PM
Jens Krueger
Yes, "could". Not "will". ;-)
So, enlighten me: Which one is going to be still around in 2035:
makeashorterlink.com, tinyurl.com, shorl.com, notlong.com, babyurl.com,
biglnk.com, bittyurl.com, briefurl.com etc. etc. If you predict correct,
I'll buy you a beer. In thirty years. :-)
No, like you just said above, they could; most probably 80% of them will
be defunct in a couple of years. Here's an article further detailing the
problems with redirects:
http://www.businessknowhow.com/internet/miniurl.htm
Cheers,
Jens
Since this now higly OT, EOT for me. Feel free to email me at my first
name at jjk.cc
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
