2-stroke diesel is the (near) future?
Old May 13th 05, 04:46 PM
Steve
MJC wrote:
It's Diesel, not "Desiel".
Andrew P.
Well if you're going to get picky, it's "Auto" engine, not "Otto" engine.
No, the spark-ignition cycle is the Otto cycle. Yes, most Auto engines
are Otto engines, but don't let that confuse you.
Old May 13th 05, 04:50 PM
Steve
Actually, it is Otto, as in 4-stroke spark ignition.
nate
A 4-stroke diesel is still an Otto engine. An Otto cycle engine is one
with four strokes, intake, compression, power, and exhaust. Doesn't
care whether SI or CI.
No, it really isn't, at least not in common usage. If you want to be
ridiculously pedantic, then the "Diesel cycle" is an Otto cycle with
constant-pressure combustion under varying cylinder volume, whereas what
is commonly just called the "Otto Cycle" is a spark-ignited Otto cycle
with constant-volume combustion under varying cylinder pressure.
Neither cycle attains that ideal, so there's some overlap, but if you
look at real-world pressure-volume diagrams for Diesel and
spark-ignition engines, the difference is obvious.
Old May 13th 05, 04:52 PM
Steve
Don Stauffer wrote:
one with four strokes, intake, compression, power, and exhaust.
Doesn't care whether SI or CI.
Whoops
Before everyone jumps on me, I left off an important qualification. I
was specifically talking about cars, airplanes and highway trucks. Large
Diesels, (stationary, large ship, etc) do run a different cycle- the
true Diesel cycle.
However, even the true Diesel cycle of larger engines is not the true
cycle Diesel really wanted. He couldn't develop the true cycle he
wanted (constant enthalpy), and a large Diesel comes somewhat close. A
high speed (vehicle) engine doesn't even come close with even today's
technology. It is pretty close to an Otto cycle, though still not
exactly. Otto cycle has infinitesmal fraction of cycle for ignition and
burn, while even a high speed Diesel (and even the SI engine) still
ignites and burns over a finite angle of crank rotation. Still, the
result, as I say is MUCH closer to Otto than the cycle Rudy had
intended. Still makes a good engine, however :-)
I pretty much agree, although today's high-speed diesels are doing a lot
better at approchin the constant-enthalpy cycle than they used to,
thanks to being able to divorce the injection profile from crankshaft
position via electronically-controlled injection systems.
Old May 13th 05, 05:40 PM
"Steve" wrote in message
Now that you mentioned it, what sort of rpm ranges are the high speed
diesels capable of?
You may remember that some years ago (just after the Arabs shut off the oil)
AVCO showed
a rather smallish (V8?) diesel that you could swap into just about any
American car of the time.
Cost was about $5000, estimated.
They claimed some rather high RPM capabilities for this engine.
Old May 13th 05, 06:13 PM
Sport Pilot
karel wrote:
"Sport Pilot" wrote in message
Sooo. I oftern transpose letters, I don't proofread something as
triavil as usenet messages.
If you consider your messages trivial, why post them?
Anyway, I won't see them anymore. Ploink!
Only a fool assumes that someone who has trouble spelling or
pronuciation.
Old May 13th 05, 06:17 PM
Sport Pilot
Don Stauffer wrote:
one
Doesn't
Whoops
I
Large Diesels, (stationary, large ship, etc) do run a different
cycle-
the true Diesel cycle.
A
and
You can only get so much speed when you inject the fuel through the
combustion or expansion cycle. High speed diesels get more speed by
injecting more of the fuel early. But an aircraft engine doesn't need
to turn more than 2500 RPM so we should be able to get the benifit of
the longer burn time.
  #28
Old May 13th 05, 08:51 PM
Richard Isakson
"Sport Pilot" wrote ...
pronuciation.
Isn't able to complete a sentence either?
Rich
  #29
Old May 13th 05, 09:23 PM
Sport Pilot
Got cut off some how.
Actually I thought I had decided not to send it, and came back and some
how hit the enter key.
  #30
Old May 13th 05, 11:17 PM
Steve
Sport Pilot wrote:
groups.com...
pronuciation.
......... what? I'm waiting for the rest. And its "pronuNciation."
Its one thing to have the occasional typo, but typing a constant run-on
of misspelled and non-punctuated text just screams "I'm a moron!" to the
world.
BSFC vs gas mileage, 2 stroke vs 4 stroke Jay Home Built 10 August 24th 04 02:26 PM
Diesel Jodel information..........and .........diesel plane groups Roland M Home Built 1 January 4th 04 04:04 AM
Diesel Jodel information..........and .........diesel plane groups Roland M General Aviation 1 January 4th 04 04:04 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M General Aviation 2 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 12:44 AM
