BGA Engineering News No. 30, May 2005
http://www.gliding.co.uk/bgainfo/tec...hnewsmay05.pdf has a section on wheel brakes (at the end) which includes the following: " If a glider was designed with a brake then it must have one fitted and working. " If the glider has a main skid and can be stopped by using the skid then the wheel brake may be temporarily unserviceable provided it is recorded as a deferred defect, notified to the pilot and rectified at the earliest opportunity (i.e. within a day or so)." When Lasham first bought new K13s and K8s, one of the first things we did was to disconnect the wheel brakes. With the K8 the wheel brake hardly worked, and the front skid worked very well. With the K13, the brake soon stopped working at all well, and again the front skid works well. I saw a K13 Tost wheel with the maker's tag attached. It said, roughly, "This wheel has a brake which is too small, because there is not room to fit one big enough. Do not use it unless you have to, you will need to adjust it every time you use it hard." Lasham is of course a large flat site, and the K8 and K13 finish on the front skid even if the stick is held on the back stop during the ground run. Most of Lasham's present fleet of K13s were built with a front wheel instead of a skid, and have a disc brake which does work well. Is it possible to change the Tost drum brake wheel on a K13 to a disc brake? How much does it cost? How many club operated K13s have a Tost drum wheel brake which works well? Is it really unsafe to operate a K13 without a good wheel brake, relying on the front skid? Is it really unsafe to operate a K8 without a wheel brake? How much flying have those who wrote this ruling done in skidded K13s and in K8s? I have twice tried to post this to u.r.a.s., but both times it disappeared into cyberspace. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. |
Working?
How and who's going to test it? Do glider testers now need a rolling road dyno to test the restriction of the brake? That's the only way to really test a wheel brake. If when pulling the lever a smell of hot brake shoes is emitted then the brake is 'working'. If the lever moves the brake shoes/pads into contact with the drum or disk the brake is 'working'. Ian |
I don't think there is any need for concern here for
several reasons. This is nothing new, just a re-statement of something that has been the rule for some time. Like many other rules set by the BGA it can be safely ignored, they don't have the bottle to enforce it. There are far worse things that go on that they are selectively blind to so why shoud this be a burning issue. The wheel brake on my ASW 17 will stop the wheel turning if operated in the workshop, very useful, pity it does not retard the glider at all on the ground run, not that I would want it to as with no nose wheel an effective brake is not a good idea. I would hasten to add that the brake 'works' as it was designed to do. My club has a K13 and I have never seen it with a wheel brake and I cannot think why anyone would fit one. I would like to see the BGA justify that having a wheel brake is an airworthiness issue when they ignore so many other more dubious practices. At 23:30 13 May 2005, W.J. \bill\ Dean \u.K.\. wrote: BGA Engineering News No. 30, May 2005 http://www.gliding.co.uk/bgainfo/tec...rs/technewsmay 05.pdf has a section on wheel brakes (at the end) which includes the following: ' If a glider was designed with a brake then it must have one fitted and working. ' If the glider has a main skid and can be stopped by using the skid then the wheel brake may be temporarily unserviceable provided it is recorded as a deferred defect, notified to the pilot and rectified at the earliest opportunity (i.e. within a day or so).' When Lasham first bought new K13s and K8s, one of the first things we did was to disconnect the wheel brakes. With the K8 the wheel brake hardly worked, and the front skid worked very well. With the K13, the brake soon stopped working at all well, and again the front skid works well. I saw a K13 Tost wheel with the maker's tag attached. It said, roughly, 'This wheel has a brake which is too small, because there is not room to fit one big enough. Do not use it unless you have to, you will need to adjust it every time you use it hard.' Lasham is of course a large flat site, and the K8 and K13 finish on the front skid even if the stick is held on the back stop during the ground run. Most of Lasham's present fleet of K13s were built with a front wheel instead of a skid, and have a disc brake which does work well. Is it possible to change the Tost drum brake wheel on a K13 to a disc brake? How much does it cost? How many club operated K13s have a Tost drum wheel brake which works well? Is it really unsafe to operate a K13 without a good wheel brake, relying on the front skid? Is it really unsafe to operate a K8 without a wheel brake? How much flying have those who wrote this ruling done in skidded K13s and in K8s? I have twice tried to post this to u.r.a.s., but both times it disappeared into cyberspace. W.J. (Bill) Dean (U.K.). Remove 'ic' to reply. |
The ASW17 as built has a K13 wheel, no surprise that it does not work.
ASW17s advertised in the USA used often to claim "Blanik wheel", so presumably this can be made to fit and works better. W.J. (Bill) Dean (U.K.). "Don Johnstone" wrote in message ... I don't think there is any need for concern here for several reasons. This is nothing new, just a re-statement of something that has been the rule for some time. Like many other rules set by the BGA it can be safely ignored, they don't have the bottle to enforce it. There are far worse things that go on that they are selectively blind to so why should this be a burning issue. The wheel brake on my ASW 17 will stop the wheel turning if operated in the workshop, very useful, pity it does not retard the glider at all on the ground run, not that I would want it to as with no nose wheel an effective brake is not a good idea. I would hasten to add that the brake 'works' as it was designed to do. My club has a K13 and I have never seen it with a wheel brake and I cannot think why anyone would fit one. I would like to see the BGA justify that having a wheel brake is an airworthiness issue when they ignore so many other more dubious practices. At 23:30 13 May 2005, W.J. \bill\ Dean \u.K.\. wrote: BGA Engineering News No. 30, May 2005 http://www.gliding.co.uk/bgainfo/tec...rs/technewsmay 05.pdf has a section on wheel brakes (at the end) which includes the following: ' If a glider was designed with a brake then it must have one fitted and working. ' If the glider has a main skid and can be stopped by using the skid then the wheel brake may be temporarily unserviceable provided it is recorded as a deferred defect, notified to the pilot and rectified at the earliest opportunity (i.e. within a day or so).' When Lasham first bought new K13s and K8s, one of the first things we did was to disconnect the wheel brakes. With the K8 the wheel brake hardly worked, and the front skid worked very well. With the K13, the brake soon stopped working at all well, and again the front skid works well. I saw a K13 Tost wheel with the maker's tag attached. It said, roughly, 'This wheel has a brake which is too small, because there is not room to fit one big enough. Do not use it unless you have to, you will need to adjust it every time you use it hard.' Lasham is of course a large flat site, and the K8 and K13 finish on the front skid even if the stick is held on the back stop during the ground run. Most of Lasham's present fleet of K13s were built with a front wheel instead of a skid, and have a disc brake which does work well. Is it possible to change the Tost drum brake wheel on a K13 to a disc brake? How much does it cost? How many club operated K13s have a Tost drum wheel brake which works well? Is it really unsafe to operate a K13 without a good wheel brake, relying on the front skid? Is it really unsafe to operate a K8 without a wheel brake? How much flying have those who wrote this ruling done in skidded K13s and in K8s? I have twice tried to post this to u.r.a.s., but both times it disappeared into cyberspace. W.J. (Bill) Dean (U.K.). Remove 'ic' to reply. |
Don Johnstone wrote:
The wheel brake on my ASW 17 will stop the wheel turning if operated in the workshop, very useful, pity it does not retard the glider at all on the ground run, not that I would want it to as with no nose wheel an effective brake is not a good idea. A friend of mine fitted his ASW 17 with a Cessna wheel and disk brake. It was very effective, and did not put the glider on it's nose. If I needed to use the brake hard enough to put a glider on it's nose, I'd gladly trade a scratched nose for running into something hard or expensive! -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Eric Greenwell wrote:
Don Johnstone wrote: The wheel brake on my ASW 17 will stop the wheel turning if operated in the workshop, very useful, pity it does not retard the glider at all on the ground run, not that I would want it to as with no nose wheel an effective brake is not a good idea. A friend of mine fitted his ASW 17 with a Cessna wheel and disk brake. It was very effective, and did not put the glider on it's nose. If I needed to use the brake hard enough to put a glider on it's nose, I'd gladly trade a scratched nose for running into something hard or expensive! Just be careful. I decided to make the Tost "Liliput" (you know why they called it that, don't you) wheel work on my Standard Cirrus. The amount of play and tiny components can make life exciting though. My approach was to methodically adjust the actuating lever on successive flights. Landing on a 1435m tar runway meant there was no risk of hitting anything, so it should have been safe to experiment. I went from having no effective retardation to a locked wheel and one of those expensive white stripes on the tar in one adjustment... Having now taken a close look, the bush on the actuator is worn, and the floating attachments move. I could fit a new wheel and have very little improvement - even purchased a new brake assembly, then discovered that they changed the bolt pattern for the locating arm. Currently the new brake is gathering dust and I simply ensure I don't point it at anything I may want to keep on the ground run... One of those Cleveland disk brake sets is looking better by the day. -- Bruce Greeff Std Cirrus #57 I'm no-T at the address above. -+- \_________0_________/ |
At 23:00 15 May 2005, Eric Greenwell wrote:
Don Johnstone wrote: The wheel brake on my ASW 17 will stop the wheel turning if operated in the workshop, very useful, pity it does not retard the glider at all on the ground run, not that I would want it to as with no nose wheel an effective brake is not a good idea. A friend of mine fitted his ASW 17 with a Cessna wheel and disk brake. It was very effective, and did not put the glider on it's nose. If I needed to use the brake hard enough to put a glider on it's nose, I'd gladly trade a scratched nose for running into something hard or expensive! -- Change 'netto' to 'net' to email me directly Eric Greenwell Washington State USA I have an answer for that, I don't point it at anything hard or expensive :-). As luck would have it the 17 is heavyish and most farmers fields in the UK are quite soft and so work on the gravel trap theory. I found the same problem as another poster, increasing the efficiency of the brake switched on white line drawing mode. |
On Fri, 13 May 2005 23:07:36 UTC, "W.J. \(Bill\) Dean \(U.K.\)."
wrote: : " If a glider was designed with a brake then it must have one fitted and : working. If they enforced this it would ground most of the wooden club gliders I have flown. Ian -- |
Last weekend I was at a very well known small club with two K13s, both with
front skids. Both had a wheel brake cable on the bottom of the airbrake handle, on both of them this cable was slack when the airbrake was fully open to the stop. I told them that both K13s should be grounded, and explained why. They just laughed, and said that they had always been like that. Later I was happy to fly in one of them, with the CFI; no problems. Beaurocracy, don't you love it! W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Ian Johnston" wrote in message news:cCUlhtvFIYkV-pn2-MsLI6ErB8BMG@localhost... On Fri, 13 May 2005 23:07:36 UTC, "W.J. \(Bill\) Dean \(U.K.\)." wrote: : " If a glider was designed with a brake then it must have one fitted and : working. If they enforced this it would ground most of the wooden club gliders I have flown. Ian |
| So I invested my US$6°°.....GUESS WHAT!!!... less than ten days later, I received money | [email protected] | Owning | 1 | January 16th 05 07:48 AM |
| Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 10:45 PM |
| 16 Aug 2004 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | August 17th 04 01:37 AM |
| 30 Jan 2004 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | January 31st 04 04:55 AM |
| Tailwheel endorsement | John Harper | Piloting | 58 | December 12th 03 02:48 PM |
