Does anyone know where I can lay my hands on an airport database with name,
ID, lat/long and elevation? I've found two from separate sources that are close, but each is missing at least one element that I'd like to have and I don't relish the thought of trying to merge them into one. -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic http://www.wizardofdraws.com More Cartoons with a Touch of Magic http://www.cartoonclipart.com |
airnav.com has one, as does landings.com.
Are you a member of AOPA?
If not, you should! By the way, they have have the aiport directory. They have everything you need, every detail to the bone. You can even download airport directory to the PDA. You can't beat that, unless you have the array of expensive equipment in your plane. Toks Desalu PP-ASEL "Dyin to soar!" "Wizard of Draws" wrote in message news:BEAD8615.6E996%jeffbTAKEOUTALLCAPS@TOEMAILwiz ardofdraws.com... Does anyone know where I can lay my hands on an airport database with name, ID, lat/long and elevation? I've found two from separate sources that are close, but each is missing at least one element that I'd like to have and I don't relish the thought of trying to merge them into one. -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic http://www.wizardofdraws.com More Cartoons with a Touch of Magic http://www.cartoonclipart.com |
For data, check out http://www.sarangan.org/aviation/garmin/ and also
http://navaid.com/GPX/ http://www.cockpitgps.com/ gives a good introduction to use of handhelds... Regards from ENZV "Wizard of Draws" wrote in message news:BEAD8615.6E996%jeffbTAKEOUTALLCAPS@TOEMAILwiz ardofdraws.com... Does anyone know where I can lay my hands on an airport database with name, ID, lat/long and elevation? I've found two from separate sources that are close, but each is missing at least one element that I'd like to have and I don't relish the thought of trying to merge them into one. -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic http://www.wizardofdraws.com More Cartoons with a Touch of Magic http://www.cartoonclipart.com |
In a previous article, "Christian" said:
For data, check out http://www.sarangan.org/aviation/garmin/ and also http://navaid.com/GPX/ GPX might be a bit hard to parse, but with the help of GPSBabel ( http://gpsbabel.sourceforge.net/ ), you can turn that GPX file into a CSV (comma separated values) or other standard ascii file that you can import into Excel or whatever you want to do with it. -- Paul Tomblin http://xcski.com/blogs/pt/ Disclaimer: "These opinions are my own, though for a small fee they can be yours too." |
On Sun, 15 May 2005 23:04:53 -0400, Wizard of Draws
wrote in BEAD8615.6E996%jeffbTAKEOUTALLCAPS@TOEMAILwizardo fdraws.com:: I've found two from separate sources that are close, but each is missing at least one element that I'd like to have and I don't relish the thought of trying to merge them into one. Of course, UNIX contains the ideal tool for merging databases and manipulating fields within a database: awk. And there's even an awk executable for Windows available he http://cm.bell-labs.com/cm/cs/awkbook/index.html or http://cm.bell-labs.com/cm/cs/who/bwk/ And you'll find a manual page for awk he http://www.mkssoftware.com/docs/man1/awk.1.asp |
Wizard of Draws wrote in
news:BEAD8615.6E996%jeffbTAKEOUTALLCAPS@TOEMAILwiz ardofdraws.com: Does anyone know where I can lay my hands on an airport database with name, ID, lat/long and elevation? I've found two from separate sources that are close, but each is missing at least one element that I'd like to have and I don't relish the thought of trying to merge them into one. The most complete raw data is http://aviationtoolbox.org/raw_data/FAA/ATA- 100/ |
Wizard of Draws wrote: Does anyone know where I can lay my hands on an airport database with name, ID, lat/long and elevation? I've found two from separate sources that are close, but each is missing at least one element that I'd like to have and I don't relish the thought of trying to merge them into one. -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic=81 http://www.wizardofdraws.com More Cartoons with a Touch of Magic=81 http://www.cartoonclipart.com DAFIF https://164.214.2.62/products/digitalaero/index.cfm it's what most PC based flight planners, simulators, etc... run off of |
On 5/16/05 7:21 AM, in article , "Paul
Tomblin" spewed: In a previous article, "Christian" said: For data, check out http://www.sarangan.org/aviation/garmin/ and also http://navaid.com/GPX/ GPX might be a bit hard to parse, but with the help of GPSBabel ( http://gpsbabel.sourceforge.net/ ), you can turn that GPX file into a CSV (comma separated values) or other standard ascii file that you can import into Excel or whatever you want to do with it. Thanks guys. This looks like my best bet since I'm on a Mac. I just need a basic CSV file to import into my Filemaker Pro logbook. I'm trying to learn the program and a logbook with flight time, currencies, insurance and medical info, E6B and airports seemed like a useful way. Since I'm not that good with math, my head hurts. -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic http://www.wizardofdraws.com More Cartoons with a Touch of Magic http://www.cartoonclipart.com |
| WI airport closure | Mike Spera | Owning | 0 | March 9th 05 02:53 PM |
| NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 06:12 AM |
| N94 Airport may expand into mobile home community, locals supportive | William Summers | Piloting | 0 | March 18th 04 04:03 AM |
| Rules on what can be in a hangar | Brett Justus | Owning | 13 | February 27th 04 06:35 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
