Hi all,
Back into aircraft ownership, this time I was able to go whole four months without an airplane ! After owning couple Cessnas, I got hold of a '56 PA-23-150 project, completely stock except for newer radios, cleveland wheels, and the (Horton ?) tips. My friend and I are going through a partial restoration, its been a lot of fun. Engines and props are good, had to do the flap torque tube AD, all new tires, generator bracket & belt, rebuild two struts, bunch of new seals, o-rings, etc, etc. So... just curious if there are any other Apache pilots in the NG. All the old timers at the field stop by the hangar periodically and reminisce about flying these machines. We really have it apart and I've been nothing short of impressed by the workmanship and effort that must have gone into building the thing. I've never flown twins (ok, this is more of a two-part 300hp engine ;-), but after doing a ground runup with fistful of throttles, there is really no going back, is there... Martin |
My partners and I all did our initial MEL in a 23-150... shopped hard for
one until we realized that we really wanted something with more payload. Stepped up to a '66 Aztec, and even though it drinks almost twice the fuel of it's little brother, we love it so far. As far as the workmanship and effort, the way some of the cables and wires are routed, they went through a lot of effort but basically it's a tube frame that they wrapped aluminum around and said, "Hey, put a screw or ten in it, that should hold it." Built like a brick-s*t house for guys with strong wrists or electric screwdrivers. Sounds like you're already up to speed on several of the AD's, other things to watch for include Leaky hydraulic power pac Janitrol or Southwind heater AD's, lots of info and parts at www.aircraftheater.com old or dried out fuel bladders Hartzell prop and hub AD's 50 hour AD for fuel leakage inspection 100 hour ADs for fuel valve inspection, engine mounts, exhaust cracks Outboard flap hinge inspection You may want to consider dual generators and electric fuel pumps or even an electric back up hydraulic pump as long as you have everything torn a part. Copper battery cables would also be on my list, makes starting less strenuous on the 12v battery. I'm sure Denny can fill you in on more. Jim "omk" wrote in message oups.com... Hi all, Back into aircraft ownership, this time I was able to go whole four months without an airplane ! After owning couple Cessnas, I got hold of a '56 PA-23-150 project, completely stock except for newer radios, cleveland wheels, and the (Horton ?) tips. My friend and I are going through a partial restoration, its been a lot of fun. Engines and props are good, had to do the flap torque tube AD, all new tires, generator bracket & belt, rebuild two struts, bunch of new seals, o-rings, etc, etc. So... just curious if there are any other Apache pilots in the NG. All the old timers at the field stop by the hangar periodically and reminisce about flying these machines. We really have it apart and I've been nothing short of impressed by the workmanship and effort that must have gone into building the thing. I've never flown twins (ok, this is more of a two-part 300hp engine ;-), but after doing a ground runup with fistful of throttles, there is really no going back, is there... Martin |
Like Jim, I am an Aztec owner. Mine is a '64C model. Big
brother of the Apache with the same PA23 designator. Welcome to twin-land. The fist full of throttles is fun to fly but it looses some of its attractivness every time I stop for fuel :-) "Jim Burns" wrote in message ... My partners and I all did our initial MEL in a 23-150... shopped hard for one until we realized that we really wanted something with more payload. Stepped up to a '66 Aztec, and even though it drinks almost twice the fuel of it's little brother, we love it so far. As far as the workmanship and effort, the way some of the cables and wires are routed, they went through a lot of effort but basically it's a tube frame that they wrapped aluminum around and said, "Hey, put a screw or ten in it, that should hold it." Built like a brick-s*t house for guys with strong wrists or electric screwdrivers. Sounds like you're already up to speed on several of the AD's, other things to watch for include Leaky hydraulic power pac Janitrol or Southwind heater AD's, lots of info and parts at www.aircraftheater.com old or dried out fuel bladders Hartzell prop and hub AD's 50 hour AD for fuel leakage inspection 100 hour ADs for fuel valve inspection, engine mounts, exhaust cracks Outboard flap hinge inspection You may want to consider dual generators and electric fuel pumps or even an electric back up hydraulic pump as long as you have everything torn a part. Copper battery cables would also be on my list, makes starting less strenuous on the 12v battery. I'm sure Denny can fill you in on more. Jim "omk" wrote in message oups.com... Hi all, Back into aircraft ownership, this time I was able to go whole four months without an airplane ! After owning couple Cessnas, I got hold of a '56 PA-23-150 project, completely stock except for newer radios, cleveland wheels, and the (Horton ?) tips. My friend and I are going through a partial restoration, its been a lot of fun. Engines and props are good, had to do the flap torque tube AD, all new tires, generator bracket & belt, rebuild two struts, bunch of new seals, o-rings, etc, etc. So... just curious if there are any other Apache pilots in the NG. All the old timers at the field stop by the hangar periodically and reminisce about flying these machines. We really have it apart and I've been nothing short of impressed by the workmanship and effort that must have gone into building the thing. I've never flown twins (ok, this is more of a two-part 300hp engine ;-), but after doing a ground runup with fistful of throttles, there is really no going back, is there... Martin |
So... just curious if there are any other Apache pilots in the NG. All the old timers at the field stop by the hangar periodically and reminisce about flying these machines. We really have it apart and I've been nothing short of impressed by the workmanship and effort that must have gone into building the thing. Martin Not an owner, but helped a local school get one up off the ground recently. See attached picture. Story goes like this: SETTING Student and Instructor in parked Aztec with engines running. Instructor reading down checklist gets to "Gear down and locked". Kid in pilot seat "Gear down and locked" at which he promptly reaches over and pulls the gear handle UP! Instructor hearing the warning klaxon as the gear starts going up -- reaches over and pulls the mixture on both engines. As the left one (with the pump on it) winds down, the gear stops retracting. JUST in time to keep the props from striking. Turns out the safety switch (that is supposed to keep that from happening) wasn't working and probably hadn't been checked in years. We got it back up and pumped the gear down. Copilot side wouldn't lock down. Turns out it bend a brace up at the top that had to be sent to California to get straightened. But that was all the damage (besides of course, the student's embarrassment and the school's wallet for the repairs). I mention it so you will be sure to check those locking cams, the "locked-in" indicator switches, and the safeties. Enjoy her after the refurb... Chuck Cherokee-180 7498W |
Martin Woops, Forgot to attach the picture. Chuck |
Martin, Fat Albert is a 1957 Apache... Serial number 23-969... The
guys have pretty well covered the gotchas in their posts... The flap torque tube AD is a killer because you have to extract it, drill out the rivets, dye penetrate, etc., every year... After a couple of times you will go looking for non AD parts... The steel torque tube itself is not too bad a hit on the wallet - though everything for airplanes is ten times overpriced... The torque arm is the killer - Piper wanted $1600 for a dash-6 arm... I lucked out and found a used one for half that... So, that AD has gone away... The annoying part is that the failures have been in planes that were abused, dumping full flaps above the white arc, etc., yet we have to pay the piper (pun intentional) for their behavior... The hub/blades AD is recurrent... Someday you will belly up to the bar for a non AD set... I've been happy with mine and the big spinners make it look good... Fat Albert has been putting on airs every since he got the new blades, thinks he is a mini airliner now... The heater is another issue as the guys pointed out... If you are in a warmer part of the country, just cobble it up and keep it going... If the fire tube is cracked then you are at the cross roads between overhaul and new... I chose to spring for a new C&D heater (gorgeous stainless can) with a warranty - living where I do at the 45th parallel.... The guys did forget the rudder hinge, dye penetration AD... Important, especially if the airplane has set out in the weather with the rudder banging around... If your plane doesn't have the dorsal fin and wing fairings on the inside engine cowlings, get them and install... Night and day difference in engine out handling... Beyond that, it is only the usual problems of flying old iron... So grab yourself a fist full of throttles and feel like a real man.... denny |
Chuck wrote:
Instructor hearing the warning klaxon as the gear starts going up -- reaches over and pulls the mixture on both engines. As the left one (with the pump on it) winds down, the gear stops retracting. JUST in time to keep the props from striking. He's lucky it wasn't a Navion. On the Navion, the engine driven pump will develop enough power to drop her on her nose from just the starter spinning the engine with the handle in the UP position. I know of only one Navion with a squat switch, the plane wasn't designed with one. |
Chuck wrote:
Martin Woops, Forgot to attach the picture. Chuck Most of us won't be able to see it. Most news servers strip pictures. Suggest you put it on a website (like a free geocities site) and provide a link. |
Denny,
Thanks for the reply - saw your plane on Jay's site, looks very nice ! We are replacing the torque tube w/ steel, the bellcrank is an obnoxious one, and they are really proud of p/n 16423-06, $1695 list now! I'll try to find a used one, it would be nice to avoid all that floor disassembly next time... If you have any good sources for used parts, I would appreciate a reference, too. I've been in touch with John Lumley down in Florida (The Flying Apache Assoc.), he is a great resource, too. We do have the nacelle fairings installed, but not the fin. I've been looking at those, not sure I want to do the whole square rudder, but looks like Diamond Aire sells just the dorsal is that what you have ? Any measurable SE performance gain ? Thanks, Martin |
Good story !
I don't think there is a "switch", just a valve on the left gear that causes the fluid to bypass the actuators when the strut is compressed. I didn't know about this and spent a good hour "troubleshooting" the gear when the airplane was jacked up, wheels off (no weight to extend the deflated strut). Anyway, at least I know it *is* working ! :-) Martin |
| Thread Tools | |
| Display Modes | |
| Apache helicopter brought down | Richard | Military Aviation | 0 | April 11th 04 11:20 AM |
| Apache crews sharpen gunfighting skills | Otis Willie | Military Aviation | 0 | January 12th 04 12:45 AM |
| UK pilots start Apache training | Otis Willie | Military Aviation | 0 | September 13th 03 11:37 PM |
| Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 10:25 AM |
| Early Bonanza or Apache? | Brinks | Owning | 11 | July 16th 03 07:01 PM |
