Key Locks -- Part II
Old May 17th 05, 02:01 PM
Jay Honeck
Default Key Locks -- Part II
After reading the other posts about key locks, the responses brought another
question to mind.
My key ignition switch works very hard, and the key can be removed in any
position. It's hard to push it in and keep the starter engaged (it's one
of those turn-while-you-push switches), so we usually end up pushing it
several times to get the engine started.
Can that ignition switch be dismantled and repaired, or is this a
"replace-only" job?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 17th 05, 03:21 PM
Jay Honeck wrote:
: Can that ignition switch be dismantled and repaired, or is this a
: "replace-only" job?
Unlikely to be repairable without some questionable dissasembly. Those
switches are usually made with little metal tabs bent to hold on the back plate
insulator. The tabs have to be be unbent to remove, and then rebent to reinstall.
There's probably some impressive spring assembly in there, as well (to take care of
the rotational spring, and the push-in spring).
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old May 17th 05, 03:29 PM
Ron Natalie
"replace-only" job?
I had a similar problem with mine (the key would actually FALL OUT)
in flight and it would appear to be in the OFF position and still
leave one MAG hot. I just replaced the blasted thing. A new bendix
switch wasn't that much. My ignition key didn't match the canopy
or baggage compartment locks anyhow.
Old May 17th 05, 03:32 PM
Jay Honeck
Now, for the real question:
Do I have to get this part from Piper (for big $$$), or can I use the
(apparently identical) switch shown in the Aircraft Spruce catalog?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old May 17th 05, 05:54 PM
Michelle P
Jay,
If the part is TSO or PMA with equiv part number it is fine.....
Michelle
question to mind.
"replace-only" job?
Old May 17th 05, 09:16 PM
Robert M. Gary
You may actually have an AD that requires you to replace the mag
switch. I had to replace mine two years ago after a shop showed me an
AD that says it must be replaced if the key can be removed in flight. I
have no idea why the hell such an AD exists.
-Robert
Old May 17th 05, 09:17 PM
Robert M. Gary
It must have a TSO or STC. If the TSO lists your aircraft then you are
good to go. I would be surprised if this isn't the case.
-Robert
Old May 17th 05, 09:34 PM
Jim Burns
I was trying to remember just what that AD was about. I remember reading it
a couple years ago, but do not know why. Wasn't there something in the AD
about the switch malfunctioning and actually leaving one or both mags hot
when the switch was turned to off in addition to the key comeing out? Seems
like I also remember an inspection and lubrication requirement.
Maybe I was just dreaming.
-Robert
Old May 17th 05, 10:50 PM
nrp
There also was a part of that AD that required an operational test in
which the key is forcefully (no torque spec but plenty aggressively)
turned CCW beyond OFF to see if the engine keeps running. Some
aircraft including our 172M, would relight again.
A new switch wasn't that expensive about 5 years ago (like $100). It
came as part of a kit replacing all of the locks in the airframe. The
tumbler setup and key etc was more robust that the Cessna OEM key.
Old May 17th 05, 10:58 PM
Jim Burns
AH!! That's where I read it... when studying for my CFI ride in a 182RG.
Thanks!
"nrp" wrote in message
ps.com...
Airman Finds True Calling as Part of 'Best Force' Otis Willie Military Aviation 0 September 11th 04 12:18 AM
BergFalke II/55 part. Bruce Greeff Soaring 2 May 12th 04 03:32 PM
commercial privileges Gary Drescher Piloting 32 February 27th 04 03:42 AM
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. Larry Dighera Piloting 0 February 22nd 04 04:58 PM
Part 91 Commercial Glider Rides to be Outlawed? Vaughn Soaring 9 October 27th 03 10:26 PM
