2-stroke diesel is the (near) future?
Old May 18th 05, 06:29 PM
Sport Pilot
Stuart & Kathryn Fields wrote:
We own a 2003 Jetta TDI and it poops out before it gets to 4500.
However, it
goes uphill at 80mph gaining speed at around 2500RPM. BTW. Hp=
Torque X
RPM. If your 100hp engine peaks at 2500 rpm and your 200horse engine
peaks
at 7500 rpm, the 100hp engine has to develop 1.5 times more torque
than your
200hp engine at the peak hp rpm.
Stuart Fields
Experimental Helo magazine
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478
(760) 408-9747 general and layout cell
(760) 608-1299 technical and advertising cell
www.vkss.com
www.experimentalhelo.com
"Steve" wrote in message
Sport Pilot wrote:
Steve wrote:
Sport Pilot wrote:
Diesel fuel is not conducive to high speed running. Nor is a
long
injection period through much of the expansion phase. Yes you
can
boost the turbocharger and the other things, but an Otto cycle
engine
will respond with even higher speeds. Parts failure from speed
is
not
a problem with diesel engines, the rotating parts have to be
bigger
than an otto engine because of the higher compression, yet the
otto
engine will turn higer RPM's with smaller parts.
All of the above is true in the common practice of diesel design,
but
none of it is necessarily true. There is nothing FUNDAMENTAL that
limits
a diesel to low-RPM designs only. One can build a screaming
high-RPM
diesel with light-weight rotating parts, but one would have to
ask
"why?" Gasoline engines are made high-revving in order to
increase
power
output from a small package, but diesels can develop a lot more
low-RPM
torque through high boost because they don't detonate when
"lugged,"
so
there's no NEED to make them scream. If you need more power,
don't
spin
them faster, just boost them harder. High RPM is an aggravation,
not
an
advantage (no matter what Honda VTEC drivers think...).
Actually diesels don't really deliver that much torque at similar
speeds. Ok they do but only because the valving is timed for the
slower speeds. Many gasoline tractor engines will diliver
similar
torque, but with a higher fuel consumption due to the lower
compression
ratio.
It depends on what you're comparing to. A lot of tractors use
normally-aspirated indirect-injection diesels, which are no
comparison
to a turbocharged diesel. Or to a good normally-asipirated gasoline
engine, except in terms of longevity. Gasoline engines are hard to
beat
for the *width* of their torque curve, but modern turbo-diesels do
a
good job against them, and do so with better efficiency.
Diesel fuel burns slower and will knock when the injection
timing is shortened to allow higher speeds.
Higher speed requires more than just rapid injection, it also
demands
higher boost pressure, which causes the fuel to burn faster without
any
knock-like phenomenon. All serious diesels are turbocharged for
that
reason (as well as others), and normally-aspirated diesels are
limited
to very small power outputs and relatively low efficiency. You can
only
get so much combustion chamber pressure through the compression
ratio of
the engine- the rest has to come from forced induction. As someone
pointed out earlier, the VW TDI develops power up to 4500 RPM,
which is
comparable to many gasoline engines, but it is able to do so only
because it is a turbo-diesel. As I said before, there's no reason
that
building a 7000-RPM diesel isn't possible, but there's no REASON to
build one.
I think most of us know that torque is only a force and you need speed
(RPM) to develop power. More speed is more power. Or was there some
other point you are trying to make?
  #92
Old May 18th 05, 10:09 PM
Steve
II think the point is that there are TWO ways that do an equally good
job of increasing power. More TORQUE is more power too.
Since power=K*Torque*RPM, the result is that if you hold the speed
constant and double the torque, you get double the power. There are
diesel engines in this world that develop 20,000 horespower at only 150
RPM. Naturally, the torque value is astronomical. No, they don't fly.
;-) They swim.
  #93
Old May 24th 05, 03:52 PM
Sport Pilot
Steve wrote:
speed
some
150
;-) They swim.
Why the obvious apple and orange comparision? I can show you a model
diesel engine of less than 1/2 cubic engine that turns about 10,000
RPM? So what. A large engine is going to turn less RPM because of its
rotation mass. You need to compare engines of equal size. The model
diesel engines will not turn as fast as the gas or methanol/nitro
engines because the fuel (ether and kerosene) will not burn as fast.
But they will put out more torque than the other two types, though only
marginally more than gasoline. This is because the fuel burns slower,
not because of the cycle, because all, the spark ignition gas engine,
the glow plug methanol/nitro engine, and the compression ignition
engine, are actually otto cycle engines.
  #94
Old May 24th 05, 10:41 PM
Steve
To refute the statement that "more speed is more power."
OK, Lets do it!
Dodge 5.9 Liter v8 gasoline engine: 230 horsepower at ~5000 RPM
Compared to:
Dodge/Cummins 5.9 Liter turbo-diesel engine: 325 horsepower at 2900 RPM
More speed is NOT more power any more than more torque at the same speed
is more power.
  #95
Old May 24th 05, 10:48 PM
Steve
Sport Pilot wrote:
The model
I say again: there is no magic rule that says "diesel burns slower" than
gasoline. Increasing the boost pressure can increase the burn rate AS
MUCH AS YOU WANT. Its just not done most of the time, because no one
WANTS a 7000 RPM engine when a 4000 RPM engine is available to do the
same job. People only build 7000 RPM engines when there's no other way
to get the power.
No, that's already been covered. Diesel (true diesel with either direct
or pre-chamber injection) is a subtly different cycle than the Otto
cycle. Its constant-pressure combustion instead of constant-volume
combustion.
  #96
Old May 24th 05, 10:54 PM
Thomas Tornblom
Steve writes:
OK, Lets do it!
Compared to:
uh?
More torque at the same speed *is* more power.
power = torque * speed
Had the gas engine produced the same torque at 5000 rpms as the diesel
do at 2900, then it would have had about 560 hp at 5000.
Thomas
  #97
Old May 24th 05, 11:27 PM
Steve R.
"Thomas Tornblom" -to-reply wrote in message
Steve writes:
uh?
Yeah, that was my reaction! (?) ;-)
Thomas
Actually, the equation to calculate power (or horsepower (HP) in this case)
is HP = Torque X rpm / 5252.
Torque being a measurable force that turns the crankshaft and ultimately the
wheels, main rotor, or propeller (I just noticed that this is going to two
aviation and one automotive newsgroups). Horsepower is defined as a
"measurement" of work performed. By the equation, at least as it applies to
internal combustion reciprocating engines, you can't have HP without torque!
So, if you can increase the torque value at a given rpm, you'll increase the
power output at that rpm. Likewise, if you can maintain a given torque
value at a higher rpm, you'll produce more power in that case too. It
doesn't matter what kind of engine you're talking about or the fuel burned.
Gasoline, diesel, methanol, it makes no difference. The equation still
applies.
FWIW!
Fly/Drive Safe,
Steve R.
  #98
Old May 25th 05, 02:02 AM
Sport Pilot
OK, Lets do it!
Compared to:
is more power.
Steve,
As you said power is torque * RPM, so for the same torque more speed
is power. In fact with 0 RPM you have no power only a force. No I
have not argued that desiels cannot deliver power by increasing torque.
Only that their inherent design and fuel limits their maximum speed.
Your example is a poor one most diesels of equivelant size will deliver
more torque at less RPM and have less total horsepower. I don't know
where you found that pitiful Dodge 5.9 liter engine. I have a 4.7 V8
in my Grand Cherokee and it puts out 260+ HP. I know that the 5.7
Liter hemi V8 puts out about 320 or so HP and it is not turbocharged.
So that is a more equal comparison. Unlike the apple orange examples
you put up.
  #99
Old May 25th 05, 02:21 AM
Sport Pilot
Steve wrote:
Sport Pilot wrote:
The model
to get the power.
combustion.
I was not quite correct if I said desiel fuel burns slower, it is
however made to ignite better with desiel engines so that the fuel
ignites spontanously when injected. The fuel burns slower because it
is injected over a period of time. However, I may have been correct
about the model fuel. There are diesel conversion heads for model glow
engines. This replaces the head and glow plug with a head with a
varible compression. You adjust the timing by adjusting the
compression. The fuel is a mix of kerosene, ether, amyl nitrate, and
oil. This fuel will ignite at a much lower temperature than true
desiel fuel. The ether and amyl nitrate are the componets which ignite
at a low temp. Though ether is extremely volatile it is not a very
high energy fuel and I think it burns slowly. These converted engines
will turn large propellers at slower speeds than the glow engines they
were converted from.
Another example of a high energy fuel that limits speed is
nitromethane. Because it is a monopropellent the racers can pretty
much inject as much as their ignition can ignite, except for
hydrolocking. That is if more fuel is injected than the combustion
chamber volume the engine will blow up. But nitro burns slowly so RPM
is more or less limited to just over 10,000 RPM loaded. The slow
burning is why you see huge flames coming out the exhaust.
  #100
Old May 25th 05, 04:14 AM
On Tue, 24 May 2005 21:54:29 GMT, Thomas Tornblom
-to-reply wrote:
Steve writes:
OK, Lets do it!
Compared to:
One BIG factor is being forgotten here. The diesel is turboed. This
makes it roughly equivalent to an 8 liter engine at about 6psi boost.
Any combustion engine produces power in proportion to the amount of
air consumed. On a diesel it does not necessarily "consume" all the
air that goes through it - but the maximum power output is definitely
limitted by how much air can be put through it. A turbo can eisily
double the amount of air an engine pumps through it at a given speed.
Running an engine at double the speed also increases the amount of air
going through the engine - not quite double due to reduced volumetric
efficiency at speed.
Double the CFM gives double the horsepower, before factoring in
frictional losses and / or pumping losses.
A naturally aspirated diesel engine generally produces less HP per
unit of displacement, but more torque at low RPMs due in part to less
pumping loss (no air throttle)
uh?
Thomas
BSFC vs gas mileage, 2 stroke vs 4 stroke Jay Home Built 10 August 24th 04 02:26 PM
Diesel Jodel information..........and .........diesel plane groups Roland M Home Built 1 January 4th 04 04:04 AM
Diesel Jodel information..........and .........diesel plane groups Roland M General Aviation 1 January 4th 04 04:04 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M General Aviation 2 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 12:44 AM
