On Thu, 19 May 2005 19:20:48 +0100, Peter wrote:
Hi, Someone has lost the red "disconnect" button onmy KFC225 autopilot. Honeywell want a lot of money for a whole new switch. Would anyone know who makes this switch? It looks like a standard pushbutton switch, with a button about 9mm diameter. I could make a new button easily enough if I knew the thread used in the centre of the button (the button has a male screw on it). It certainly isn't metric. If you _know_ it's not metric, it's probably 4-40 or 6-32. These are standard thread sizes in that size of stuff. I've seen those buttons before, so I'm pretty confident about that. Are you in a metric-only country? The switch manufacturer is probably one of the well known names... Any info would be much appreciated. One of these links might have some useful info: http://www.google.com/search?q=pushbutton+switch Good Luck! Rich |
On Thu, 19 May 2005 21:39:25 GMT, Rich Grise
wrote: On Thu, 19 May 2005 19:20:48 +0100, Peter wrote: Hi, Someone has lost the red "disconnect" button onmy KFC225 autopilot. Honeywell want a lot of money for a whole new switch. Would anyone know who makes this switch? It looks like a standard pushbutton switch, with a button about 9mm diameter. I could make a new button easily enough if I knew the thread used in the centre of the button (the button has a male screw on it). It certainly isn't metric. If you _know_ it's not metric, it's probably 4-40 or 6-32. These are standard thread sizes in that size of stuff. I've seen those buttons before, so I'm pretty confident about that. Are you in a metric-only country? The switch manufacturer is probably one of the well known names... Any info would be much appreciated. One of these links might have some useful info: http://www.google.com/search?q=pushbutton+switch Good Luck! Rich Hmmm....I must be out of sorts. A person needs a button with a male thread. He could make it himself if he knew the size. The makers price is too high. He wants someone like Rich to tell him the thread size. Have I got the facts right so far? So the hardware store has some screws at 5 cents each or so for him to try. Let's say he might buy 5 different sizes. That's a quarter. Is that getting too costly, already? Brian (sour-grapes) Whatcott, Altus, OK |
On Fri, 20 May 2005 16:30:52 +0000, Brian Whatcott wrote:
On Thu, 19 May 2005 21:39:25 GMT, Rich Grise wrote: On Thu, 19 May 2005 19:20:48 +0100, Peter wrote: Someone has lost the red "disconnect" button onmy KFC225 autopilot. Honeywell want a lot of money for a whole new switch. Would anyone know who makes this switch? It looks like a standard pushbutton switch, with a button about 9mm diameter. I could make a new button easily enough if I knew the thread used in the centre of the button (the button has a male screw on it). It certainly isn't metric. If you _know_ it's not metric, it's probably 4-40 or 6-32. These are standard thread sizes in that size of stuff. I've seen those buttons before, so I'm pretty confident about that. Are you in a metric-only country? The switch manufacturer is probably one of the well known names... Any info would be much appreciated. One of these links might have some useful info: http://www.google.com/search?q=pushbutton+switch Hmmm....I must be out of sorts. A person needs a button with a male thread. He could make it himself if he knew the size. The makers price is too high. He wants someone like Rich to tell him the thread size. Have I got the facts right so far? So the hardware store has some screws at 5 cents each or so for him to try. Let's say he might buy 5 different sizes. That's a quarter. Is that getting too costly, already? No, it's just that in the UK, inch parts (apparently) are kind of few and far between. Didn't they used to refer to them as "English" vs metric? Ironic, ain't it? :-) The existing shaft on the switch has a male threaded stud. The button (or knob) needs a female thread. But I'd think that even in UK, there's _somebody_ _somewhere_ who has a 4-40 nut or a 6-32 nut on hand, just to check. As Peter said, if he knows the thread size, he can make a button. According to http://www.csgnetwork.com/screwinfo.html , A #4 screw is about .112" OD, which is mumble-mumble millimeters - whaddaya, multiply by 25.4? And #6 is .138". The -40 or -32 is just number of threads per inch, which divided by 25.4 is number of threads per millimeter. With a magnifier and decent scale, it's trivially easy to measure them. He could theoretically even get the right sized tap, and just drill and tap a piece of plastic. What would international mail be on a 2-ounce, $3.00 tap? For that matter, he could make a little form, add some mold release, and pour some epoxy into it and make a knob in place. Cheers! Rich |
On Sat, 21 May 2005 09:08:10 +0100, Peter wrote:
Rich Grise wrote The existing shaft on the switch has a male threaded stud. The button (or knob) needs a female thread. But I'd think that even in UK, there's _somebody_ _somewhere_ who has a 4-40 nut or a 6-32 nut on hand, just to check. As Peter said, if he knows the thread size, he can make a button. It certainly isn't 4-40 (which I assume is 4-40 UNC, same as commonly used on D-connector male screwlocks) as that is too big. The thread OD is slightly less than 3mm. Oh, dear. That's a tiny little bugger. I was thinking of the ones I'd seen many years ago, in the US military. For what it's worth, the next smaller common sizes are 3-48 and 2-56, but I imagine you've looked them up by now. Sure I could get some screws... BTW the price of the whole switch was quoted at US$72... but this is AVIATION Naturally, it would come with a batch number and an 8130-3form with a nice rubber stamp on it. Yeah, for that price, at least in my case, it's worth doing a little bit of sculpture or what-not. Do they have "Sculpey" over there? It behaves a lot like modeling clay (which I believe the Brits call "plasticine"), but when you mold it to the shape you want, you can bake it and it hardens to the consistency of bulk HDPE, or a little harder. I'm also a little surprised that by this time somebody hasn't come up with a knob from their junque box and dropped it in an envelope yet. Good Luck! Rich |
I bet they have one at SkyCraft Parts and Surplus in Winter Park
Florida. email me a good closeup picture of the unit or the switch. |
| Thread Tools | |
| Display Modes | |
| Slaving autopilot to a VOR? | Jay Honeck | Owning | 22 | May 29th 04 07:09 PM |
| mitchell autopilot | dave | Owning | 1 | May 5th 04 07:11 PM |
| IMC without an autopilot | Jon Kraus | Instrument Flight Rules | 101 | April 18th 04 08:17 PM |
| Chelton AP-3C autopilot | Kyler Laird | Owning | 0 | April 2nd 04 04:08 PM |
| KAP140 Autopilot Details | News | Instrument Flight Rules | 27 | October 22nd 03 03:01 AM |
