Canoe pontoons?
Old August 8th 03, 05:26 AM
Scott Marquardt
Default Canoe pontoons?
Has anyone done it? I did the obligatory google search, and found nothing
in 20 seconds (so it must not exist, right? ;-) Obviously, though, I'm not
the first idiot to think of it.
I'd like to see a light plane with canoes for pontoons. There'd be vertical
tubes that would drop down (think a pickup truck camper's vertical supports
for when you don't have the pickup under it), so you could taxi to shore,
jack down the tubes (broad plates on the bottoms for mud?), and detach the
canoes. Go fishing for the day, then re-attach the canoes, jack up the
tubes and take off.
Am I nuts? I suppose someone's going to tell me that it'd be easier to
convert a pontoon to something that could double as an inefficient canoe.
;-D
The big hazard is an obvious one, but what the heck. There's gotta be a
way.
- Scott
Old August 8th 03, 05:32 AM
Bernie the Bunion
Am I nuts?
Beats me, but why don't you contact Jesse James from
the TV show Monster Garage and ask him to consider
a conversion as one of the show's projects.
Old August 8th 03, 05:44 AM
Scott Marquardt
Am I nuts?
No, for them I'd suggest trying to get one of these to fly:
http://www.zorb.com/thumbnails.htm
- Scott
Old August 8th 03, 06:59 AM
Del Rawlins
On 07 Aug 2003 08:26 PM, Scott Marquardt posted the following:
nothing in 20 seconds (so it must not exist, right? ;-) Obviously,
though, I'm not the first idiot to think of it.
Nope, you're not. 8^) Idiot is a stronger term than I would have used,
though.
vertical tubes that would drop down (think a pickup truck camper's
vertical supports for when you don't have the pickup under it), so you
could taxi to shore, jack down the tubes (broad plates on the bottoms
for mud?), and detach the canoes. Go fishing for the day, then re-
attach the canoes, jack up the tubes and take off.
The main problem is that a canoe is a displacement hull, while you need
the pontoons to be planing hulls with a step. As I understand it, the
faster you push a displacement hull, the further into the water it wants
to dig, until it reaches its hull speed, which is the fastest you can
make it go. A planing hull is designed specifically to ride (plane) on
top of the water's surface at high speed, which will allow you to reach
a suitable speed for takeoff. The "step" allows the hull to rise
further out of the water than if the entire bottom surface was flat,
decreasing drag so that you can get off the water.
By the time you modified the canoes to act as planing hulls and added a
step, there wouldn't be much of the original metal left. Probably
easier to start from scratch.
canoe. ;-D
Even if it were possible, you wouldn't want to try to remove a float in
the field. Normally, when aircraft are switched between floats and
wheels a large hoist or crane is used to raise it high enough in the air.
If you are content with an inefficient canoe, carry an inflatable and
folding paddles with your baggage. You should always have a paddle in
your floatplane anyhow. Alternately, lots of canoes are carried as
external loads on float rigging, if your plane is big enough. Beware, a
buddy of mine who flies floats says external loads can do goofy things
to the handling qualities/performance.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Old August 8th 03, 07:08 AM
tubes and take off.
IIRC, many folks just lash a regular canoe to the floats. Best of both
worlds, there....
Old August 8th 03, 09:43 AM
Bushy
I plan on building a Storch so I can go fishing out the window,
'cause I get seasick, but I don't get airsick!
Peter
Old August 8th 03, 03:38 PM
Rich S.
"Bushy" wrote in message
Peter
How large of a sinker do you need to troll at 40 mph?
Rich S.
Old August 8th 03, 04:24 PM
Morgans
"Scott Marquardt" wrote in message
not
vertical
supports
tubes and take off.
;-D
way.
- Scott
Floats for airplanes are a lot tougher than canoes. They also have
watertight compartments, so they all don't fill up in case of a leak, or
hole. They also have a raised portion just in back of the cener of gravity,
so that once it is planning, the aircraft can rotate, and fly away. It
might be easyer to convert a float into a canoe. Bettter yet, strap a a
canoe onto the float, and leave the float alone.
Jim in NC--
Old August 8th 03, 06:51 PM
Bushy
I'll let you know in a couple of years, but from what they reckon,
20mph +full flap + 30%power = fly at 20mph
- 20mph headwind = 0mph ground speed
Peter
Old August 10th 03, 03:45 AM
Scott Marquardt
Dan Thomas wrote:
Aircraft floats are designed the way they are for a critical
purpose and it would be difficult indeed to come up with something
much different that might still work.
Looks like there's agreement on that.
Hokay, then, would any respectable homebuilt pontoon be capable of doubling
as some kind of canoe? Granted, we still have the problem that a canoe is
generally wide open, whereas a pontoon that's wide open is ill-advised.
Perhaps a kayak design, where a simple hole in the middle of the pontoon
could be easily covered, might work -- provided a pontoon would be
seaworthy (why do I have this nagging sense it would just tip over no
matter what you tried to do with it).
Thanks to all for responding to an idea that I agree borders on the
nonsensical. I'll skip asking wether using a prop as a canoe paddle would
eliminate the need to j-stroke. ;-)
- Scott
