USB-to-serial converters that work (especially with ILEC SN10) ?
Old May 23rd 05, 04:03 AM
Marc Ramsey
Greg Arnold wrote:
Dave, why don't you upgrade the SN-10 to a USB connector?
That would just shift the driver issues from the USB-to-serial converter
vendors to Dave...
Old May 23rd 05, 04:10 AM
Greg Arnold
The new Colibri uses a USB connector, and other soaring instruments
doubtless will follow in the future.
vendors to Dave...
Old May 23rd 05, 04:17 AM
Marc Ramsey
Yes, and you'll need to get a USB driver from LXN, which is just about
as likely to work on your particular Windows computer as a random
USB-to-serial converter...
Old May 23rd 05, 05:00 AM
Greg Arnold
I have a digital camera, a laser printer, and an Ipaq, all with USB
connectors, and all work fine on my Windows computer. Why would the
Colibri be different?
Old May 23rd 05, 05:10 AM
Kilo Charlie
Thanks Casey - Have you used this for both PClink and software load
(ILEC SN10) ?
Did you get "unregistered driver" or other warnings, or have to upgrade
the driver ?
Thanks !
Best Regards, Dave "YO"
Hi Dave-
It works fine with PCLink for the Model 25 (LS-8) but for some reason did
not with trying to download a flight from the Model 20 (Nimbus)....we just
sent that Model 20 GPS/NAV in for updated software so it may be a Cambridge
issue.....I'll let you know. After mine failed TS1 used his laptop to
download it without a problem.....he has an old laptop with a serial
connnection though. I have not used mine to upload updates or TP databases
into the Model 20 so can't answer that part.....works fine with the 25.
Resulted in missing a nice long flight for OLC......you hear that Mitch???
Casey
Old May 23rd 05, 05:26 AM
Marc Ramsey
Why would a USB-to-serial converter be different?
Because the drivers for most digital cameras (which are actually USB
"mass storage devices"), and low-level printer drivers are included with
the Windows 2K/XP. The generic USB PocketPC driver is now also included
in XP, and both HP and Microsoft have a vested interest in making sure
it works properly.
The USB-equipped flight recorders I have seen all look like USB serial
devices, for which a vendor supplied device driver is required. Flight
recorder vendors don't build their own drivers, they redistribute
whatever driver is supplied by the chip manufacturer which, strangely
enough, happen to be the exact same drivers supplied along with
USB-to-serial converters that use the same chip family.
Old May 23rd 05, 05:40 AM
Greg Arnold
You have lost me. However, I do know that my Belkin adapter works fine
with the LX-5000, but not at all with a Cambridge 302. I also know that
the Cambridge 302 works fine with the USB connection to an Ipaq.
it works properly.
Old May 23rd 05, 05:45 AM
Greg Arnold
Correction -- the Cambridge connection to an Ipaq is not USB. As I
said, I am lost.
with the Windows 2K/XP. The generic USB PocketPC driver is now also
included in XP, and both HP and Microsoft have a vested interest in
making sure it works properly.
Flight recorder vendors don't build their own drivers, they
redistribute whatever driver is supplied by the chip manufacturer
which, strangely enough, happen to be the exact same drivers supplied
along with USB-to-serial converters that use the same chip family.
Old May 23rd 05, 02:56 PM
Bob Greenblatt
For what it's worth, and that probably isn't much here, the Belkin FSU 409
will NOT work with Macintosh OS X.
Bob
bobgreenblattATmsnDOTcom --fix this before responding
Judge halts work on Navy landing field in eastern N.C. Otis Willie Naval Aviation 1 April 21st 04 12:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
Ford V-6 engine work Corky Scott Home Built 19 August 21st 03 12:04 PM
