(RST Engineering, Please read!) "The Muse"
Old May 24th 05, 12:04 AM
RST Engineering
Without me doing a lot of research that most of you seem to have done, what
is the input, what is the output, and what is the function? And no, I won't
do stereo. There are good reasons.
"Scott Skylane" wrote in message
RST Engineering wrote:
Why renamed to me?
O.K., I guess I'll get out the 2X4, and start smacking.
Old May 24th 05, 04:07 PM
Jose
And no, I won't
I'd be curious to know what they are.
Jose
The price of freedom is... well... freedom.
Old May 24th 05, 09:05 PM
RST Engineering
And no, I won't do stereo. There are good reasons.
Stereo In The Aircraft
RST does not produce any stereo intercoms, audio panels, headsets, or other
devices that
reproduce stereo music. If you are absolutely determined to have stereo in
your aircraft, you
might just as well stop reading now, because anything we have to say isn't
going to change your
mind.
We made a conscious business and engineering decision not to produce any
product for stereo.
There are good aviation and engineering reasons for this.
First, a little background music or listening to the ballgame in a cockpit
environment isn't all
that bad. Sometimes flying is miles and miles of nothing but miles and
miles. On the other
hand, I know from my own love of music that when there is a particularly
good cut playing on my
home stereo and I have the headphones on (try "Sweet Sir Galahad" by Baez or
"Minstrel Of The
Dawn" by Lightfoot at somewhere slightly below the threshold of pain in the
'phones to see what I
mean) that I get totally lost within the music and the world just sort of
blurs away. Just
about the LAST thing I want in an airplane is a pilot that has zoned out on
music and is just
holding the controls to have something to do with their hands. That's item
#1.
Second, stereo is expensive. Yes, I understand that FLYING is expensive,
too, but to go to the
expense of specially-designed headphones, intercoms, audio panels, and all
the rest of it seems
to us to be on the other side of reasonable. Our company thrust has, and
always will be, to make
flying affordable for everybody. That's point #2.
Now to the engineering stuff. Suppose you try and take your stereo headset
and fly in somebody
else's airplane that is "regular airplane". Will your stereo headset work
without the trick
little switch on the cable to convert it to a monophonic headset? No, you
will hear one ear of
the conversation only. And what did that little switch do? It put both
earphones in parallel,
which cut the impedance of the headset in half. Properly designed, this
MIGHT not be noticeable
to the aircraft radio, or it might. Since airplane radios weren't designed
to figure out whether
or not you were messing around with a stereo headset, the manufacturer
didn't worry about making
sure his radio would drive that low of an impedance.
Even worse, if somebody else takes his standard aircraft headset and puts it
into your stereo
airplane jack, it will short out one of the channels. Depending on the
design of the intercom,
the best you can hope for is that one stereo channel will be dead in
everybody's headphones.
Second worst is that the short on that channel will blow out the amplifier
for that channel. In
a really lousy design, that short will cause the whole intercom/audio panel
to fail, leaving you
without any headphone audio at all.
Given all these reasons, RST has decided not to produce any stereo
equipment. While it probably
won't sway your decision for stereo in your airplane, we thought you should
at least consider
these problems.
Old May 25th 05, 10:00 AM
Thomas Borchert
RST,
equipment.
Not sure I can follow. All your points except no. 1 have been solved
quite well by most all other companies in the business, and the price
delta has become real small. For headsets and audio panels, stereo is
the de-facto standard now. And no. 1 is really not your decision to
make, is it? It's the decision of the customer. But, if that's the way
you want to do business and it works, by all means do it.
Thomas Borchert (EDDH)
Old May 25th 05, 02:45 PM
RST Engineering
Have been for 33 years now. Seen a lot of them come and go. We are still
here. Must be doing SOMETHING right every now and again.
FS Aeronautical engineering textbooks for sale john hawkins Home Built 0 March 26th 05 09:53 PM
FS Aeronautical engineering textbooks for sale john hawkins General Aviation 0 March 26th 05 09:53 PM
Navy enlistment questions Atcrossroad Naval Aviation 53 September 23rd 04 10:43 AM
PS Engineering Report Jeff Owning 44 December 7th 03 11:24 PM
PS Engineering Hankal Owning 0 December 5th 03 12:25 AM
