even the pros dont get it right
Old May 24th 05, 08:04 PM
Stefan
Steven P. McNicoll wrote:
But my question wasn't about the
floor of Class E airspace, it was about the transition altitude. Please try
again.
I tried to explain the possible reasoning of the regulation. (Which one
may or may not agree with.) I tried to explain, now it's your turn to
try to understand.
Stefan
  #72
Old May 24th 05, 08:05 PM
Steven P. McNicoll
"Stefan" wrote in message
No, it's not a typo. It's a linguistic error of somebody who tries to
communicate in a foreign language. I'm sure it won't happen to you.
If it's not a typo what is it?
  #73
Old May 24th 05, 08:07 PM
Steven P. McNicoll
may or may not agree with.) I tried to explain, now it's your turn to try
to understand.
As you answered a question that wasn't asked, I'm left to conclude you don't
understand the subject you're attempting to discuss.
  #74
Old May 24th 05, 11:08 PM
Stefan
You can read, can't you?
Stefan
  #75
Old May 25th 05, 05:24 AM
Steven P. McNicoll
Yes, I read very well. The problem is in your writing.
  #76
Old May 27th 05, 10:41 PM
Steven P. McNicoll
"Ron Rosenfeld" wrote in message
ICAO sets out standard international phraseology for communications
between air traffic services and pilots in several documents including
Annex 10
Volume 2 (Communications Procedures) to the Convention on International
Civil Aviation and ICAO PANS-ATM (Procedures for Air Navigation Services -
Air Traffic Management) Doc. 4444.
I was not able to find that on the www. However, the British Radio
Telephony Manual CAP 413 is available at
http://www.google.com/url?sa=U&start...13.PDF&e=10313
There is also an appendix where they list the differences from ICAO
standard.
But that would mean the US is NOT the only nation that doesn't adhere to
ICAO phraseology. How can that be??!!!
With regard to the current discussion, of "level instructions", CAP 413
states:
1.2 Level Instructions
1.2.1 Only basic level instructions are detailed in this chapter. More
comprehensive phrases are contained in subsequent chapters in the context
in which they are most commonly used.
1.2.2 The precise phraseology used in the transmission and acknowledgement
of climb and descent clearances will vary, depending upon the
circumstances, traffic density and nature of the flight operations.
1.2.3 However, care must be taken to ensure that misunderstandings are not
generated as a consequence of the phraseology employed during these phases
of flight. For example, levels may be reported as altitude, height or
flight levels according to the phase of flight and the altimeter setting.
Therefore, when passing level messages, the following conventions apply:
a) The word 'to' is to be omitted from messages relating to FLIGHT LEVELS.
b) All messages relating to an aircraft's climb or descent to a HEIGHT or
ALTITUDE employ the word 'to' followed immediately by the word HEIGHT or
ALTITUDE. Furthermore, the initial message in any such RTF exchange will
also include the appropriate QFE or QNH.
Examples include:
Climb FL 150
Climb to altitude 2000 feet.
In another section, they state that "Climb" means "Climb and maintain"
One wonders why they don't just say that. That would allow them to be
consistent with altitudes and Flight Levels; "climb and maintain FL 150",
"climb and maintain 2000."
  #77
Old May 27th 05, 11:30 PM
Steven P. McNicoll
Yes. It serves two pruposes: To avoid confusion between "to" and "two" and
to avoid confusion between "climb to 5000ft" and "climb 5000ft"
Do you have a reference for that? I found a site that says the ICAO
standard is "climb to 5,000 feet".
"An example the FAA uses is that ICAO standard phraseology requires the use
of the phrase 'climb to 5,000 feet' while the U.S. filed to use 'climb and
maintain 5000 feet.' FAA believed that there could be confusion when using
the ICAO phraseology in that situation as to whether the command was climb
to five thousand feet or climb two five thousand feet. Currently, the FAA
requires controllers to comply with standard U.S. phraseology as filed with
ICAO."
http://www.house.gov/transportation/...11-00memo.html
  #78
Old May 28th 05, 02:52 AM
Ron Rosenfeld
On Fri, 27 May 2005 21:41:05 GMT, "Steven P. McNicoll"
You would be more likely to obtain an answer by directing your question to
those making that claim.
  #79
Old May 28th 05, 02:55 AM
Steven P. McNicoll
It was sarcasm. I already know the answer and he who made that claim has
grown silent.
  #80
Old May 28th 05, 09:43 AM
Chris
"Steven P. McNicoll" wrote in message
link.net...
and
use of the phrase 'climb to 5,000 feet' while the U.S. filed to use 'climb
and maintain 5000 feet.' FAA believed that there could be confusion when
using the ICAO phraseology in that situation as to whether the command was
climb to five thousand feet or climb two five thousand feet. Currently,
the FAA requires controllers to comply with standard U.S. phraseology as
filed with ICAO."
with respect in the example about the instruction would be to climb to
flight level 250 so the example is not realistic.
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
Pros & cons of TFT monitors in flightsims? Alan Cameron Simulators 7 October 27th 03 02:57 PM
GPS Models -- Pros and Cons Aviv Hod Piloting 22 July 22nd 03 10:35 PM
