I have an opportunity to buy a 1988 ASW-24 which is
in beautiful condition, good electronics and great trailer. The glider is equipped with M&H winglets. The asking price is $45,000 US. I would appreciate any feedback regarding the winglets and/or the price. Thanks |
Lee,
The ASW-24 is a great aircraft, but I'm sure you have discovered in your research that the 24's original airfoil was discovered to not perform as well as expected in rough air. There was a relatively simple remedy which was to "blunt" the leading edge. Before worrying about the winglets I'd check to ensure that this modification has been done. And to answer your question, if the avionics are top notch and the winglets PROPERLY installed and the finish in very good condition, then $45k sounds like a fair price in my opinion. It's a beautiful aircraft. Respectfully, Lee Rusconi wrote: I have an opportunity to buy a 1988 ASW-24 which is in beautiful condition, good electronics and great trailer. The glider is equipped with M&H winglets. The asking price is $45,000 US. I would appreciate any feedback regarding the winglets and/or the price. Thanks |
In fact it is the other way around.
Is the winglets that is the key. The "blunting", changing the first 10% of the airfoil in the outboard section of the wing was thought to improve the climb but it turns out to be a well designed winglet that made the difference. The factory winglet did not perform as well. Those in the know are changing back to the original airfoil as the cruise is improved but climb does not deteriorate. It was not the airfoil but rather the small Reynolds numbers in the wing tip region that caused the problem, which the winglet corrected. The 24 is still very competitive indeed. I do agree with the rest of your comments. Regards Udo wrote in message oups.com... Lee, The ASW-24 is a great aircraft, but I'm sure you have discovered in your research that the 24's original airfoil was discovered to not perform as well as expected in rough air. There was a relatively simple remedy which was to "blunt" the leading edge. Before worrying about the winglets I'd check to ensure that this modification has been done. And to answer your question, if the avionics are top notch and the winglets PROPERLY installed and the finish in very good condition, then $45k sounds like a fair price in my opinion. It's a beautiful aircraft. Respectfully, Lee Rusconi wrote: I have an opportunity to buy a 1988 ASW-24 which is in beautiful condition, good electronics and great trailer. The glider is equipped with M&H winglets. The asking price is $45,000 US. I would appreciate any feedback regarding the winglets and/or the price. Thanks |
I fly an ASW-24, original airfoil, and it climbs nicely, paired with
another -24B. Also climbs well with LS-3, DG-200, DG-400, Discus, PW-5 and so on. I fly in Spain, so thermals are usually strong and turbulent. No problem there. I am in the belief that the leading edge thing is more a factory response to gliding gossip, than an actual aerodinamic problem. Great bird, great cockpit, rigging, handling, etc. You wouldn't regret buying it. Replace the electric ballast dump with a mechanic one. The electric takes forever to dump. escribió en el mensaje oups.com... Lee, The ASW-24 is a great aircraft, but I'm sure you have discovered in your research that the 24's original airfoil was discovered to not perform as well as expected in rough air. There was a relatively simple remedy which was to "blunt" the leading edge. Before worrying about the winglets I'd check to ensure that this modification has been done. And to answer your question, if the avionics are top notch and the winglets PROPERLY installed and the finish in very good condition, then $45k sounds like a fair price in my opinion. It's a beautiful aircraft. Respectfully, Lee Rusconi wrote: I have an opportunity to buy a 1988 ASW-24 which is in beautiful condition, good electronics and great trailer. The glider is equipped with M&H winglets. The asking price is $45,000 US. I would appreciate any feedback regarding the winglets and/or the price. Thanks |
I slightly disagree with Udo. The best result, in my opinion, having
flown '24's in all the combinations, is the leading edge mod and improved winglets together give the best total result. I never saw any deterioration of glide with leading edge mod and did see improvement in gust sensitivity. He is very much correct that winglet is most important as it keps the tip working and aileron effective down to a speed where overall drag on the airfoil begins to rise due to separation. '24 is a great glider, I'd still have it today if Gerhard had not made a little bit better glider in the "28. Good Luck UH |
As I recall, the ASW-24 had a climb problem until it
was discovered the ship must be flown a bit faster while thermaling. Is this true and at what speed do you thermal the ship? JJ At 02:00 26 May 2005, Udo Rumpf wrote: In fact it is the other way around. Is the winglets that is the key. The 'blunting', changing the first 10% of the airfoil in the outboard section of the wing was thought to improve the climb but it turns out to be a well designed winglet that made the difference. The factory winglet did not perform as well. Those in the know are changing back to the original airfoil as the cruise is improved but climb does not deteriorate. It was not the airfoil but rather the small Reynolds numbers in the wing tip region that caused the problem, which the winglet corrected. The 24 is still very competitive indeed. I do agree with the rest of your comments. Regards Udo wrote in message roups.com... Lee, The ASW-24 is a great aircraft, but I'm sure you have discovered in your research that the 24's original airfoil was discovered to not perform as well as expected in rough air. There was a relatively simple remedy which was to 'blunt' the leading edge. Before worrying about the winglets I'd check to ensure that this modification has been done. And to answer your question, if the avionics are top notch and the winglets PROPERLY installed and the finish in very good condition, then $45k sounds like a fair price in my opinion. It's a beautiful aircraft. Respectfully, Lee Rusconi wrote: I have an opportunity to buy a 1988 ASW-24 which is in beautiful condition, good electronics and great trailer. The glider is equipped with M&H winglets. The asking price is $45,000 US. I would appreciate any feedback regarding the winglets and/or the price. Thanks |
J.J.
Since I am a relative late comer to the ASW 24 and have flown it only with the B mod. and Nixon winglet My target speed "at a 45deg". bank and empty at 7.3lb/sqft is about 50kt. Regards Udo "John Sinclair" wrote in message ... As I recall, the ASW-24 had a climb problem until it was discovered the ship must be flown a bit faster while thermaling. Is this true and at what speed do you thermal the ship? JJ At 02:00 26 May 2005, Udo Rumpf wrote: In fact it is the other way around. Is the winglets that is the key. The 'blunting', changing the first 10% of the airfoil in the outboard section of the wing was thought to improve the climb but it turns out to be a well designed winglet that made the difference. The factory winglet did not perform as well. Those in the know are changing back to the original airfoil as the cruise is improved but climb does not deteriorate. It was not the airfoil but rather the small Reynolds numbers in the wing tip region that caused the problem, which the winglet corrected. The 24 is still very competitive indeed. I do agree with the rest of your comments. Regards Udo wrote in message groups.com... Lee, The ASW-24 is a great aircraft, but I'm sure you have discovered in your research that the 24's original airfoil was discovered to not perform as well as expected in rough air. There was a relatively simple remedy which was to 'blunt' the leading edge. Before worrying about the winglets I'd check to ensure that this modification has been done. And to answer your question, if the avionics are top notch and the winglets PROPERLY installed and the finish in very good condition, then $45k sounds like a fair price in my opinion. It's a beautiful aircraft. Respectfully, Lee Rusconi wrote: I have an opportunity to buy a 1988 ASW-24 which is in beautiful condition, good electronics and great trailer. The glider is equipped with M&H winglets. The asking price is $45,000 US. I would appreciate any feedback regarding the winglets and/or the price. Thanks |
JJ,
Good winglets fix the climb "problem" (which wasn't much of a problem--I flew mine sans winglets the first year and loved it). Hank Nixon and I have a friendly ongoing debate over whether the modified leading edge (the famous "B" mod) does anything beneficial. He did the mod; I didn't. I think he's just keen to see me take a file to my leading edge. With Hank's latest winglets, my ship climbs with anything. I'd thought until last year that I had to fly it a little faster; e.g., low 50s (kts.) in moderate banks. But I discovered at New Castle that in survival conditions, I could fly it just like a 1-26 and it climbs great: i.e., slow it down until it's on the edge of buffet. There may or may not be some benefit to the blunter "B" leading edge in gusty thermals but I haven't noticed. I do agree with those who believe that the debate over the airfoil, micro-turbulence, etc., was primarly a very effective (obviously!) marketing campaign on the factory's part. After all, how do you sell a brand new glider that doesn't seem to go any better than the old model unless you can point to something that's been "fixed"? ![]() Chip Bearden "JB" ASW-24 owner since 1992 John Sinclair wrote: As I recall, the ASW-24 had a climb problem until it was discovered the ship must be flown a bit faster while thermaling. Is this true and at what speed do you thermal the ship? JJ |
It's true what you say. The first flights I tried to thermal at 80-85kph,
just as I had done on ASK-21, Astir, and Discus I previusly flew. Found it harder to climb. I thermal now around 90-95kph and I find no problem. Just had to be slightly more careful about speed. It climbs very well if you respect the speed range. "John Sinclair" escribió en el mensaje ... As I recall, the ASW-24 had a climb problem until it was discovered the ship must be flown a bit faster while thermaling. Is this true and at what speed do you thermal the ship? JJ |
Of course it would be true, at 80km/k you would be flying to slow
if you tried to thermal. This is minimum sink speed in level flight at 6.5 lb/sqft. at 7.5 lb/sqft you would be approaching stall speed. To recap the ASW24 does not have to be flown any faster then other glider of its type. Two gliders you have mentioned have a much lighter wingloading and the Discus and the ASW24 with 7.5 lb/sqft will fly at about the same speed. Now I know how misinformation gets started. Regards Udo "J.A.M." wrote in message ... It's true what you say. The first flights I tried to thermal at 80-85kph, just as I had done on ASK-21, Astir, and Discus I previusly flew. Found it harder to climb. I thermal now around 90-95kph and I find no problem. Just had to be slightly more careful about speed. It climbs very well if you respect the speed range. "John Sinclair" escribis en el mensaje ... As I recall, the ASW-24 had a climb problem until it was discovered the ship must be flown a bit faster while thermaling. Is this true and at what speed do you thermal the ship? JJ |
