#21
Skywise wrote:
Other reports have indicated that 121.5 MHz was in use by an unidentified ELT signal at the time communications were attempted. Snipola OK. That explains that. My question then is wouldn't the Blackhawk crew have noticed the ELT signal on their radios? I mean, if I tun my receiver to 121.5 and there's an ELT on it, won't I know so? I don't see how you could miss it. It is a very distinctive howl. -- Mortimer Schnerd, RN VE |
Guy Elden Jr wrote:
Ron Natalie wrote: Guy Elden Jr wrote: - Rumsfeld had ordered the plane to be shot down, and they were literally seconds away from doing so... I don't know if Rumsfeld was in the loop, but they were very close to being shutdown. I think that's a very big deal though. The claim that an order was actually made is a far cry from just debating the point, which is probably SOP anyway for any incursion that gets close enough to the restricted zone at the center of the ADIZ. - The "CFI" had his "license" revoked... No CFI, but even REC.AVIATORS who should no better have been making this error right and left. It gives a very bad impression of instructors when they go calling this guy an instructor. Call him a country bumpkin who should've known better, because that's what he is. - The "student pilot" would not be charged... Have you heard anything to the contrary? Point here (and granted, this is really more a technicality for pilots) is that the student pilot was not, at the time of the incident, acting in the capacity of a student pilot. He couldn't have been, because the guy who was acting as PIC was not an instructor. So the whole scenario that this radio station described was factually wrong on several accounts, and paints a very different picture... i.e., "instructor & student" vs "pilot and passenger". Don't bet on that. If FAA wanted the student certificate, they'd have it and it would be up to him to try to get it back in court. Even when the lawnchair nutcase with the balloons survived his stunt, FAA said that they would have cancelled any certificates he had because that's all they could really do. But he didn't have any. |
"Skywise" wrote in message
... OK. That explains that. My question then is wouldn't the Blackhawk crew have noticed the ELT signal on their radios? You'd think so, yes. I mean, if I tun my receiver to 121.5 and there's an ELT on it, won't I know so? Sorry if it's an obvious question...I'm still just an armchair pilot. No, it's a good question and it illustrates why it seems that the folks in the C150 weren't the only people with their heads up their butts that day. Pete |
I mean, if I tun my receiver to 121.5 and there's an ELT on it, won't I know so? Sorry if it's an obvious question...I'm still just an armchair pilot. Keep up. ![]() The Blackhawk crew asked the Cessna to tune to a second frequency after noticing the issue on 121.5. Shaeffer, the Cessna pilot, claims an inability to talk to them on that frequency until he'd turned 90 degrees. -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 ____________________ |
On Thu, 26 May 2005 22:35:40 -0000, Skywise
wrote in :: Larry Dighera wrote in : Snipola Other reports have indicated that 121.5 MHz was in use by an unidentified ELT signal at the time communications were attempted. Snipola OK. That explains that. My question then is wouldn't the Blackhawk crew have noticed the ELT signal on their radios? I can't speak for the Blackhawk crew, but one would expect so. I mean, if I tun my receiver to 121.5 and there's an ELT on it, won't I know so? If the ELT signal were strong enough to interfere with communications between two aircraft in formation flight, I would think it could be heard by both of them. Sorry if it's an obvious question...I'm still just an armchair pilot. No need to apologize. The point is, the governments shoot-down policy for intruding aircraft relies to a great extent on two way radio communications. At least it seems to have in this case. To base a lethal policy on an unreliable method of communications is half-baked at best, and displays the government's lack of concern for the welfare of its citizens at worst. |
Larry Dighera wrote:
It relies upon radio communications that are inherently unreliable. It does not. There are visual signs. Stefan |
On Fri, 27 May 2005 10:17:47 +0200, Stefan
wrote in :: Larry Dighera wrote: It relies upon radio communications that are inherently unreliable. It does not. It seems to have to some extent in this case. And that failure in establishing communications apparently resulted in delaying the Cessna from diverting course away from ground based weapons and certain death. There are visual signs. That is true also. However, I have not read/heard reports of the standard/documented* visual signs being successfully given in this case. In this case, apparently initially attempting to use radio communications to communicate with the pilot of the Cessna 150 failed resulting in the aircraft continuing deeper into the White House FRZ. The F-15 intercept aircraft had to resort to the deployment of flairs (an undocumented procedure outside what pilots are taught to expect in intercept situations) to cause the Cessna to change course. Should the flight have continued 15 to 20 seconds longer without changing course, government spokesmen have said the order to shoot it down would have been given. Such a close encounter with our government's lethal force makes me uncomfortable, and calls into question the adequacy of the intercept procedures as they are currently written. From the information (of admittedly questionable credibility) I've seen, it appears the PIC's judgment in intentionally launching without being current to carry passengers, with a pre-9/11 chart, was notably poor. It appears to me, that he hadn't been aloft for a good length of time, and his lack of currency resulted in his flight becoming a hazard to aerial navigation and causing a disruption of governmental decorum. But I don't consider those offences to warrant a death sentence. So while this case reflects badly on GA pilots, it also points out the indiscretion of the security policy currently in place in the vicinity of our nation's capital and those who drafted it. * http://www.aopa.org/whatsnew/newsite...intercept.html |
#28
![]() "Larry Dighera" wrote in message It worked. The plane was diverted, nobody was killed, the media made a bunch of money and an idiot lost his certificate. What if the C-150 had gotten close enough to the White House to trigger ground fire as a result of its inability to communicate via radio? Would you still characterize the policy as having worked? Nope. But it didn't work out that way. If you're arguing that the margin of error was a little slim and shows flaws with relying on radio communications, I might agree. Except, there's no way to hook a landline to an airplane, or board it, so using radio to communicate with it is more or less necessity, isn't it? 'Course, publishing the ADIZ, TFRs, FARs, requiring weather briefing and expecting a certificated pilot to be able to navigate in VFR don't seem to have worked either. Personally, I don't have much sympathy for the guy. -c |
#29
On Fri, 27 May 2005 15:50:00 -0700, "gatt"
wrote in :: "Larry Dighera" wrote in message It worked. The plane was diverted, nobody was killed, the media made a bunch of money and an idiot lost his certificate. What if the C-150 had gotten close enough to the White House to trigger ground fire as a result of its inability to communicate via radio? Would you still characterize the policy as having worked? Nope. But it didn't work out that way. It hasn't worked out that way yet. But the lethal force dictum has only been in place for a few years so far. Given the narrow margin the Cessna flight escaped tragedy, I would expect that someone will get shot down for no good reason within the coming decades. If you're arguing that the margin of error was a little slim and shows flaws with relying on radio communications, I might agree. Thank you. Except, there's no way to hook a landline to an airplane, or board it, so using radio to communicate with it is more or less necessity, isn't it? It's only a necessity if you consider the security measures effective in stopping terrorist activity. I find it difficult to see how the current security policy accomplishes what it purports to address. More intelligent people need to reassess what measures might be more effective, IMO. 'Course, publishing the ADIZ, TFRs, FARs, requiring weather briefing and expecting a certificated pilot to be able to navigate in VFR don't seem to have worked either. Humans make mistakes; it's human nature. If those mistakes intrude on the rights or safety of others, they should be made to compensate those affected by their mistakes/inelegance. In this case, the disruptive evacuation in DC was a result of misguided security officials/policy, and the only threat to the safety of others occurred as a result of those misguided security officials/policy not the Cessna PIC. Personally, I don't have much sympathy for the guy. I have no sympathy for the Cessna PIC at all, but I don't consider that to be the issue here. |
#30
Larry Dighera wrote: Humans make mistakes; it's human nature. If those mistakes intrude on the rights or safety of others, they should be made to compensate those affected by their mistakes/inelegance. In this case, the disruptive evacuation in DC was a result of misguided security officials/policy, and the only threat to the safety of others occurred as a result of those misguided security officials/policy not the Cessna PIC. Personally, I don't have much sympathy for the guy. I have no sympathy for the Cessna PIC at all, but I don't consider that to be the issue here. I agree with Larry here. It seems that the entire security apparatus of this country is run by a combination of Chicken Little and Fearless Fosdick. For those who don't remember, Fearless Fosdick was the Al Capp takeoff on Dick Tracy, who shot "criminal jaywalkers" while ignoring real criminals. Everyone knows the story of Chicken Little. -- Remove _'s from email address to talk to me. |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Naval Aviation | 5 | August 21st 04 12:50 AM |
Conspiracy Theory’s real Script: Slave CIA, FBI change the story jews wanted to tell the media | Jean-Paul Roy | Restoration | 0 | July 12th 03 12:55 PM |
MEDIA ADVISORY ON 767A REPORT TO CONGRESS | Otis Willie | Military Aviation | 0 | July 11th 03 09:30 PM |
