Are handheld GPSes becoming a defacto primary nav source?
Old September 1st 03, 07:15 PM
Tom Pappano
Paul Tomblin wrote:
This week I did several IFR flights, some in IMC and most in VMC. On a
couple of those flights, ATC offered me direct to the next VOR after the
one I was navigating to, well before I could actually pick up the signal.
One time departing Rochester, they told me to go direct Elmira when I was
less than 500 feet off the ground and there are 2000 foot hills between me
and Elmira. So I turned to the approximate direction, and punched "GOTO"
on my handheld GPS, and followed the GPS's HSI until I climbed up high
enough to get a signal.
They don't offer a vector, or say "direct when able", they just say "05X,
go direct East Texas".
It seems to me that they know we can't recieve that VOR, but as long as
we've got the GPS on board, it doesn't matter to them. I guess as far as
legalities go, we're just ded reckoning in the right general direction
until we pick up the VOR.
I pretty much always file IFR /u or /a, and I've come to the conclusion
ATC does assume you have some sort of GPS or Loran available. I almost
always get some sort of "direct". I've only been asked once if I had
GPS available, on an IMC Angel Flight from Tulsa to Houston. Soon as I
was handed off to Fort Worth (about McAlester, OK) he inquired about
GPS, then cleared me direct HOU. Another fun part was the arrival.
We did a "best forward speed" intercept of the localizer at 8000, with
the approach flown at 160. On another trip into New Orleans, during a
STAR, I was given a direct to a fix that "shortcutted" part of the
procedure.
I've also wondered if ATC somtimes observes the "quality of your
performance" and then maybe helps/expects more accordingly.
Tom Pappano, PP-ASEL-IA
Old September 1st 03, 07:23 PM
Tarver Engineering
nk.net...
wrote in message ...
Why the hostility?
What hostility?
Conflict is the mother of creation.
Old September 1st 03, 11:59 PM
hnelson
I put "GPS" in the comment part of the flight plan and file /A. I have an
panel mount non-IFR GPS coupled to the autopilot.
Howard
Old September 2nd 03, 12:00 AM
Mike Adams
The first one was via the victor airways, the second one was VOR to VOR.
Details:
KLVS V190 DHT V234 EMP V10 DODSN KOJC
KOSH LNR UKN MCW FOD KSUX
Mike
(Eric Wickberg) wrote:
Mike, did you file airway routes on these flight plans, or direct?
Eric
Old September 2nd 03, 12:18 PM
Dan Thompson
I believe your instructor was wrong. It is permissible to file an IFR plan
with a direct route, even if all you have to navigate direct with is a
handheld or even just a tuna sandwich. You are working harder than you have
to, filing an airways or VOR route then requesting direct later. It doesn't
hurt you any, but you are wasting your time.
The AIM addresses the issue of flying direct when outside of NAVAID
service
volume limits; see section 5-1-7, paragraphs c.4 and c.5. Also see
paragraph c.7 regarding obstacle clearance rsponsibility.
I raised this same issue with my flight instructor when taking IFR
lessons.
He explained that although it's not permissable to FILE an IFR direct
route
that requires GPS without having a certified unit, it's OK to request
"direct" if I have my hand-held and I'm in radar contact. So now I always
file a route that meets NAVAID requirements and request "direct" once
established on the filed route. I just let the controller know that "I
have
GPS aboard" and my request has never been denied.
"Paul Tomblin" wrote in message
signal.
was
me
"GOTO"
"05X,
as
Paul Tomblin , not speaking for anybody
Give a man a fish and you feed him for a day; give him a freshly-
charged Electric Eel and chances are he won't bother you for anything
ever again. -- Tanuki
Old September 2nd 03, 07:07 PM
Robert M. Gary
"hnelson" wrote in message om...
I do the same and often get direct. However, FSS complains to no end when I do it.
-Robert
Old September 2nd 03, 07:51 PM
Michael
There are several separate issues at work here.
First off - there are no official, written rules as to what may be
used for enroute naviagation under IFR. As far as legalities go, you
are proceeding direct to the fix, as cleared, using a tuna sandwich,
tea leaves, handheld GPS, or whatever streamlined navigation technique
you prefer. Of course this is directly counter to the
(non-regulatory) AIM, so what we have in practice is a massive gray
area.
Second, the controller NEVER cares HOW you comply with your clearance,
merely that you DO comply with it. If he cleared you present position
direct to a fix, then as long as you proceed along the line between
that present position and the fix, he really couldn't care less how
you are doing it.
Third, you've nailed it. The handheld GPS has become a defacto
primary nav source. I don't know ANYONE who flies Part 91 IFR without
a GPS of some kind anymore, unless it's a training flight. Why would
you?
The fact is that a handheld GPS and a good set of batteries provide
the best possible protection against nav/electrical failure. That's
important when you have a non-redundant electrical system. The GPS
provides course guidance that's less affected by terrain than anything
you're likely to find in a GA aircraft. It's more accurate and
(unless we're talking about IFR-approved stuff that had to have the
user interface made FAA-compliant and thus defective) easier to use
than anything else in the airplane.
Controllers are not idiots - they've caught on. They realize that
virtually everyone can now go direct to any fix - and that means that
airplanes can be routed to bypass choke points like VOR's. Clearly
that improves safety. Just as clearly, insisting on following airways
because you lack 'approved' area nav is not in the interest of safety.
Michael
