Painting the pilot side of a wood prop
Old May 28th 05, 01:53 PM
Michael Horowitz
Default Painting the pilot side of a wood prop
There are sun angles such that on final I get a strobe effect from sun
reflected off the back of the wooden prop.
I have asked Sensinich if painting the back would cause them any
heartburn i.e. different rates of heat absorbtion, balance , etc.
NILHRD from them yet.
Anyone had any experience? - Mike
Old May 28th 05, 05:37 PM
Kyle Boatright
My prop was made by Aymar/Demuth and came from the factory with black paint
on the back.It hasn't given any problems in 4 years and over 300 hours, and
the black paint more or less makes the prop disappear from the pilot's seat.
I don't think you'll have any problems painting yours. Just make sure it is
clean to start with, and use a semi-gloss (not flat) paint. Flat paints
don't hold up well, and are harder to clean. Also, use light coats of
paint, and try and keep the amount of paint equal on both blades or your
prop *might* have a balance problem.
KB
"Michael Horowitz" wrote in message
Old May 29th 05, 02:09 AM
Smitty
That strobe effect could be more than annoying. Some pilots are unaware
of flicker vertigo, sometimes triggered by landing into a setting sun.
The idle RPM of a prop shuttering a bright light source can scramble the
brain so thoroughly that the pilot becomes incapable of flying, with
fatal results. As a minimum it's good to find out whether you're
susceptible to this, and if so, avoid landing on 27 at sunset!
Old May 29th 05, 04:27 PM
Blueskies
"Smitty" wrote in message news
I've also read that this flicker can cause a seizure in diabetics...
Stealth Pilot
On Sat, 28 May 2005 08:53:09 -0400, Michael Horowitz
paint the side facing you matt black.
use an acrylic laquer out of a rattle can (its the lightest weight
paint)
paint even coats on each side then balance your prop.
correct the imbalance with layers of paint.
bolt it back on using a torque wrench and you will have done yourself
and your aeroplane a big favour.
shiny props of any colour are a liability with the sun behind you
because you get a shiny wooden or chrome disk in front of you that can
be impossible to see through.
(been there and painted it matt black the next day. balancing the prop
is very important in the battle against fatigue failures)
Stealth Pilot
Australia
Old May 29th 05, 05:10 PM
Montblack
"Blueskies" I've also read that this flicker can cause a seizure in
diabetics...
Diabetics?
How does that work?
Montblack
Old May 29th 05, 05:23 PM
jls
"Blueskies" wrote in message
news
Yes, and there is also anecdotal evidence in the literature that it renders
viagra ineffective and has triggered coprolalia. That's the reason why I
paint the backside of woods props flat black, or with satin varnish.
Old May 30th 05, 04:23 AM
Darrel Toepfer
diabetics...
Diabetics?
How does that work?
Dianetics... Believers in everything Diane...
Old May 30th 05, 11:26 AM
Dan, U.S. Air Force, retired
Darrel Toepfer wrote:
diabetics...
Diabetics?
How does that work?
Frequently in conflict with Judyism which is basically what occurs when
Judy finds you with Diane.
Old May 30th 05, 12:42 PM
Blueskies
"Richard Riley" wrote in message ...
On Sun, 29 May 2005 15:27:27 GMT, "Blueskies"
:"Smitty" wrote in message news :
: That strobe effect could be more than annoying. Some pilots are unaware
: of flicker vertigo, sometimes triggered by landing into a setting sun.
: The idle RPM of a prop shuttering a bright light source can scramble the
: brain so thoroughly that the pilot becomes incapable of flying, with
: fatal results. As a minimum it's good to find out whether you're
: susceptible to this, and if so, avoid landing on 27 at sunset!
:I've also read that this flicker can cause a seizure in diabetics...
No. In epileptics, sometimes.
Well, one good reply out of 5 isn't bad...thanks!
I wonder if Chris Thomas is a real pilot? Anybody know? Badwater Bill Home Built 116 September 3rd 04 05:43 PM
Pilot Error? Is it Mr. Damron? Badwater Bill Home Built 3 June 23rd 04 04:05 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Single-Seat Accident Records (Was BD-5B) Ron Wanttaja Home Built 41 November 20th 03 05:39 AM
