The HIO ILS 22 has a hold at COUVE which is defined by the intersection
of three things: the UBG 232, BTG 242 and the LOC. It's also the UBG 232 @ 21.7 DME. I was flying this in FS2002 in the 182RG, which only has 1 CDI on the panel, but it does have a DME you can remote to the second (invisible, I guess) NAV. So I identified COUVE as 21.7 DME on the UBG 232 and turned outbound, flipflopped to the LOC for the hold, but kept the DME on UBG to identify the intersection as "on the LOC with the UBG DME 21.7". Would that be legitimate if you were in a real airplane with one CDI and DME, or are you supposed to flip over to BTG or UBG to identify the intersection? It occured to me later that it's not so hard since you can leave the OBS on the radial and the LOC will still work. -- Ben Jackson http://www.ben.com/ |
"Ben Jackson" wrote in message news:22g5b.258423$Oz4.68786@rwcrnsc54... The HIO ILS 22 has a hold at COUVE which is defined by the intersection of three things: the UBG 232, BTG 242 and the LOC. It's also the UBG 232 @ 21.7 DME. Actually, the UBG 232 radial does not define the intersection...its just a transition from the Newburg VOR to the IAF. I was flying this in FS2002 in the 182RG, which only has 1 CDI on the panel, but it does have a DME you can remote to the second (invisible, I guess) NAV. So I identified COUVE as 21.7 DME on the UBG 232 and turned outbound, flipflopped to the LOC for the hold, but kept the DME on UBG to identify the intersection as "on the LOC with the UBG DME 21.7". Would that be legitimate if you were in a real airplane with one CDI and DME, or are you supposed to flip over to BTG or UBG to identify the intersection? It occured to me later that it's not so hard since you can leave the OBS on the radial and the LOC will still work. That's absolutely legitimate. Often times you will have intersections that are identified by several means, such as intersections, NDBs, and DME fixes. As long as you have the equipment to identify the fix somehow, you're good. A second VOR to crosscheck would be better, but its not required. -- Ben Jackson http://www.ben.com/ |
No such thing as "supposed to." You decide how to use the installed
equipment to your best advantage. Bob Gardner "Ben Jackson" wrote in message news:22g5b.258423$Oz4.68786@rwcrnsc54... The HIO ILS 22 has a hold at COUVE which is defined by the intersection of three things: the UBG 232, BTG 242 and the LOC. It's also the UBG 232 @ 21.7 DME. I was flying this in FS2002 in the 182RG, which only has 1 CDI on the panel, but it does have a DME you can remote to the second (invisible, I guess) NAV. So I identified COUVE as 21.7 DME on the UBG 232 and turned outbound, flipflopped to the LOC for the hold, but kept the DME on UBG to identify the intersection as "on the LOC with the UBG DME 21.7". Would that be legitimate if you were in a real airplane with one CDI and DME, or are you supposed to flip over to BTG or UBG to identify the intersection? It occured to me later that it's not so hard since you can leave the OBS on the radial and the LOC will still work. -- Ben Jackson http://www.ben.com/ |
| Instrument panel labelling options | John Galban | Home Built | 12 | November 18th 04 11:42 PM |
| Carpeting options? - New Cessna's as an example | BellSouth.net News | Home Built | 2 | October 12th 04 05:23 AM |
| Lycoming O-290-D options | Gene Z. Ragan | Home Built | 6 | March 11th 04 11:17 AM |
| British Homebuilt Aeroplane needs Identifying | Phillip Rhodes | Home Built | 3 | July 11th 03 05:10 PM |
| Wow! New fractional aircraft share re-sale options | Darrel Toepfer | Home Built | 0 | July 8th 03 08:30 PM |
