![]() "old hoodoo" wrote in message news:EO7me.74275$yV4.25134@okepread03... Cougar wrote: Somebody on another forum was trying to convince people that because of the gasoline shortages during WW-II that there were quiet a few aircraft that actually used diesel fuel. I know that people are playing with that today, but was it really used in aviation back then? Thanks, Coug 140 Ju-86D's. 276 Bv-138's. All used the Junkers Jumo 205 These were not used due to gas shortages. I think the Ju-86's might have been an attempt to use the diesels to see how they would work out in service (better engines replaced them) and perhaps the Bv-138 used them due to their intended use in conjunction with naval vessels. The Ju 86s were a combination of two hopes - greater range, and greater power from the diesels. But the lack of acceleration killed this off, as even in?1936? it was clear that the diesel-engined Ju 86s were 'easy meat' compared to the petrol variant. As an earlier poster reported, where altitude was needed, not acceleration, then diesel-engined variants had a future - but when fighters could reach those altitudes, it was again the end of the diesel. |
And for what it's worth, there were even diesel model airplane engines,
at least in the years immediately after WWII. I've a couple of flying model airplanes my father built in the 1946 to 1950 period so equipped. Rich |
"R Leonard" wrote in news:1117507544.101576.304210
@o13g2000cwo.googlegroups.com: And for what it's worth, there were even diesel model airplane engines, at least in the years immediately after WWII. I've a couple of flying model airplanes my father built in the 1946 to 1950 period so equipped. Many model airplane engines today are still two-stroke diesels. They start with a glow plug and continue running after starting just the way big diesels do. Dave in San Diego |
"R Leonard" wrote:
And for what it's worth, there were even diesel model airplane engines, at least in the years immediately after WWII. I've a couple of flying model airplanes my father built in the 1946 to 1950 period so equipped. Rich Sure...aren't most model a/c engines Diesel?...I've had several way back when I was young...(in the fifties) they all had glo-plugs for starting and none had an ignition system...mine were all two stroke cycle Diesels... much simpler. -- -Gord. "I'm trying to get as old as I can, and it must be working 'cause I'm the oldest now that I've ever been" |
On Tue, 31 May 2005 04:35:22 GMT, Gord Beaman
wrote: "R Leonard" wrote: And for what it's worth, there were even diesel model airplane engines, at least in the years immediately after WWII. I've a couple of flying model airplanes my father built in the 1946 to 1950 period so equipped. Rich Sure...aren't most model a/c engines Diesel?...I've had several way back when I was young...(in the fifties) they all had glo-plugs for starting and none had an ignition system...mine were all two stroke cycle Diesels... much simpler. I had 'em, too. They did function on the same principle as diesels, but were powered by a form of gasoline. They were not powered by diesel fuel. The only aircraft trying it today, that I know of, are the Diamond people. Personally, I'd like to see them "pull it off." Time will tell. Bill Kambic |
Dave in San Diego wrote:
Many model airplane engines today are still two-stroke diesels. They start with a glow plug and continue running after starting just the way big diesels do. Close, but for clarification: o There are diesel model engines today. They run at a higher compression than glow engines, and run on diesel fuel, rather than glow fuel, which is basically a methanol/oil mix. Typically, they don't have glow plugs. o Glow engines, although they appear to run on the heat of compression, won't continue running without a hot glow plug filament. (After the engine is running, and battery voltage is removed, the filament continues to glow from the heat of ignition, the ignition having been caused by the glowing filament.) -- John Miller email domain: n4vu.com; username: jsm(@) Surplus (For sale or trade): |
![]() "John Miller" wrote in message ... Dave in San Diego wrote: Many model airplane engines today are still two-stroke diesels. They start with a glow plug and continue running after starting just the way big diesels do. Close, but for clarification: o There are diesel model engines today. They run at a higher compression than glow engines, and run on diesel fuel, rather than glow fuel, which is basically a methanol/oil mix. Typically, they don't have glow plugs. o Glow engines, although they appear to run on the heat of compression, won't continue running without a hot glow plug filament. (After the engine is running, and battery voltage is removed, the filament continues to glow from the heat of ignition, the ignition having been caused by the glowing filament.) Glow plugs were used on gasoline engines long before the spark plug was invented. On early engines the glow plug had to be heated with a blowlamp before the engine could be started. The plug itself was a copper or brass rod that protruded into the cyliner. Keith ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
![]() "Peter Stickney" wrote in message ... Sorry for jumping in late - I'm replying to Bill Kambic, too. (No Offence, Bill, Finger Trouble on my part) Gord Beaman wrote: wrote: On Tue, 31 May 2005 04:35:22 GMT, Gord Beaman wrote: "R Leonard" wrote: And for what it's worth, there were even diesel model airplane engines, at least in the years immediately after WWII. I've a couple of flying model airplanes my father built in the 1946 to 1950 period so equipped. Rich Sure...aren't most model a/c engines Diesel?...I've had several way back when I was young...(in the fifties) they all had glo-plugs for starting and none had an ignition system...mine were all two stroke cycle Diesels... much simpler. I had 'em, too. They did function on the same principle as diesels, but were powered by a form of gasoline. They were not powered by diesel fuel. Model Airplane Glow Fuel is usually Methanol, with something (Usually Castor Oil) added to make it lubricate better. High performance fuels used to have Nitromethane added in as well. I don't know if they still do that. AFAIK, the model diesels did run on kerosene. I've never run one, but I've seen a couple. Neat little widgets. There isn't a whole lot of difference between them and a glow engine in construction, save for the head. Instead of a glow plug, they've got a screw that adjusts an opposing "piston", allowing you to change the combustion chamber volume and therefore the compression ratio. Yes, thanks Bill...I knew that they didn't use diesel fuel, smells much more potent to me...someone mentioned here that they use the heated filament as a hot-spot for ignition (for the running phase) rather than compression heat (as in a true diesel) which makes sense. That's the way I understand it. The glow plug's wire must not transfer heat to the head very well. -- Pete Stickney Java Man knew nothing about coffee. AFAIK the glow wire is made of/plated with platinum - some kind of catalytic effect on methanol keeps the wire hot. |
2-stroke diesel is the (near) future? | Max Kallio | Home Built | 134 | July 18th 05 12:39 AM |
2-stroke diesel is the (near) future? | Max Kallio | Rotorcraft | 123 | July 18th 05 12:39 AM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | Home Built | 1 | January 4th 04 04:04 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Rotorcraft | 2 | September 13th 03 12:44 AM |
fatal bird strike | StellaStar | Piloting | 9 | July 13th 03 09:41 PM |
